Question about Samsung Ml-2165 Mono Laser Printer
Crumple printout The paper is crumpled in the lower part of the paper.
  • Nene Nepo
    Nene Nepo Nov 26, 2013
    my printer is 4 months old...
  • Nene Nepo
    who can help me in solving the problem of my printer crumpled printout?
2 Suggested Answers
  • 10 Answers
SOURCE: samsung 1340 crumpling copies as they print
how old is your printer if it is too old maybe you need to change the fusing unit
Posted on Oct 22, 2009
Second copy is crumpled
You need to isolated a problem.Verify the vertical conveyance feed and clean the feed rollers,verify the fusing unit and a duplex unit,and verify the exit unit.Stop the copy process before the paper enter in the fusing unit,and verify if the paper is crumpled or not.If is crumpled verify the paper tray rollers(casette feed rollers,vertical transport rollers).If not crumpled stop the proces after a half copy is out on the fusing unit.If crumpled change or clean the upper and lower fuser roller and the lower roller cleaning roller(aluminium roller)in the fusing unit.
Dec 14, 2013 | Ricoh Aficio 2015 Black Toner Cartridge...
Maybe you have problems with the upper fuser roller, open the back door and try to see the upper fuser roller and lower pressure roller if you see any wrinkles or damage in any of the rollers that's is the problem, you can replace them just the upper fuser roller and the lower pressure roller but it will need advanced skills, the other option is change all fuser assembly but at higher price
Nov 26, 2013 | Brother HL-5250dnt Laser Printer
Crumpled paper
A bit more information is need ie model number and a description of where the paper us crumpling most crumpling problem are due to a foreign object like a paper clip stuck in the paper path
Nov 02, 2013 | Kyocera Office Equipment & Supplies
Canon IP1880-Paper jam
after you get all the crumples out
wipe down the rollers with alcohol to clean them and wait about 5 to 10 minutes before trying to print
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Office Equipment & Supplies
Paper feed problem-wont go through- crumpling up as it tries to go through
You probably have a piece of paper stuck at the place where it's crumpling. Take a good look and carefully extract it. It may be small, so look hard.
May 01, 2009 | Office Equipment & Supplies
CLP 300 crumpling lower right hand side of paper
There is a foreign object in the paper feed path. It could be anything from a paper clip or staple through to an insect (or worse). It will definitely be on the side where the crumpling occurs. Try feeding a strip of card or thin flexible plastic backwards through the feed mechanism. A laminated sheet of paper can also be effective for this.
Nov 18, 2017 | Samsung CLP 300 Laser Printer
Drum is blinking
I found that buying good name brand paper solves the crumpling problem. Mine was doing the same thing and I was buying generic paper. I have switched to name brand and it has been working fine ever since.
May 17, 2008 | Brother HL 5250DN Laser Printer
Paper jam
If it is getting crumpled in the tray, there is something blocking the paper path.
What I would suggest is taking out the toner and drum cartridge, then remove the paper tray. Tip the machine on it's back and look into the paper feed area for something blocking the paper path.
When it is crumpling the paper like that, the feeder is working fine, just something blocking the paper path.
You can take a minela folder, and gently push it through the paper path to dislodge the obstruction.
Mar 31, 2008 | Sharp AL 1631 Copier
HP PSC1410 All in one
crumpled papers are due to something stuck inside, or the rollers are dirty, causing a misfeed
new print drivers are sometimes needed after fixya this sort of issue. get em here
Mar 23, 2008 | Office Equipment & Supplies
Crumpled paper comes out of copy machine
Firstly make sure that in the cassette the paper tray guides are fully against the paper as if they are not the paper will wiggle through the machine and cause your fault. If this doesn't work then check the paper path as there maybe a small piece of paper causing it to shift and turn causing the crumple. Also check the fuser and the little plastic stripper fins as they may have dried toner on them causing the fault.
Hope this helps you
Thanks J
Jan 08, 2008 | Office Equipment & Supplies
Samsung Ml-2165 Mono Laser Printer Logo
85 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
