Question about Intermatic Inc. ST01C Digital In-Wall Timer
Looking for a wiring diagram and how to set an Ellies Power Timer
Ellies timer similar to Toptronic
gotgeek2
  • 565 Answers
SOURCE: clock doesn't work
The wiring diagram for that timer is somewhat misleading. The 120 volt clock timer motor is connected internally to the "A" (neutral) terminal and the #3 terminal. The "A" (neutral) terminal is to the immediate left of the #1 terminal.
Here's how to do the wiring for your use, (assuming a 120 volt supply circuit and a 120 volt lighting or other load):
Connect the incoming power (line) black wire to terminal # 3. Connect the incoming (neutral) white wire to terminal "A".
Connect the outgoing (load) black wire to terminal # 4.
Connect the outgoing (neutral) white wire to terminal "A".
Posted on Mar 08, 2009
john224
  • 1378 Answers
SOURCE: Bought an Intermatic T104 Timer for a 120v pool
T104 series intermatic timers are 208/230/277 volt clocks, not 120. I believe you have the wrong model and need a T101 series instead.
Posted on Jun 13, 2009
  • 3600 Answers
SOURCE: timer won't turn off or on by itself
Pull the pin up wait and see if it comes on you will know then. Most do pull up but there are a few that have the pin that has to be shoved in. 90% however do have to be pulled up to set the timer for off and on.
Posted on Oct 02, 2009
Testimonial: "The problem was trying to decide if the pins up or down turned it on and off. I think I have it figured out now. UP (i think) makes it turn off & on."
SOURCE: Utilitech 192773 timer is DOA
90%m chance you have the two black wires reversed - can't hurt to try to reverse them
Posted on May 24, 2010
  • 56 Answers
SOURCE: i want to wire a photocell to overide my T101
You need to come off the line side of the clock to feed your photocell. And then from the load side of the photocell you can feed to the load side of the time clock. Leave the time clock wired the way it is now. What this will do is feed the light with the photocell or the time clock, but keep in mind by doing this the light will always remain on when it is dark. There is no other way to do it.
Posted on Sep 30, 2010
How do i program my toptronic tddgt digital timer
Toptronic timer appears to be din-rail mounted electronic timer:
Copy following link for timer manual
http://waterheatertimer.org/pdf/Toptronic-timer-manual.pdf
Jun 01, 2012 | Hardware & Accessories
We have a 1EGD1 dayton timer delay relay what is the wiring diagram
Open following link to identify timer:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1EGD1&op=search&Ntt=1EGD1&N=0&sst=subset
This is typical 8 pin delay timer relay.
The wiring diagram appears on side of the timer.
Open following link for example how to wire 8-pin timer.
http://waterheatertimer.org/images/Connect-relay-to-timer.jpg
Example shows 24Volt, but 120Volt wires exactly the same.
The timer is 120Volts. So connect power to terminals 2 and 7.
Other terminals are dry, and receive no power when 120V is connected to 2 and 7.
In the example wiring, the objective is to have power connected to Load at all times except when timer activates. So power is connected to terminal 1 and Load wire is connected to terminal 6.
If the objective was to have power connected to Load only when timer turns ON, then connect power to terminal 1 and connect Load wire to terminal 3.
Read how to wire timer:
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#pin
Oct 07, 2011 | Amperite Dayton Solid State Timer On Delay...
Wiring diagram sunsmart. I am replaceing a timer swithch of a differnt brand. I have a single pole installation, but the power enters the fixture and then comes to the switch. The diagram in the box...
Sounds like you have the GE sunsmart timer, and are wiring the timer for single-pole.
Following information does not apply to 3-way timer wiring.
Add a comment if you have different timer.
Start with previous timer:
The previous timer was connected to two wires: Hot wire and Load wire.
Hot wire carries power from circuit breaker.
Load wire connects to fan,light, or motor.
How to wire Sunsmart:
1) Only one wire in the electrical box is Hot. That wire is usually black. Connect black Hot wire to timer-black wire.
2) Load wire connects to timer-blue wire.
3) Timer-red wire is capped off for single-pole wiring.
4) Timer-green wire connects to bare copper wire.
5) Timer-white wire connects to Neutral wire. This will power the timer electronics. The previous timer probably had a battery to power timer electronics. Neutral wires are white wires that are twisted together and covered with wire nut and pushed to back of box.
6) If box does not have Neutral wires, then connect timer-white wire to bare copper ground wire until neutral wire can be run from any nearby outlet box.
7) Try the timer, and if timer does not work, then reverse timer-blue and timer-black.
Resources:
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 01, 2011 | Hardware & Accessories
How do I set in Automatic mode, seems to only work manually since loss of power?
1) Power outage is major cause of timer failure. Power surge occurs when power is restored, and electronics are susceptible to surge. This includes water softerer, treadmill, electronic water heater, timers, etc.
Timers should be unplugged when power goes off.
