Need colour code from phillips din plug to red and black/white jack plugs
  • 2,113 Answers
All RCA cables are red for right and white for left audio output and have been for quite a few decades
Posted on Nov 26, 2013
There is only a red and white hole in the tv
I used to have a Phillips CRT TV from 1986 and it did not have the 3 colours red yellow and white on it to plug in the RCA jacks for my Nintendo 64 console. It was plugged into a vcr for it to work. Or you can buy the Rd switch piece for your console http://www.lukiegames.com/N64-Gamecube-RF-Modulator-Nintendo it is an old TV that did not have those parts to it yet 1994 and older will not have them then.
Feb 17, 2014 | Nintendo 64 Console
My Ariana TV only shows the colours black and white
Might have video plugged into wrong plug. Nowadays, for RCA video, Green jack (which is usually for dvd player three color) is used also as conventional video output for old dvd players. They have an automatic switch to detect if you're plugging in old video (yellow) jack in. Picture will be in colour upon plugging into the right jack. No need to shut tv off, just plug in until you see color. Should be sharp & clear.
Jan 22, 2014 | Televison & Video
Need to know how to connect to tv it comes on but in black and white
If you're using composite video cables (red/white/yellow) but your TV doesn't have a yellow jack to plug into, plug the yellow cable into the green "Y" plug instead. If there is more than one set of video jacks on your TV, make sure you're using the first set, usually labeled "Video 1" or "Component 1". If it still comes up in black and white after all that, you may need to look in your TV's settings menu to see if there's an option to change the settings for that port from Component to Composite.
If you're using component video cables (red/white & red/blue/green) make sure the cables are all plugged in to the proper color-coded ports on the TV. Mixing up the video cables can cause the image to show up in black and white
May 12, 2012 | Video Game Consoles & Games
HOW DO I CONNECT TO TV
There are many methods to do this.
If your cable are ONLY RED,WHITE,YELLOW
1 Plug the red white and yellow cables to there corrosponding jacks on your DVD player
2 Plug the red white and yellow cables to jacks labled video IN, Audio IN. They will be colored on the back of your Tv
3 Plug in the power cable.
4 Turn it on and flip through the inputs on your tv until you see the picture
IF your cables are RED, GREEN, BLUE, RED, AND WHITE
1 Your are using what is called conponent video. This is a high definition video.
2 Three of your plugs are for video. They are Red(Cr) Green(Y) and Blue(Cb)
3 Plug the GREEN into the Y jack
4 Plug the RED into the Cr jack
5 Plug the BLUE into the Cb jack
6 Plug your power cable int o the wall if you havent alredy done so
7 Plug the other red cable into the audio right jack
8 Plug the white cable into the audio left jack
9 Turn it on and surf through the input until you find it
If you have a BLACK, RED and WHITE
Do the same as RED WHITE and YELLOW but
1 Put the black cable into the s-video slot
2 Surf through the inputs until you find the picture
If you have ONE BLACK CABLE
1 This is called HDMI(High-definition multimedia interface)
2 Plug one end into the tv and the other inte you dvd
Thank you for your time, Good luck and I hope this works
Jun 08, 2011 | Televison & Video
What do i need to play back recorded video onto my t.v from my sony handycam dcr-trv260...i have s cord, usb cord, yellow rca jack??? so what else do i need!!!...nothing i have tried has worked???please...
You can connect this camera to a suitable TV with either the S-Video lead or the RCA lead, but only if the TV is equipped with the appropriate inputs. The S-Video lead looks like a tiny DIN plug, and the RCA jacks are three separate plugs coloured red, white and yellow (yellow is composite video, red and white are left and right stereo sound). If you use S-Video you will also need to make a separate connection for sound (using the red and white RCA connectors). Sometimes the TV sound input is a mini stereo jack, and you will need a Y connector to adapt the two RCA connectors to the mini jack, or maybe the camera's sound output is also by mini jack, in which case you may need the reverse Y connector. Most TVs have some way of accepting a video signal, but you may already be using it for a DVD player or the like.
