Question about Refrigerators
Ge GSS25JFMCWW Unit not cooling.
    Scholar:
    New Friend:
  • 81 Answers
The mainboards go bad on these all the time. If you don't have TONS of frost in the freezer section. Pull it out and unplug it. Take off 9 screws holding a little panel on in the back. Disconnect all connectors and then the compression fittings holding the board on. Look on the back of the board for any burn outs located near the compressor relay. It's a black box, but you want to look on the side that has all the solder joints. You're looking for burnt solder joints.
Posted on Nov 28, 2013
  • JohnVan Akker
    JohnVan Akker Nov 30, 2013
    I checked the board, no smells or signs of burning. Yesterday, I moved the unit outside, used the garden hose to clean the coils underneath and coils behind the panel in the freezer. They froze up again, but it is now 29 degrees in freezer after running all night. What next?
GE bottom freezer stopped cooling
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
GE bottom freezer stopped cooling sporadically every 1-2 days then cools again with no intervention. Unit is 5 yrs old.
Put the old board back in. See what it does, from your post, sounds like it was working correctly.
GE model # GSS25JFMCWW has water to the dispencer,but not to the icemaker.
could be a number of thing,s The device that sends water to the ice/mak is different than the door water the ice maker has it,s own brain (circuit) water in/out some built into the frig itself . The ice /mah send siginal to water valve to send water.. to ice maker sorry icall appl man sorry
Mar 18, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a GE side by side Model No. GSS25JFMCWW. The refrigerator side is not staying cold. When I remove the back panel in the freezer there is heavy frost build up on the coils. If i thaw out the coils...
the ice disp stopped working now the unit will try to start then stop over and over, went to main board on back of frig. took off jumper one connector it stopped but not sure what jumper one controls
Oct 26, 2010 | GE GSS25JFM Side by Side Refrigerator
GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator GSS25JFMCWW not dispensing ice but dispense water
I have the same problem with the same unit. I removed the ice tray and held the open door cut-off switch closed. I then pressed the lever to dispense ice. I hear a humm like power is getting to the motor but the motor is not turning. I hear a click like the selonid is engaging. I'm having to assume at this point it's the motor and I am going to go ahead and order a motor. I've found a motor for the unit at partselect.com for $65.54. Hope this helps you.
Apr 21, 2009 | GE GSS25JFM Side by Side Refrigerator
I have side by side refig model GSS25JFMCWW.I have to manually defrost by shutting off refrig.This model has defrost cycle,what would cause this cycle not to work?
Defective defrost timer, heaters, or defrost thermostat. Locate the defrost timer, rotate the dial (clutch head screw) clockwise SLOWLY until you hear one click. That puts the timer in defrost. Wait 25-30 minutes and the defrost should happen. Normally the timer will shift back to the cooling mode after 18-22 minutes. If it does not restart after the 30 minutes your problem is the defrost timer. Rotate the dial SLOWLY a little more and it should go back into the cooling mode. If you followed the above instructions and did not get a defrost the problem is in the heaters or defrost thermostat.
May 26, 2008 | GE Refrigerators
I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