Of all timers on market today, only one instruction manual says to unplug timer with power loss. However many people write fixya saying their timer, and electronic water heater control etc stopped functioning after power loss. Probably other products have same problem, but I work with timers and water heaters and see only that slice of the world.
2) Question posted under Woods 59377.
Several timers look identical or similar.
59377 timer has non-replaceable rechargeable battery, some similar timers have AA battery.
If timer has battery, change battery.
Then reset timer to restore functionality. Press reset button for a few seconds with paper clip.
3) If timer function does not restore after reset, then timer is bad.
Buy similar timer at Lowes or Target, and return defective timer in new package.
4) If function is restored, then re-program timer
Open following link for timer instructions showing how to reset timer and re-program timer:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Sep 09, 2011 | Woods Industries 59377 Indoor Digital...
Timer programing intructions
Question posted under Intermatic ST01C timer.
Open following link for ez programming steps, including battery information and wiring diagrams:
http://waterheatertimer.org/ST01C-program.html
If you have different timer, links to most timers appear at bottom of page.
For example, the Utilitec timer looks very similar to ST01C
Aug 23, 2011 | Intermatic Inc. ST01C Digital In-Wall...
To palaboy: when you talk about a switch on the left most terminals, you mean with this switch im enable the timer???
Question is not clear.
You posted about Dayton on-delay timer?
This timer has two contacts, and wires similar to a light switch.
Connect 120V power to terminal 1
Connect wire going to load to terminal 3
Maximum Load is 1 amp so this timer should be wire to a contactor/relay and not directly to Load.
If you have Dayton off-delay timer, open following link for wiring diagram, and to see examples of contactors:
If you have a different timer, then add a comment with clear description of timer or in-focus photo of timer posted on Flickr
Jul 11, 2011 | Amperite Dayton Solid State Timer On Delay...
HOW I INSTAL ,CONNECT SWITCH TIMER TE502 ? IT
Wiring diagram shows on side of timer and looks same as to following illustration:
http://waterheatertimer.org/images/NO-NC-timer-200.jpg
For more complicated illustration showing din rail and modular timer wiring variations:
http://waterheatertimer.org/images/NO-NC-timer.jpg
With din rail timers, the power connects to screw terminals 1 and 2 and this will run the clock and relay.
The TE502 image is bad, and I can't see wiring diagram exactly.
It appears that terminal 4 is common. This is typical for din rail timers.
Put Hot lead to terminal 4.
Terminal 3 appears to be the NO terminal, so put wire going to Load to terminal 3.
Jun 20, 2011 | Electrical Supplies
How to bypass mtd8
To permanently bypass the timer, you have to move wiring.
I don't have specific wiring diagram or programming manual for mtda8 timer, but am familiar with wiring din-rail mounted digital timers.
1) Wiring is typical across all din-rail timers, with variations of same theme depending on number of channels and purpose.
2) Open following illustration of wiring:
http://waterheatertimer.org/images/DIN-series-wiring-300.jpg
Same-similar illustration shows on side of timer.
3) Notice the mtda8 has 5 screw terminals.
4) Two screws are for incoming power. These terminals are usually labeled 1 and 2. These wires power the timer.
5) Three more screws are for the timing relay. These screws are usually labeled 3 4 and 5.
Typically the #4 center screw is common, and carries power. And when timer is ON, power is live between #4 and #3 terminal. When timer is OFF, power is live between #4 and #5 terminal.
6) Move #3 wire to #4 or #5 screw and then the timer function is bypassed.
Jun 15, 2011 | Hardware & Accessories
I just bought an older electronic Intermatic timer at a yard sale. Model ET7215C. Timer power can be 120/240/277. There are 5 terminals for this, numbered 1-5. Looks like a variable tap power transformer....
I think you have the ET70215C SPDT
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
If this is not your timer, then add a comment.
Manual for ET70215C (same manual is for other models too)
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et70215c%20-%20english.ashx
Just as you figured, timer has selectable voltage.
Page 28 shows wiring diagrams and jumper settings:
Timer comes with a jumper, and then you select with voltage by installing jumper
Sample wiring diagram below shows 120Volts:
ET70125 appears to have 8 terminals.
Some models have 5 terminals.
There are many ways to wire this timer. Off hand I can think of 10 different ways.
Add a comment if you need help with a specific project.
In any case, the clock terminals are 1 and 2.
To put voltage to the timer switches in the simplest wiring options, is to put a jumper wire from terminal 2 to 3
If you are using 240-277 voltage with two hot wires, you still need to jumper from clock terminals to switch terminals. For example one jumper wire from terminal 2 to terminal 3 & then second jumper wire from terminal 1 to terminal 6
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 08, 2011 | Intermatic Hardware & Accessories
GE Digital Time Switch (15132) for basic landscape lighting
Leave the breaker off, remove the wires from the timer and just connect them. then turn the power on. Unless you have a short somewhere, the lights should come on. What you have just done is made the breaker your switch. If the breaker kicks you know to keep looking for a short as it is not the timer. Regards, Joe
Jan 04, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
65 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
