Technics f61 error code - Audio Players & Recorders
    Problem Solver:
  • 5 Answers
Check the integrity of your speaker wire, make sure they are 'phased' (-+) properly, also check all other connections, it sounds like the protection ...
Posted on Nov 26, 2013
I have a technics stereo but f61 error on it how do i fix it
F61 is the error code for an amp problem. It may need an amp IC replaced, or, if you're lucky, the may just be bad solder connections on the amp IC's and regulators that are on the heatsink. Most of the technics receivers had an access panel that can be removed from the bottom of the unit, and then you can visually inspect for any bad connections. Check anything that is on the heatsink as these were the biggest problems for this line of receivers.
Dec 18, 2012 | Audio Players & Recorders
F61 error on my display screen on my technics stereo
Download the service manual. It will have all details about error codes and rectifications.
Jun 06, 2012 | Audio Players & Recorders
What does F61 mean
Hi Georgina,
F61 is an error code(protect error code in other brand) for panasonic home theater system. This will trigger if the unit gone to overload to avoid further damaged to other parts. This code is quite technical if your not handy with electronics. However I will say to you the common caused of this error code.
1. Output IC - this is the most common caused of the error code. Once shorts happened to this IC, it will trigger the error code. Exposure to high volume and/or running in the long time will caused this IC to shorts and produce an overload.
2. Shorted Speaker - if one of your speakers shorts, error code will appear also. This may isolate by disconnecting the speaker to the set and play the unit *****. If the symptom still there the fault came from the unit itself.
3. Shorted Inputs - inputs connector is also prone to shorts due to frequent bending and pulling. To isolate this from fault, disconnect all the inputs connected to the unit like the aux input, antenna, mic, etc.
4. Faulty power supply - once gone to out-of-regulation condition, the error code will appear to protect the most expensive parts from further damaged. Bad solder joints in this section is also to consider.
5. Faulty Fan and its circuitry - F61 will appear only after a minute of operation not upon powering on the unit. Check the fan if working or not...
I would advice you to send the unit to your local Panasonic service center and leave the expert isolate the symptoms.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it forfree.
Hope I helped you.
Good luck and have a great day!
Jdvillanueva
Jan 10, 2012 | Technics Audio Players & Recorders
My technics hi-fi separates sL-EH790 is not coming on just saying f61 then going off
Hi Shelly,
"F61" is an error code for short and/or overload detected by the processor upon self check.
First thing you have to try to eliminate this kind of symptoms is by disconnecting all of the inputs and speakers connected from the unit then turn it on without them. Let me know if the symptoms still persist...
Jdvillanueva
Oct 22, 2011 | Technics Audio Players & Recorders
What does f61 mean?
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 16, 2011 | Panasonic SC-AK18 CD Shelf System
Stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Oct 15, 2009 | Audio Players & Recorders
Technics F61 error, can you please tell me what this means?
F61 is the "shorthand" for protection mode for Technics units. Either the regulator IC or the output AMP-PAC IC has failed. Expect a parts cost between $40 -$100 for the repair depending upon which IC has failed.
Dan
Jun 19, 2009 | Technics Audio Players & Recorders
F61
Sound amplifier ic??******** this guy is talking out of his ***.
F61 relates to fan error. There are two fans, one of them is either spinning too slowly or not at all.
This fan can be purchased in any computer store. Just remove it and take it with you.
Jul 28, 2007 | Technics SC-DV290 System
Technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
May 14, 2007 | Technics SCEH790 CD Shelf System
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
26 people viewed this question
 Grubhead
Grubhead
