After water spillage system is not able to boot completely its getting hanged in between, tried to boot through net, usb cdrom the same result , pl help
I had a water spillage on my netbook acer one , now after drying it the system is booting , but the windows is hanging up in between, i tried to boot through net, usb cd rom etc but its not responding the same thing happens windows runs and hangs up in between. pl help
  • Peter Steiert
    Peter Steiert May 11, 2010
    Do you have another laptop hard drive to attempt to boot off of with this system? Possibly the hard-drive took some damage from the water and can't read the binary correctly anymore.
    Sergeant:
    Champion:
  • 225 Answers
Good morning! Possible that some internal part/s of your Acer One computer might be damaged, I suggest to bring it to an Authorized Acer Service Center for proper hardware parts check-up & repair. best regards
Posted on May 08, 2009
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
When I turn on my acer aspire one d250 it says Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
6. USB CDROM
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery which will erase all user data and restore the operating system to its factory default when you purchased the netbook.
Jan 03, 2011 | Acer Aspire One D250 (99802378332) Netbook
Can I boot my e-machine M6810 from a usb cdrom drive? My build in cdrom fell apart and my usb cdrom works when the computer is on, but I can't seem to boot from the new cdrom I have tried changing the...
in short - yes! any e-machine, or indeed any computer build in last 5 years can be boot-up from usb port.
you need to enter bios and setu-up as first boot-up device "other", "boot from another devices", i do not remember which one is actually in this particular bios
plug in your external usb cd-rom, or indeed bootable usb-memory or bootable hdd and they should boot and work as they are on the computer.
another issue, internal cd-rom cannot be really disabled as only mechanical, external part stop working, it' logic part is still there and cmoputer therefore "see" it. you can disable it by downloading newest bios which have bit more power and tweaks than old one.
Jul 26, 2010 | E-Machines M6810 Notebook
My System is affected by virus.when i format the total hard drive still it can run within some days.how 2 remove this virus manually or help 2 format the drive using any bootable software...plz...
I suggest booting from a bootable cdrom disk, instead of a floppy disk, USB drive, etc. Everything except the cdrom can quite easily become infected with a virus just by plugging it into the computer. You MUST create the bootable cdrom from a KNOWN clean computer! If you try to create one from the infected system, you can almost be assured you will only create an infected cdrom!
If you don't have a way of creating a bootable cdrom, try booting your system from your Windows installation cd / dvd. Do a complete format before the install and then SHUT DOWN the computer! Do NOT just reboot and continue with the installation of the OS. Viruses are "memory resident" in that they load themselves up into RAM when the computer boots and will remain there until the machine does a complete shut down. I recommend you shutdown (i.e., turn off the computer) and restart the machine a couple of times AFTER doing the format to be assured that the virus is eradicated.
Once you are satisfied the virus no longer exists, you can go ahead with a new install of the OS. The FIRST thing to do before loading ANY of your personal files back onto the computer is to install a virus scanning software -- and make sure it is active and the virus pattern files are current. After scanning the hard drive for problems and finding none, can you go ahead with the installation / restore of your personal files.
Chances are pretty good that the reason the computer runs OK for a couple of days and then the virus reappears is that a file you have installed or copied over from your backup is infected. Each time you launch the program / file, the virus gets installed and the cycle starts again.
Jan 23, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Lifebook P1510 not booting from recovery CD off external CDROM dr
you'll have to use a password recovery tool for windows.
Try www.password-changer.com and http://home.eunet.no/pnordahl/ntpasswd/.
Oct 30, 2009 | Fujitsu LifeBook P1510 Tablet PC
If i enable the USB drive in CMOS.after booting the system is hanged.only mother board name mercury is shown.
The problem is with the Installed USB Devices. Check whether you are using any of the USB slots in your system. If any printers or any other USB devices are installed the boot will check with these devices, so your system is getting hanged. Try to disable the USB booting or else remove the usb device and then boot. This will resolve your problem.
Oct 19, 2009 | Mercury P4VM800M7 Motherboard
Trying to get cd to boot from bios
just may the CDROM the top priority, then it may ask you to restart the computer, just let it restart then put the CD in.
Aug 04, 2008 | Computers & Internet
Gigabyte Slot 1 GA-6BXC Start Up UnStable
I recommend that you formatt your HDD to a FAT32 system probably by using another pc then you should also ensure that your bios is setup for the appropriate operating system. maybe just download the appropriate bios files off the gigabyte web site.
May 27, 2008 | Gigabyte Slot 1 GA-6BXC Motherboard
Installing XP on a dell computer
try to go to bios and load bios defaults, esc then save and exit. boot from the cdrom by, tapping on F12 at dell screen. at boot menu screen, choose cdrom, press enter, when you see the message, PRESS ANY KEY T5O BOOT TO CDROM, hit any immediately, that should allow you to install xp directly from the cdrom.
Feb 13, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
David Payne
David Payne
