Question about Coffee Makers & Espresso Machines
Saeco xelsis leaking water
Running a descaling cycle lets my mashine leak water at the front rigt hand side and also at the middle of the mashine, right hand side. Its out of warranty now and had been repaired 4 times since January now. Last fix lasted 4 months and its starting again. With all the electrics inside where it seems to leak I am concerned keeping the mashine running. Any suggestions? Thx.
    Problem Solver:
  • 12 Answers
The removable drip tray inside the front of the machine has two rubber inserts on the back side and the rubber has come away from the plastic causing a false leak. You will need to order a new one or fix the existing one.
Posted on Aug 13, 2015
mirran
  • 515 Answers
SOURCE: Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Posted on Jul 10, 2008
ginko
  • 19396 Answers
SOURCE: My Saeco Incanto Sirius machine keeps asking for yet another VENTILATE cycle
The following procedure works on Gaggia and Saeco when you get the ventilate error:
The Ventilate sign can be due to one or more of the following reasons:
Cause 1- Water leaking from the inlet valve below the water tank. The hose from the inlet valve to the pump can be air locked. When using the hand pump, do not thrust its nozzle too deep (maximum insertion to not exceed 1/3".
Cause 2- Blockage in the passage of water due to clogged passage anywhere between the pump and espresso delivery nozzle.
Cause 3- Pump is not working. Open steam/water outlet knob and hear the pump work. If you do not hear any noise from the pump, this may be the main cause.
Cause 4- Flow meter is faulty. This part is like the water meter for homes. It measures the flow of water and signals the electronic board. The malfunctioning flowmeter will not send signals even when water is flowing through it.
Cause 5- Hose is disconnected and water is not flowing in the system.
Cause 6- O-rings at hose connection is leaking, reducing the water flow to be sensed by flowmeter.
Cause 7- Boiler gasket is leaking. Reduces flow of water through the system.
Cause 9- Brew unit is blocked, blocking flow of water through the flowmeter. This also causes pump to slow down and ultimately stop with muffled sound within 15 seconds.
Cause 10- Brew unit not connecting brew valve, preventing flow of water. Same sign under cause 9.
Cause 11- Steam is leaking. Registers reduced flow of water at the flowmeter.
Cause 12- Solenoid valve is blocked or solenoid coil is bad. Same observation as cause 9.
Cause 13- Electronic Control board is bad. Though rare it can happen due to condensed water from leaking steam. When steam is leaking or boiler is leaking, machine should not be used any more to prevent steam shorting the Electronic board.
Some of the above causes can be checked and corrected before seeking technical help. Do not assume anything without physically checking each of the following:
1- Make sure the water tank is full. If the water tank has water level float, make sure the float is in its housing and it floats as water is filled in the tank. If the level float does not rise with the level of water, then replace the float.
2- Water is not leaking from below the tank. The inlet valve is good. If leakage is present, replace the gasket in the water inlet valve.
3- Prime the machine by opening the hot water knob for 20 seconds or pressing the hot water button. Hot water flow shows the boiler is not blocked with minerals and pump is good. The solenoid valve is good.
4- Water & steam flowing normal, check the brew group for blockage. Determine when was the last time brew group was cleaned. Clean the brew group as explained elsewhere on these pages. If the machine has pre-ground function, try making a fake espresso (without coffee). Make regular espresso in other models to make sure that water goes through brew group and espresso is dispensed.
4- If hot water does not flow because the pump is not activated, then pump is bad. Replace pump.
5- Pump starts to work but within few seconds its sound is muffled and finally stop. This indicates there is serious blockage in the water line or the boiler is clogged with mineral deposits. If water is leaking and seen on the counter top, the chances are that water is leaking from hose connections(replace O-rings) or the boiler is leaking from seams (replace boiler).
6- Prime the machine by opening steam outlet for 20 seconds. Steam flow shows that steam boiler / steam outlet is not blocked. If the steam does not flow, then steam boiler or steam passage is blocked. Replace steam boiler or steam valve
7- Check the solenoid valves to make sure that they open & close as the coil is energized. Solenoid valve is located between the pump and boiler. The pump is activated simultaneously as the solenoid valve when espresso selection button is pressed. Some models may have a solenoid valve near the steam valve. In these models, the solenoid valve is activated to allow passage for steam/hot water. If the valve is not functioning, the ventilate sign will appear.
7- Hear the pump work when priming the machine. Louder noise from the pump can be due to
** air-locked water hose, or
** water is not sucked from the tank or the pump is sucking air instead of water or
** the diaphragm inside the pump has lost flexibility and not developing pressure to push water forward
** the hydraulic system is blocked at one or more locations due to mineral sediment. Find the location and cause of the block and correct it.
