Replace staple cartridge in Bizhub 601
Need to change empty staple cartridge
SOURCE: WHERE ARE THE STAPLES?
to  the left you will have a narrower section  and it will possibly have mail box attachment and job divider shelves that ride up and down .......this is the finisher unit
separate this section from the main body of the machine
beware of the paper reciever falling as you separate  take hold and lower
when you have separated  remove the bridging paper reciever OR hold up
staples are inserted in the unit central and to the right of a green rolling wheel
grasp the green bar on this unit and pull upwards   your staple bars go into this piece that should be in your hand
Posted on Feb 23, 2009
Bizhubman
  • 108 Answers
SOURCE: How do I change the staples in the bizhub 200?
If you have the finisher pictured above: If the machine is asking for staples, press "Finishing" on the panel then "Add Staples" this will move the staple unit to the front of the finisher. If the machine is not asking for staples but is not stapling paper then you may have a staple jam. To get the staple unit out: Open front door of finisher, Locate green turn wheel (this is horizontal in bottom left of finisher front door and is connected to white gears) turn this green turn wheel and the staple unit will be moved to the front of the finisher. Remove blue staple cartridge and remove the staple jam. After you reinstall the cartridge into the staple unit just close the finisher door and the unit will move back to home position on its own.
Posted on May 13, 2010
  • 60 Answers
SOURCE: I need some one to
Thanks, but I don't think anyone will do that since you simply are trying to put on trash our school and knowledge, just because you want to save some bucks. What you think a technician was doing ? They work just for few bucks. What you think ? We are RICH ?????!!!!
THANK YOU
Posted on Mar 30, 2011
  • 118 Answers
SOURCE: MY KONICA MINOLTA BIZHUB C203
Yes you did good but you didnt get it in all the way... push harder till it clicks in,,,, unless there is no staples in the cart.... tell me how it went
Posted on Oct 16, 2011
xeerie
  • 347 Answers
SOURCE: Emptying waste toner BizHub C250
It has the facility to empty the waste toner cartridge manually.You do not need to buy new one.
Posted on Jun 05, 2012
How to fix error code C0103
one of your paper draws not working check all for proper operation might have paper behind them
Jan 14, 2015 | Konica Minolta Konica BizHub Press C7000...
How to remove clear staple cartridge to replace with new refill
The last time I played around with a staple unit I had to replace the full unit. If the empty cartridge won't come out it's probably not empty. Try more investigation around this area.
Good luck
Oct 03, 2014 | Xerox Office Equipment & Supplies
How to Replace Staples in FS-526 Finisher
if the stapler is out. then open the finisher door and the staple cartridge with blue handle pull out and replace, do not throw the blue part away as you only replace the middle staple pack. Or open the finisher door and turn the green knob to bring the stapler to you
Jul 23, 2014 | Konica Minolta Bizhub C652 Color Copier...
Konica minolta bizhub c35 black toner being recognized as empty
sir/mam replace the cart then might have gotten a bad one from the store
Mar 11, 2014 | Konica Minolta bizhub C35 Black Toner...
How do I replace staples in bizhub 501
Open doors where toner is located.
Deep in the left cavity, you should find a brown unit in which the staple cartridge is located.
Carefully slide the unit towards you and when it reaches the edge, you can gently lift the blue handle and remove the empty cartridge.
Press each side and the spring will lift allowing you to remove the empty white cardboard staple holder. The arrows are to point away from the blue handle.
replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-0.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-1.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-3.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-6.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-10.jpg
Feb 20, 2013 | Konica Minolta Office Equipment & Supplies
May 15, 2012 | Konica Minolta magicolor 5430 DL Laser...
May 13, 2010 | Minolta bizhub 200 All-In-One Printer
How do I replace the staples on a bizhub 250
the staple unit is located in the finisher where the paper is stacked,check on the top or on the side for a compartment door that pops open. You should see a clear plastic cartridge that slides out where another one can be replaced
Mar 25, 2010 | Minolta bizhub 250 Black and White Copier
I need to change staples
Jan 06, 2010 | Minolta bizhub 200 All-In-One Printer
56 people viewed this question
k24674
