Question about Amana ABB1927DE Bottom Freezer Refrigerator
Amana Arb1914cw Bottom Freezer - Amana ABB1927DE Bottom Freezer Refrigerator
Benimur
  • 6966 Answers
SOURCE: ARB1914CW AMANA REFRIGERATOR. FREEZER
Please check the fan that blows cold air from the freezer through the vents toward the refrigerator section. Open the door, press on the door switch, wait for a minute or more, the fan should kick in. If not defective, corroded or frozen.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 23, 2008
SOURCE: my amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Posted on Jan 15, 2009
  • 20 Answers
SOURCE: amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
Posted on Jun 04, 2009
heatman101
  • 43501 Answers
SOURCE: i have an amana bottom freezer --where is the reset button
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 02, 2010
heatman101
  • 43501 Answers
SOURCE: Amana freezer on bottom working fine, but refrigerator not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
My amana fridge model number Arb1914cw isn't cooling but the freezer is working
ur defrost terminator is bad and is not going into defrost cycle? and this will stop the fan from circulating the cold air. the heat is only suppose to last up to 20-30 minutes then back into defrost mode? if the defrost timer is bad heres a trick u can use that may get u back into defrost mode, locate the defrost timer in ur fridge usually at top center. then under the timer u will see a tiny slot or hole. if u stick a small screw driver into that hole and turn slowly clockwise till u hear it click? i, it will now go into defrost and u should hear the fan and the compressor go off , hope this helps let me knoiw if u have any more questions, lastly I suspect its not ur timer but ur defrost terminator> meaning is will not allow it to go into heat defrost. its easy and relatively inexpensive.
Amana refrigerator model #ARB1914CW fan quit running. quit cooling
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 07, 2011 | Amana Refrigerators
Were is the defrost timer located on an amana model ARB1914CW refridgerator
Hi.
The defrost control is located between the two lights on the ceiling of the fresh food section. If you use a mirror you'll see the timer shaft through the access hole.
Hope that helps.
fil
Mar 06, 2011 | Amana Refrigerators
Amana abb2224des with Bottom freezer. Just
the least you remove the better.use vacuum cleaner hose to collect s..t (dust) easier than wet cloth.
Feb 11, 2010 | Amana ABB2224DES Stainless Steel Bottom...
Amana bottom freezer not working on model abb2524deq
I replaced the solenoid and my ice machine starting working again.
May 02, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Mar 16, 2009 | Amana ABB1927DE Bottom Freezer...
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
My amana bottom freezer won't cool both the fridge and freezer are warm
Nov 04, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Bottom Freezer control knob
http://amana.com
go here and scroll to the bottom of the page and click on "sitemap"
and you will find help information.
Mar 17, 2008 | Amana ARB8057CSL Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
20 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
