Question about Kenmore Dryers
Kenmore Elite Gas Dryer. Cycle wont start
When START button is pressed motor runs but when START button is released motor stops imediately.
    President:
  • 1,489 Answers
This sounds like one of two things in order of most likely:
- the centrifugal switch in the motor is not functioning (burned, stuck, broken)
- or the run winding in the motor is bad
Need more info, let me know...
Posted on May 08, 2009
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
The drum in my kenmore elite he3 wont turn
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
May 08, 2012 | Kenmore Elite HE3 Steam 8674 Dryer
Have a kenmore elite quiet pak ll gas dryer start buton doesn't start. when release the button dryer stops
if the dryer runs when you push the botton in and stops when you stop pushing on the button you have a bad even heat board or a bad motor relay.these parts are located inside the top console,if you send me the model number i can look up your dryer and tell you the part you need to change out
Jul 02, 2010 | Kenmore Dryers
Dryer start button
The motor switch is not switching over. Either the switch is bad or the dryer is not tumbling fast enough to activate it. Eric
Aug 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Press start button and dryshuts off when start button is released
There is a switch assembly on the motor that activates when the motor is running. Centrifugal switch. It keeps it running when you release the switch. That is where to start. Eric
Jun 11, 2009 | Kenmore 74992 Gas Dryer
My Kenmore Elite dryer starts, but stops running when the start button is released. Do you know the possible problem? Any suggested solutions?
it is one of 2 things either the motor switch is not working right or the control board is out check the motor first if you have a multimeter check the centrifugal switch on the motor
Dec 10, 2008 | Kenmore Elite 45986 Front Load Washer
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Dryers Logo
76 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
