Question about Spa Parts Plus CONTACTOR, 120V DOUBLE POLE 50 AMP - DPC50-120
Air control buttons leak water.
Top air control buttons leaking water.
Air control valve leaking water
dis assemble the air control. check the gaskets for any damage or cracks
Feb 24, 2014 | Dream Maker Spas Pool & Spa
Electrolux washer e 13
Water leak in tub or leak in air bell is what the code means if you do not see water leaking and you can not find a air leak in the hose or air bell test the pressure switch if it test fine then replace the control board
Feb 12, 2014 | Electrolux Washing Machines
My Interamtic has a switch for the spa areator but will not work from the spa. It will activate if I short out leads at the controller. Is this a problem with the swithch or is there water or debris in the...
You could have one of several problems.
The air operated switch may be faulty.
There may be an air leak at either end of the pipe linking the switch and the control button or the pipe is kinked or blocked.
It could also be a worn or cracked o-ring in the control button which is not allowing the the control to provide sufficient air pressure to operate the switch.
Check all the pipe fittings for air leaks/restrictions. . If air pressure appears sufficient, then switch should be replaced
Sep 21, 2010 | Intermatic T21004R- Pool-Spa Mechanical...
Water leaks under machine when filling
Hello, if your washer leaks only when filling then you have to check these:
Air-gap device- The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
THE TUBE - There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak
inlet spout- Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tube. If the spout cracks or breaks free of it's mounting, it can cause a leak.
Thanks
Jun 04, 2010 | Danby DWM99W Top Load Washer
Air condition warm air. put in coolant freon but still warm air. water pump replaced. still the same.
If it has climate control, the blended air door module behind the glovebox maybe the problem. It is stuck on the hot side.
May 01, 2010 | 1999 Chevrolet Blazer
Hi,iv got 2002 jaguar s type r last week it started leaking engine cooling liquid from back of engine above gearbox i tried evrything to see where it was coming from but couldnt find out so i assumed it...
yes you got it in one,, its an air lock stoping the water going round the heater, you need to blead the air out rad seal wont block up the heater,,,,iv used it many times,,,my old truck ran with it in for years!
look for a bleed scew on a water pipe and open it with the motor running let water ran out till no air is in it, top up header tank as well
Nov 21, 2009 | 2002 Jaguar S-Type
Water pump cycles to often. When pump turns on, pressure gauge shoots up to 50 lbs right away without pumping much water.
Sounds like a well fed system with a pressure tank that has lost its air charge. Check for a water tank with a tire pressure type stem fitting, should also have a pressure gauge. Most newer tanks have a rubber diaphram inside to keep the air and water from mixing, but a lot of older ones don't and the newer ones will develope a leak that will produce the simpoms you describe. Try adding a few pounds of air pressure to the top of the tank and check for leaks. Warning: Compressed air can escape explosivly if the tank is badly rusted out but if your water pressure goes to 50# without the tank leaking, it should be safe to add up to 25# of air. The air charges the water system and allows the pump to shut off until enough water is used to lower the pressure back to set points on the control switch. It's not a good idea to adjust the set points on the switch unless all parts in the system have been checked for safety to the new pressures.
Aug 13, 2009 | Water Heaters
LEAKING FROM BOTTOM
Is it leaking only when it is filling or all the time? If it is only leaking during fill, it could be an air gap device
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • If it is leaking all the time it could be the main tub seal. Hope this helped.
    Jul 16, 2009 | Roper RAS6233KQ Top Load Washer
    Leaking in back and on sides of machine
    the hose for your water pressure switch it clogged not allowing the air pressure in it to increase to the point that the switch tells your water to shut off at the proper level. Tkake the back loose and follow the clear hose up into the control panel, disconnect from pressure switch and either blow or use small blast of compressed air in this tube t clear the clogg. Powder detergents are famous for clogging this line.
    Apr 06, 2009 | Whirlpool LSR5132PQ Top Load Washer
    Spa Parts Plus CONTACTOR, 120V DOUBLE POLE 50 AMP - DPC50-120 Logo
    24 people viewed this question
    Top Spa Parts Plus Electrical Supplies Experts
    Craig Butler
    Craig Butler
    Steve
    Gene Haynes
    Are you a Spa Parts Plus Electrical Supply Expert? Answer questions, earn points and help others
