Question about Activision Cabelas Big Game Hunter 2012 - Complete package - 1 user - PlayStation 3 76570
Controller Cannot get past "Please reconnect wireless controller 1 to continue" message. I have reconnected many times, but to no help. I have sixaxis controller. It dosn't say Dualshock 3 on the controller but that can't be nessecary?
Please reconnect controller 1 to continue for cabelas dangerous hunts 2011 on ps3. What does this mean
This means that the system wants you to reconnect the first player controller, usually in the 1 slot. It will do this if it thinks the controller is missing. I get this frequently on my xbox when the controller runs out of batteries.
Make sure the controller is plugged in all the way, charged and working properly!
Alternatively, you can power down the PlayStation and start it back up again.
Regards,
G33k
May 06, 2011 | Activision Video Game Consoles & Games
I have an older Lutron system - the Maestro Wireless MRF-VCTX-WH. I can't find instructions to reconnect one dimmer. The only instructions online that I can find are for the Pico, and that process doesn't...
Hard a hard time finding it too. Found an old instruction sheet lying around:
Step 1) Turn the Dimmer On
Step 2a) Press & hold the Dimmer's tap button. LEDs will blink one at a time, from the bottom up to the top. After approximately 8-seconds, the LEDs will start to cylce slowly from top to bottom (setup mode). CONTINUE to hold the tap button and go to step 2b.
Step 2b) Press and hold the "ON" button on the Wireless Controller (MRF-VCTX).
Step 2c) Once the dimmer learns the wireless controller, the LEDs on the dimmer will cycle quickly from top to bottom. Release the dimmer's tap button to exit set-up mode, and release the wireless controller's on button.
Repeat steps 1-2c for each additional dimmer.
Apr 24, 2011 | Lutron MRF-VCTX-WH Maestro Wireless White...
JUst bought PS3cabelas dangerous hunt 2011-followed all instructions but cant get game going prompt keeps coming up saying reconnect wireless controller 1 to continue-what does that mean?
Sounds like your controller is not properly connected. Before turning your ps3 on, plug the controller in with the usb cable and then turn it on. If it does not automatically connect press the center button.
Feb 06, 2011 | Video Game Consoles & Games
Controller will not stay connected. continuously stops game and says "please reconnect controller
How to connect a wireless controller
  1. Press and hold the Guide button on the controller until the controller and the console turn on.Press and release the connect button on the console.Within 20 seconds, press and release the connect button on the controller.When the lights surrounding the power button on the console stop flashing, the controller is connected.
    • If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
Dec 28, 2010 | Microsoft Xbox 360 Wireless Controller
Xbox 360 controller not working, all 4 lights are blinking.
The wired and wireless controllers can be actively connected to an Xbox 360 console all at one time. Each connected controller is assigned a quadrant on the Ring of Light. Before you can connect a wireless controller, at least one quadrant must be free and will be unlit.
Connecting an Xbox 360 Wireless Controller to an Xbox 360 Console is called Connecting. To connect a controller to a console:
First, Press and hold down the Guide Button on the wireless controller until it turns on.
Second, Press and release the power button to turn the console on.
Third, Press and release the connect button on the console.
Fourth, Press and release the connect button on the controller.
Fifth, After the ring of light on the controller and console spin and flash once, the controller is connected. The quadrant that remains lit indicates the controller's position.
Four Green lights on the controller's Ring of Light flash continuously
The Please Reconnect Controller message appears on the monitor
There is interference and the controller does not respond properly
Step 1: Ensure that either the AA batteries are new or the Xbox 360 Rechargeable Battery Pack has a full charge.
Step 2: Ensure that you have performed the proper procedure to connect the Xbox 360 Wireless Controller to the console.
Step 3: If still experiencing issues, ensure there is a clear line of sight between the front of the console and the wireless controller. If there are any obstructions, especially metal objects, remove them.
Step 4: 2.4 gigahertz cordless telephones, microwave ovens, and Bluetooth headsets for cell phones can interfere with the operation of the wireless controller. Turn off or unplug those devices and then try to connect the wireless controller to the console again.
Step 5: If these steps did not resolve the issue, the wireless controller may need to be replaced.
Jun 06, 2010 | Microsoft Xbox 360 Controller
My controller just shows all four lights flashing and when i try to sync it, the lights just keep spinning round and does'nt connect
Jun 03, 2010 | Microsoft Xbox 360 Controller
PS3 Controller will only work when plugged into the USB
I picked up the folling troubleshooting tips from the PlayStation Knowledge Center. I know it may seem silly or insulting; This is not my intention. Problems like this are usually just little things you're over-looking. Give thest tips a shot, one by one, and see if your solution is in here. If it isn't, message me back here & we'll try something else to get your controller working, ok? By the way... Is it a sixaxis controller or dualshock?
  • Verify if the SIXAXIS or DUALSHOCK 3 wireless controller works with the USB cable.
  • Verify that the SIXAXIS or DUALSHOCK 3 wireless controller's battery is charged.
  • Attempt to pair the SIXAXIS or DUALSHOCK 3 wireless controller to another PLAYSTATION 3 system. This helps determine whether the problem is with the system or the controller.
  • Attempt to connect another SIXAXIS or DUALSHOCK 3 wireless controller to the PLAYSTATION 3.
  • Move closer to the PLAYSTATION 3 system. The maximum range for Bluetooth is 30 feet.
  • Make sure you have less than seven Bluetooth peripherals paired with the PLAYSTATION 3.
  • Unplug any other USB device plugged into the system when pairing the SIXAXIS or DUALSHOCK 3 wireless controller.
May 19, 2009 | Sony Playstation 3 (PS3) Console
Playstaion 2
Hey sml625,
According to information provided by the manufacturer, the Sixaxis controller is unfortunately not compatible with the Playstation 2 and is only supported on the Playstation 3 console.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 31, 2008 | Video Game Consoles & Games
Controller/Memory Card
my recommendation is to return the unit, but there is a popular way that does in fact work. I tried it and my xbox lasted 4 week longer. Basically, wrap it in 2 towels, turn it on and leave it for 30 mins, come back , unwrap and reboot xbox.
Mar 01, 2008 | Microsoft Xbox 360 Console
XBOX PROBLEM
I have had the same problem in the past. The problem with mine was the controller wires were loose from being wrapped tightly around the controller while not in use. Try pugging in a new controller or one you know does not have issues. Good luck.
Jun 30, 2007 | Microsoft Xbox Console
Activision Cabelas Big Game Hunter 2012 - Complete package - 1 user - PlayStation 3 76570 Logo
47 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
James Wishart
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
