Question about iRobot 5800 Scooba Vacuum
Scooba won't turn on
I purchased a Scooba from someone brand new, never out of the box. It worked about four times and did a great job! After about a week it just would not turn on. It shows that it is charging and then fully charged but when I unplug the charger and push power I get nothing. No light, no beep, nothing. I tried contacting iRobot for help but received no response. I finally figured it was the battery (dated 2005) and purchased a new battery. It arrived last night, I installed it and pushed power. It came on right away which confirmed to me that the other one was just dead. Well, I go to put the Scooba on this morning and again, nothing. Nada. No power. Anyone? Thanks so much!
    Sniper:
  • 61 Answers
It sounds like you've got a finicky power button. Not a lot that can be done about that, but you may want to try getting your hands on the old-style Roomba remote, the black one. The power button from that will power on a Scooba, though you can't start a cleaning cycle that way. This might allow you to bypass the Scooba's power button altogether.
Posted on Jun 04, 2009
My Scooba floor cleaner "check tank" light stays on even after it's refilled and everything cleaned but still will not work. It just keeps beeping at me when I try to start it. How do I reset it or get...
Flush out the solution valve with water (aka "prime the pump"). Use water, not just air, because water will clear any obstructions that may be in the lines. Also, rinse your tank through the four ports on the *underside*-- one round, two oval, one large and curved, all four in a row. Rinse them really thoroughly with warm water, then refill the tank and try the Scooba again. If it doesn't work, call us: 1-877-855-8593.
Aug 16, 2009 | iRobot 5800 Scooba Vacuum
Scooba battery light turns red as soon as irobot starts
Do you leave the battery on charge long enough? Try 4-hours up to overnight. If so, then the battery is probably at the end of it's useful life. Getting a new battery depends on cost versus life expectancy of the robot and whether it does the job you want it to do.
Jul 19, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Scooba says check tank and won't move.
Rinse the four ports on the underside of the tank with warm water, particularly the round opening that covers your Scooba's vacuum port and the curved one that matches the filter. Odds are, there's a clog in there and your Scooba knows it. Rinse the two oval ports as well, as thoroughly as you can.
Also, try priming the pump with water. The iRobot website shows how to do this under the Scooba troubleshooting section.
Then run the unit with water and vinegar (in place of the Clorox Cleaning Solution) if possible.
May 10, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
Scooba not working after full recharge
NiCD and LiOn batteries have this tendency. They work great for a year, then slowly die off. The problem is you. When new, the device MUST be charged for 14hr nonstop, then every 2-3 months run dead, and recharged again 14hrs nonstop. This is done so the CPU of the Roomba (cool toy) KNOWS what DEAD is and what FULL is. It does this by measuring the amount of currrent flowing thru a very precise resistance. If you do hit and miss charge cycles of the roomba or leave it charging too long, it either develops a flase memory of the above two conditions, or gets HOT and the electrolyte paste dries out. Fix is to wear it out, charge 14hrs, wer it out againand repeat 3-4x. Then recharge and use. If that doesn't fix it, the batteries are too dried and need to be replaced.
Apr 08, 2009 | iRobot 5800 Scooba Vacuum
Battery door will not open
You have to push down on the plate to open the door. Make sure Scooba is on a flat surface, then push down. If the door doesn't release, try again. It sometimes takes a few tries, but that should work. If not, call iRobot Support. They are great and have helped with everything. I love my Roombas and my Scooba!
Jan 05, 2009 | iRobot 5800 Scooba Vacuum
Scooba circles and only goes backwards.
try cleaning the cliff sensors under bumper
Dec 13, 2008 | iRobot 5800 Scooba Vacuum
Stuck on check tank indicator
If your Scooba's Green Check Tank light is coming on immediately on startup, please try the following steps:
1. Remove and reseat Scooba's battery, ensuring that you hear it click into place.
2. Remove and reseat the brush head
3. Remove and reseat the vacuum port and filter. When replacing the filter, be sure to press firmly into the hole. There is a magnet on the filter that must connect with the magnet on the Scooba.
4. Fill Scooba’s Clean Tank with approximately 1 cup of cold water, shake vigorously, and empty it to remove any debris in the tank.
5. Empty the Dirty Tank, refill with water, and slosh it around to pick up any sediment. Empty the Dirty Tank again.
6. Refill Scooba’s Clean Tank with water, adding a pinch or two of table salt. Run the Scooba. If the issue persists, please follow the steps below:
With the tank removed, press the Power button and then the Clean button.
If the robot tries to start a cleaning cycle, power off the robot and repeat, pressing the Power button first and then the Clean button. If the pump makes a “whirring” or squirting sound and the robot does not start a cleaning cycle (Check Tank indicator will light), this indicates that the pump is working. Replace the tank and try starting a new cleaning cycle with the tank on.
If Scooba does begin a cleaning cycle the second time you press the Power and then the Clean button with the tank removed, the pump valve could be blocked with debris. Using a turkey baster, straw or sports bottle, force water through Scooba’s solution valve. Confirm that the baster, straw or sports bottle fits snugly over Scooba’s solution valve, push water through the system at least three times, and then try re-starting Scooba.
Below is a link to a diagram of these steps for visual reference:
Title: Scooba is not putting down cleaning solution
http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=322&p_created=1167154849
Nov 01, 2007 | iRobot 5800 Scooba Vacuum
My scooba is not picking up all the water.
There are only a few things that can cause the condition you describe. First would be to verify that the vacuum/blower motor is running. You can test this by placing your hand on the floor opposite the side where the charger is connected and see if you feel air movement. If no air is felt, there's your problem. Second, there is a valve located in the dirty tank that if blocked will prevent water pick-up. To resolve and clear this condition will require several processes to occur at once. Fill the dirty tank half way with hot water, add Scooba cup of vinegar. Close the stopper and shake the "Good Grief" out of the tank. This action is necessary and may have to be repeated several times to clear the flapper valve in the dirty tank. Third, there may be a poor seal between the tank and the Scooba base. Verify that both the left and right sides of the tank are close to the base and equal in distance. If the right side is farther away from the tank (larger gap) then water pick up will be poor. Some Scoobe owners resort to using duct tape to hold down the tank. Fourth, verify that the thin rubber pieces on the bottom of the tank are not deformed and properly seated in the grooves. hope this helps
Oct 17, 2007 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
iRobot 5800 Scooba Vacuum Logo
880 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