If your TV lacks these connections, you may be able to use an adapter. In the UK, most recent TVs have a SCART (Peritel) socket, which takes a big plug with 21 connections on it. You can get an adapter to fit that socket that will allow you to plug in the RCA connectors and maybe the S-video too. I don't know what country you are in, or what adapters are available in your country if it isn't the UK.
Once you have made the connections, you must select the appropriate input on your TV. The other possible hiccup is setting the camera to the right video standard, NTSC or PAL., to match that used by your TV.
The USB cord will not connect your camera to the TV.
Jan 11, 2011 | Sony Handycam DCR-TRV260 Digital Camcorder
I have a Samsung P2771hd monitor. I have green and black cords (for sound and microphone) coming from the computer. I bought a cable that has the black plug from the pc that splits to the red and white...
The Red (right channel) nand White (left channel) RCA plug to miniphone jack is made for audio amplifier with RCA input jacks. The monitor should have Green audio input mini stereo phone jack for the audio input from the PC audio line out (Green mini phone jack).
You will need the shielded audio cable with mini stereo phone plug at both end for the audio hook up.
Dec 21, 2010 | Samsung P2270HD 22" LCD Monitor
2001 vw golf 1.4 wiring details for towbar plug/socket.(colour coding)?
Left indicator - Yellow to Black/White
Right Indicator - Green to Black/Green
Left Tail - Black to Grey/Black
Right Tail - Brown to Grey/Red
Fog - Blue to Grey/White
Brake - Red to Black/Red
Earth - White to Brown or Body earth above/behind Left hand Light
Oct 02, 2009 | 2001 Volkswagen Golf
Connect Philips DVD to Sansung TV
the red and black are the same as the red and white, these are the audio left and right channels. the yellow plug is the video plug. the next thing you have to check is wheather your tv has video 1 and 2 channels
May 09, 2009 | Samsung Televison & Video
Polaroid tv Wii connection
Your LCD TV should have one of the following types of inputs:
  1. Composite. This is usually a yellow jack, along with red and white jacks for audio.
    If your TV has these, which it should, then the cable that comes with the Wii will plug directly into these jacks. Plug the yellow to the yellow jack, the red to the red jack, and the white to the white jack.
  2. S-Video. This is a flat black jack. There are four little holes, and one "flat" rectagular hole. There should also be a red and white jack that go along with this for audio.
    In order to connect to this input, you will need to purchase an S-Video output cable for the Wii. Most stores that sell Wiis will sell a third-party cable for this.
    This connection will give you a significantly better picture than Composite.
    S-Video does not carry audio, so you still need to plug the red plug into the red jack and the white plug into the white jack or you'll get only video and no audio!
  3. Component video. This is a triplet of Red, Green and Blue jacks. There is usually a set of red and white jacks along with them for audio again.
    This connection will give you the best picture, and you can set your Wii to EDTV (Progressive) mode.
    To connect to this input, you will need to get the Wii Component Video cable. Most stores that sell Wiis will either sell the official Nintendo one, or a third-party cable.
    Connect the red plug to the red jack, the green plug to the green jack, and the blue plug to the blue jack. Also connect the red audio plug to the red audio jack and the white audio plug to the white audio jack.
    Be careful not to get the red audio plug confused with the red video plug!
    If you see a picture, but the colors are wrong, then you either swapped the red and blue, or you connected the red audio plug instead of the red video plug.
Apr 01, 2008 | Nintendo Wii Console
Wii gone black and white, no colour
I bought a wii a few days ago and like everybody else mine too was in black and white with a grainy picture. I have a Panasonic lcd flat screen and thought I had connected it corrected, I got somebody out to have a look at it and found out there are some connections on the side of the TV which I hadn't even noticed before, once I put the red white and yellow leads in these and set the TV to AV3 everything is in perfect colour. Hope this works for some of you.
Dec 11, 2007 | Nintendo Wii Console
26 people viewed this question
 Grubhead
Grubhead
