Question about KitchenAid KUDE70FXSS Builtin Dishwasher
Door handle/bar on kitchenaid dishwasher is loose
The external door handle/bar on my KitchenAid dishwasher has come loose on one side. I can put it back over the post, but it appears that the "post" needs to be turned to keep the handle on. How do I tighten it?
3 Suggested Answers
SOURCE: Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Posted on Nov 02, 2008
SOURCE: Loose Door Handle
door tension
Posted on Nov 22, 2008
My Dishwasher door won't latch?
Its probably loose. pull the unit out and tighten it or fix any broken parts.
Aug 19, 2014 | KitchenAid KUDK03ITWH Full Console...
Kitchenaid dishwasher KUDS30IXBL door locked open, will not close
There should be a type of hook inside the hole where the door latches to the machine. Hold the handle up and rotate the hook latch so the open side is pointing towards the machine. The click you heard was the latch that holds the door closed moving to the closed position when the door was open, and it needs to be in the release position.
Jan 28, 2013 | KitchenAid KUDS30IXBL Builtin Dishwasher
How do you open door when handle is broken? The handle is loose, not attached.
That the handle out by gently pulling one side out, then take vise grips and pull the little wire that attaches to the handle.
Jun 12, 2011 | KitchenAid KUDI24SE Built-in Dishwasher
Kitchenaid dishwasher KUDR24SE...cannot open door
did anyone have a solution? i have the same problem.
May 16, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
Nov 02, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Handle loose on Refrigerator
I have same problem. Just called KitchenAid and they told me I needed a T-20 torque key - you can buy it from them or at a hardware store. Good luck.
Jun 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Door handle will not engage with latch to open door.
yea but the trick is the latch acces is behind console not the front panel, you need to unistall the d/w slightly to remove strike plate holding broken latch closed, door needs to be opened to gain access to console screws
Feb 22, 2008 | Dishwashers
KitchenAid KUDE70FXSS Builtin Dishwasher Logo
32 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
