Question about Brother HL-5250dnt Laser Printer
The paper is crumpled in the lower part of the paper.
Crumpled paper at the lower place of the printout
    Problem Solver:
  • 17 Answers
Maybe you have problems with the upper fuser roller, open the back door and try to see the upper fuser roller and lower pressure roller if you see any wrinkles or damage in any of the rollers that's is the problem, you can replace them just the upper fuser roller and the lower pressure roller but it will need advanced skills, the other option is change all fuser assembly but at higher price
Posted on Dec 02, 2013
Second copy is crumpled
You need to isolated a problem.Verify the vertical conveyance feed and clean the feed rollers,verify the fusing unit and a duplex unit,and verify the exit unit.Stop the copy process before the paper enter in the fusing unit,and verify if the paper is crumpled or not.If is crumpled verify the paper tray rollers(casette feed rollers,vertical transport rollers).If not crumpled stop the proces after a half copy is out on the fusing unit.If crumpled change or clean the upper and lower fuser roller and the lower roller cleaning roller(aluminium roller)in the fusing unit.
Dec 14, 2013 | Ricoh Aficio 2015 Black Toner Cartridge...
Crumpled paper
A bit more information is need ie model number and a description of where the paper us crumpling most crumpling problem are due to a foreign object like a paper clip stuck in the paper path
Nov 02, 2013 | Kyocera Office Equipment & Supplies
Document comes out crumpled
Paper is not feeding through your printer properly.
First thing you should do is to remove the paper from your paper tray. After removing, place the paper back in the tray, making sure it sits evenly within the tray. There should be no part of that is higher than any other.
Next, carefully close the paper tray, making sure that no part of the paper catches when closing. Do this by feel. If you feel any resistance when sliding the tray shut, pull the tray open and try again.
If this does not solve the problem, open the printer doors and take a look inside the printer. There might be something small impeding the paper's smooth movement through your printer.
Finally, take a few seconds to clean the paper pulls (the little rubber wheels you see inside your printer). If these are dirty, the paper will not be pulled through the printer in an even way. It could pull off track causing one of the sides of the paper to rub against the printer. This is what causes the crumpling. To clean the paper pulls, just use a damp cloth and gently wipe them. Good luck!
Mar 25, 2010 | HP LaserJet 4050 Printer
Canon IR 2870 A3 printout tail crumpled
Hello sir; When you print A-3 size paper did you set up on computer for a-3 size paper, most case A-3 size use in europe, usa use letter size. I hope that's the problem,
Jan 29, 2010 | Canon Office Equipment & Supplies
Paper feed problem-wont go through- crumpling up as it tries to go through
You probably have a piece of paper stuck at the place where it's crumpling. Take a good look and carefully extract it. It may be small, so look hard.
May 01, 2009 | Office Equipment & Supplies
Drum is blinking
I found that buying good name brand paper solves the crumpling problem. Mine was doing the same thing and I was buying generic paper. I have switched to name brand and it has been working fine ever since.
May 17, 2008 | Brother HL 5250DN Laser Printer
Paper jam
If it is getting crumpled in the tray, there is something blocking the paper path.
What I would suggest is taking out the toner and drum cartridge, then remove the paper tray. Tip the machine on it's back and look into the paper feed area for something blocking the paper path.
When it is crumpling the paper like that, the feeder is working fine, just something blocking the paper path.
You can take a minela folder, and gently push it through the paper path to dislodge the obstruction.
Mar 31, 2008 | Sharp AL 1631 Copier
HP PSC1410 All in one
crumpled papers are due to something stuck inside, or the rollers are dirty, causing a misfeed
new print drivers are sometimes needed after fixya this sort of issue. get em here
Mar 23, 2008 | Office Equipment & Supplies
Crumpled paper comes out of copy machine
Firstly make sure that in the cassette the paper tray guides are fully against the paper as if they are not the paper will wiggle through the machine and cause your fault. If this doesn't work then check the paper path as there maybe a small piece of paper causing it to shift and turn causing the crumple. Also check the fuser and the little plastic stripper fins as they may have dried toner on them causing the fault.
Hope this helps you
Thanks J
Jan 08, 2008 | Office Equipment & Supplies
Crumpled pages
Damp paper is a common cause (concerina in fuser assy) as is lower heat roller being wrinkled (orange roller in rear)
Dec 31, 2007 | Brother HL-2040 Laser Printer
Brother HL-5250dnt Laser Printer Logo
106 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
