Question about Teac R1 FM/AM Radio
What does the flashing blue light mean on my teac r1 radio?
Blue light flashes...
Engine management light flashes 5 times slowly and 1 quick one, on 2008 Yamaha R1
Hello Aaron, your question is very general so I'll answer it that way. The flashes are like morse code. Yamaha will have a list of problems/diagnoses related to the flashing codes on the engine management light.
Jan 06, 2016 | 2007 Yamaha YZF-R1
Why does blue light keep flashing when my HMDX boom box is turned on
clip_image002.jpg if it is a slow flashing that means it is connected
if it is a fast flashing that means it is pairing
Jun 01, 2014 | Audio Players & Recorders
Constant flashing blue light
The flashing blue light means the Bluetooth is connectedconnected, device is on.
Jan 31, 2014 | Hmdx Hx-p240gy Jam Plus Portable Speaker,...
Teac model LT-1 how to set clock
To set time on TEAC CD Receiver LT1
Press Memory/Clock Adjust button until numbers flash.
First display is 24/12 for choice. Change with >>> button.
Press Memory/Clock Adjust button again and Hours digit
flashes. Set with >>> or <<<.
Press Memory/Clock Adjust button again and Minute digit
In 12 hour mode "PM" will be displayed
Sep 23, 2012 | Teac LT-1 Clock Radio
Need to purchase battery pack BP-R1 for Teac R1 radio
Teak does no longer carry this specialty item. They do not stand behind their product and deserve to be bypassed in the future.
Oct 07, 2010 | Teac R1 FM/AM Radio
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
Where can I buy the ac cable for the R1 Teac?
thay can be bought on ebay an also if you take it somewhere like maplin thay will be able to advise you on a unerversal adapter
Jul 26, 2009 | Teac R1 FM/AM Radio
Blue light flashing light, red light on
The flashing means that the toner and/or the imaging drum is empty or missing (printing halts on these errors). Lights on steady means low toner.
Jun 24, 2009 | HP LaserJet 2550n Printer
Re: setting clock and stations
Is there a reset button on it
Jan 31, 2009 | Teac R1 FM/AM Radio
Will not work on battery
UNPLUG THE RADIO !!!!!!!!!
Try removing the battery cover and remove and disconnect the battery.
Reconnect the battery and replace the battery cover.
Now, plug the radio into the wall electrical outlet and wait, the blue light on the radio top should start flash and will flash for about 10 minutes and then stop flashing.
Leave the radio plugged in for about 16 to 24 hours to completely charge the battery. For the first three or four times, completely drain the battery and completely recharge for 16 to 24 hours, this will condition the battery .... mine works like a dream. GR
Feb 16, 2008 | Teac R1 FM/AM Radio
Teac R1 FM/AM Radio Logo
80 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
