Question about Amana ABB1927DE Bottom Freezer Refrigerator
Amana Arb1914cw Bottom Freezer no drain - Amana ABB1927DE Bottom Freezer Refrigerator
Benimur
  • 6966 Answers
SOURCE: ARB1914CW AMANA REFRIGERATOR. FREEZER
Please check the fan that blows cold air from the freezer through the vents toward the refrigerator section. Open the door, press on the door switch, wait for a minute or more, the fan should kick in. If not defective, corroded or frozen.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 23, 2008
SOURCE: my amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Posted on Jan 15, 2009
  • 20 Answers
SOURCE: amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
Posted on Jun 04, 2009
heatman101
  • 43501 Answers
SOURCE: Amana freezer on bottom working fine, but refrigerator not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
heatman101
  • 43501 Answers
SOURCE: Amana refrigerator model #ARB1914CW fan
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 07, 2011
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
Buildup of ice on bottom of freezer compartment. Ice then melts and leaks out the bottom
sounds like you have a stopped up drain line where water drains out when freezer is in defrost mode. My Amana freezer does it quiet often.
Jul 15, 2012 | Amana ABB2224WES Refrigeration :...
Bottom freezer is all full of ice, what can I do?
The defrost drain is clogged. The defrost water is puddling up in the bottom of the freezer.
Thaw her out and remove the service panel. Unclog the drain. I use a hair dryer and a shop vac.
Amana bottom mount service manual
Aug 22, 2011 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Upper unit freezes up even tho both top and bottom are turned down. only does it occasionally
Its the defrost problem. The drain hole is clogged and water freezes in the unit instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/amana-abb1927de-bottom-freezer-upper.html --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Amana ABB1927DE Bottom Freezer...
Amana refrigerator model #ARB1914CW fan quit running. quit cooling
heatman101
Apr 07, 2011 | Amana Refrigerators
Where is the drain located in the amana refrigerator that empties the water into the bottom drain pan? ModelTC20E-L Amana frigerator
Good day,
In the freezer compartment, after you remove the rear panel, you will see the cooling (evaporator) coil. There is an aluminum pan directly below the coil. The drain hole would be obvious unless it is iced over, in which case you would need to melt the ice out.
It is connected to the drain hose which you can see by removing the back bottom cover of the machine that houses the compressor. If open and working properly, the hose carries the water to the drain pan which allowsit to evaporate.
If the freezer has an ice maker, it will have to be removed first. In addition any support brackets if they prevent the removal of the rear panel.
Jul 26, 2010 | Amana ARB8057CSL Bottom Freezer...
Amana Freezer DeepFreeze AFU2067BW 19.6 Cu. Ft. ice in bottom
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Feb 20, 2010 | Amana Freezer DeepFreeze AFU2067BW 19.6...
Water in bottom of freezer
most likely you have a plugged drain. pull panel in freezer if ice in drain pan then drain is plugged melt with hair dryer
Jan 03, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
My Amana ABB2257CS bottom freezer leaked water
your freezer cabinet need to get all out also the ice machine,and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday .com good luck
Jun 29, 2009 | Amana ABB1927DE Bottom Freezer...
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
19 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