** Clean the brew unit (see cleaning instructions) and make sure that
a- the ground coffee used is not powdery fine.
b- The dose of coffee grounds is not in excess of 7 G.
c- check if there is . Find the cause and remove it.
8- If steam and hot water flow is normal, but the ventilate sign persists, then the flow meter or the electronic control board is bad. Replace flow meter or the control board, as necessary.
From Gaggiaparts.
Posted on Oct 06, 2008
SOURCE: Machine is leaking
I had this same problem. Water leakage down the inside right side of the machine after 2-3 years, into the drip tray and all over the counter. The problem became worse over time. The steam valve would not completely shut off. Because we rarely used steam to heat or froth, and because the cost of a new unit is so high, as is the cost for repairs, I was able to eliminate the problem by opening up the machine, locating the hard, small inner-diameter, plastic internal steam line (under the cover, top of the machine, right side, leading to the external steam nozzle), and permanently pinching it closed by bending it multiple times and clamping it between some washers and bolts. So now we don't have steam, but at least the expresso maker part still works fine and doesn't leak.
Posted on Dec 22, 2008
SOURCE: saeco wont stop descaling
In service menu there are 2 parameters you should look. First one - descaling - should be on 'done'. The second one is a counter - water used since last descaling - should be on 0.
Posted on Mar 23, 2009
espressonist
  • 1711 Answers
SOURCE: Our 7 year old Saeco Magic Delux has started to
If I understand well the problem is only with tanks valve which means the spring have become more soft and stays a litle open so you have water leak. It maybe because some scale or dirt keep it open some time.
In order to decide if it wise to fix it or not the answer is simple if you have a good coffee result in cup which means that the grinder grinds good, presure pump work good and boiler heat up ok then you will only need to complete descale the machine and replace only small cheap parts and you will have a very good machine again for some more years. Remember a brand new machine will do the same espresso like yours.
Remeber to vote for this answer.
Posted on Feb 25, 2010
Saeco xelsis error code 5
Error 5 on your machine usually means it needs a new pump. The pump may be too weak to do the job.
Always try to descale the machine before doing anything else. If you can't then you will have to take it in for service.
Please visit our service center page.
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
If you need descaler visit this page.
http://www.cerinicoffee.com/espresso-descaler-25/?sort=bestselling
Dec 30, 2013 | Saeco Coffee Makers & Espresso Machines
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
How do i reset my saeco sclass incanto coffee machine
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light. Stopping it when it is out of water will only let it continue on with the descale cycle. The pump must quit on its own.
Oct 26, 2009 | Saeco Incanto Classic Espresso Machine
When i try to brew coffee hot water pouring from under the machine cover and no coffee comes out
Hi
Leaking under the machine usually means 1 of 2 things. You have a ruptured hose or your boiler is leaking. Both are repairable. There are 2 types of boilers in the Saeco machines depending on its age. The newer machines have a stainless coiled tube in an aluminum heater. This would probably be a hose. The older boilers were a 2 piece with a gasket that will leak if not taken care of by descaling on a regular basis and done correctly. No excessive heat when descaling. Turn the machine on, then run descaler through the wand by opening the knob for water. Run 8 nozs through the wand then turn the machine off and let it set. Do this until the descaler is gone. The rinse with a tank of fresh water.
Jul 10, 2009 | Saeco Vienna Espresso Machine
Saeco wont stop descaling, i have yoused 2 cleaing solusion and the mashine just right .. descaling cycle interrupted turn machine off .. wenn you turn machine off and start again then it start descaling...
Jan 16, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Got an old saeco magic comfort 7/8 years old -
bye a good coffee descaler not vinager follow instruction on it normally fill the water tank leave room for the descaler start the machine open side valve leave it running for 15 second turn it off let it site for 10 to 15 minute after open valve for 30 second let it site for 10 minute and open valve repeat untill empty tank after clean water tank very good that descaler is acid nasty stuff after fill the water tank full of water start machine open side valve empty water tank that its good luck pierre p.s it take a while do descale good but worth it
Jan 02, 2009 | Saeco Magic Comfort Plus Espresso Machine
Leak in washing machine
can you tell where the water is hitting the belt from is it in the middle of the wash tub or from the outside of the wash tub please let me know if its from the middle of the tub its probably the seal that keeps the agitator from leaking, and if its from the side the in lines from the water spicket or the valve that controls hot and cold in the machine could be leaking, please look closely and try to see where the wateris dripping down from. thank you, then let me know
Dec 21, 2007 | Washing Machines
Coffee Makers & Espresso Machines Logo
374 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
