Question about Siemens Gigaset 8825 Cordless Phone
Beeping Handsets I have continually had a problem since day one of owning this system where the phones beep while sitting in the charging cradles.  We try to reposition them in the stand/cradle without success.  I have purchased new rechargable batteries but the problem continues.  Any solutions?
Mine have done that as well.
After cleaning the contacts on both the handheld unit and the base itself, it seems to stop the problem. Try using a qtip that is wet with water or alcohol.
Posted on Oct 16, 2007
The phone says charge but it keeps beeping
five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 27, 2011 | Vtech 5.8GHz Expandable Cordless Phone...
When the Talk button is depressed on one of our two handsets the screen reads: "No link to base. Move closer to base and try again." The other handsets performs as it always has.
Hi Jim.
About the problem with the answer received, you should write to They usually reply within next working day.
About the system, if you have not sent the system for repair yet, you should do a full system power reset. This is done performing the following, simply disconnecting the power adapter won't be enough:
  • Disconnect all power adapter cables from wallsockets.
  • Remove all handsets from cradles.
  • Remove all battery from cradles.
  • Fit back the batteries in their handsets.
  • Place back handsets in their cradles.
  • Connect power cables.
The procedure above will reset the system and will re-sync handsets to cradles. If that does not work, then some of the units in the system is defective.
I wanted to remind that the feedback given to the expert does not afftect refund procedure, and do not affect your status. In some case I get negative feedback while trying to help dissatisfied
askers in troubles with Fixya service. That is not really nice and pleasant. :)
All the best.
Jan 10, 2011 | Panasonic GigaRange KX-TG5240M Cordless...
Philips Dect 215 phone continually bleeping.
Remove all handset batteries and leave for 10 minutes.
Unplug main cradle and reconnect after 30 Seconds.
Replace all handset batteries and place handsets back on cradles.
Oct 06, 2009 | Philips Lands Phones
My unit started beeping continually, I changed batteries, but
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
The woman was very friendly. Great customer support!
Aug 29, 2009 | Kwikset 907 907-L03 Lifetime Polished...
Charging Black and Decker Simple Start
First plug the charge adapter into an outlet, then plug into the unit. Push the power button to turn the unit on. Now, push the button for the light. The light should come on. At this point you hit the charge button and the green light should start blinking and there will no beeping. Then turn off the light. The green light should continue to blink and the unit will charge. This worked for me, hope it helps!
Jan 19, 2009 | Black & Decker Simple Start Car to Car...
Keeps beeping when recharging
It sounds like you need a new battery (this is what the beeping is) even though its only a year old the battery needs replaced!
Please rate my answer and help keep this site FREE!
Thank You!
Dec 28, 2008 | Black & Decker Simple Start Car to Car...
No dialling tone - just a beeping sound
It sounds like the handset is not 'registered' to the base station/cradle. Solution may be in the user handbook, which you should be able to download at :
Jun 23, 2008 | NTL VS1500 Cordless Phone
Siemens Gigaset 8825 Cordless Phone Logo
456 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
