Question about Jenn-Air JSD2695KES Side by Side Refrigerator
How can I force defrost a jenn aire refrigerator jsd2695kes
We smelled something "hot" in the kitchen this AM and want to force a defrost to see if we have something bad going on.
    Top Expert:
  • Jenn-Air Master
  • 12,962 Answers
Check manual to see if there is a manual technique for activating the defrost timer cycle. If not, and you are in rush, remove back cover of freezer, and after unplugging unit use hair dryer to melt the ice built up on the evaporator.
Posted on Nov 28, 2013
SOURCE: Jenn-Air Refrigerator
my refrigerator keep warm and freeze work fine, but when i take the back panel off in the freeze the pipes are with a lot of ice on them. Once i defrost the pipes behind the panel it will work for two or three weeks and then its back to the same process. Help me please.
Posted on Dec 31, 2007
SOURCE: Jenn Air JCD2389GTW Refrigerator problem
I just paid a little over $300 to have this fixed and boy do I feel ripped off. The part is available online for about $50 (I was charged $140) and the repair guy was here for about 40 minutes ($120 in labor, $170 before the 30% new customer discount, and $55 to defrost the freezer. Anyway, hopefully you don't get ripped off like I did and now that you've listened to me gripe you can find the solution at the end of this post. If for some reason this site doesn't allow links look up part # PS727531 or Auto Defrost Assembly. You will probably have to defrost your freezer first (which will solve your problem for a month or two). Here's what I learned about defrosting from watching the technician: Get lots of towels, if you have a drapery steamer or carpet steamer with furniture attachment it seems to go by much more quickly then when I used a hair dryer. Anyway, here's the Link. I don't mind paying for the work but I feel totally ripped off. Hopefully, this will help.
http://www.partselect.com/xq/aspx/Inventory.727531/imgID.3/qx/PartDetail.htm?SourceCode=5#RepairStory
Posted on Jun 23, 2008
  • 360 Answers
SOURCE: How do I level a Jenn-Air side by side refrigerator
this manual has leveling instructions in it, to download, click --->here<---
Please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 16, 2009
  • 72 Answers
SOURCE: Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
Posted on Jun 07, 2009
marka19
  • 1430 Answers
SOURCE: We have a built in Jenn Air refrigerator Model #JS48FSDBDA
Remove the kick plate at the bottom, then you will see the head of a bolt this raises and lowers the wheels, I'm assuming your wheels are up turn bolt clockwise. Thier will be a bolt on each side. The wheels are contained inside of a sheetmetal housing. Once the wheels are down you will be able to roll it back and forth. Go to www.appliancehelponline.com enter your model # and it will bring up a diagram of your unit. The diagram needed is the one for the cabinet. Hope this helps.
Posted on Mar 05, 2010
Jenn air JSD2695KES. Freezer is -2. Fridge side 45. Air movement is decent on freezer side Minimal on fridge side.
You may have a defrost problem starting. You can also clean your condensor coils if the are dirty it will affect the refrigerator temps sometimes.
Jul 24, 2015 | Refrigerators
Excessive condensation inside.
check the door seal is sealing properly and if the seal is broken,if the seal is broken it will have to be replaced
Sep 04, 2012 | Jenn-Air JSD2695KES Side by Side...
My Jenn-Air JSD2695kes. The refrigerator side is not cooling.
You most likely have a defrost cycle problem. Either a bad defrost heater, timer or thermostat. Jenn Air has put an Adaptive Defrost circut in the top of the Refrigerator section. You can find troubleshooting directions at ACMEHowTo.com
Jun 03, 2010 | Jenn-Air JSD2695KES Side by Side...
Fridge and freezer not cooling
clean conderser coils and make sure both fans are going ( the one in the freezer and the one by the compressor . . if this does not help there is a small and a large line common out of the compressor . the dmall one should be hot and other ( larger one ) cool . if not heat in small oine it;s low on freon . and may need recharge .. **** hope this helped mm feed back pls ..
Jan 16, 2010 | Jenn-Air JSD2695KES Side by Side...
I have installed the main control board, I need to reset the frig
if you will pull the kick panel off of the front of the refrig and feel under the frig you will find a plastic envvelope with a tech sheet that gives step by step instructions for setting the cntrl board. thx peyton
Mar 26, 2009 | Jenn-Air JSD2695KES Side by Side...
Jenn-Air JSD2695KES Side by Side Refrigerator Logo
110 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
