Question about Crafts & Hobbies
Lionel instructions My milk cans come out sideways I have used a number of voltage settings and they only come out faster sideways. HELP!
I have the wonderland express train won't go around can it be fixed
Yes, but before I took the set to a model train dealer I would check the basics. Depending how the unit is stored I would assume that corrosion(oxide) has built up between the electrical components.
This is so common that it can be assumed to be a normal maintenance activity.
The connections from the power to the track, between the tracks and between the engine wheels and the track.
Setting up on a table top allows for convenient troubleshooting.
A voltmeter provides a good tool for efficient analysis of the electrical circuit.
Using a soft cloth rub/polish the rails to eliminate oxide/grime built up.
Use an eraser to scrub the connections between the rails,
I've included several links to provide you with examples of problems and solutions.
Merry Christmas
Hope this helps?
Troubleshooting Ready To Run Lionel Train Sets
Setting Up Your Lionel Train Set
How To Fix Problem With Lionel Fastrak With Voltage Drop Fastrack Connection Pin Fix
Nov 29, 2016 | Crafts & Hobbies
I need a telephone number. I am 81 and need help
Go to Lionel.com and select customer service or contact us on their web site.
Nov 02, 2015 | Lionel Christmas Parade Box Car by Lionel
Where can I get a set of 0-9 rubber stamps in the correct Lionel font and size for re-numbering Lionel pre war STD gauge brown State Pass boxes? Thanks, GG
Mania Trains in NJ has repro stamps for Pre-War trains...may have stamps for the boxes as well. Many of the stamps came from Jerry Butler....Excellent products
Olsen's trains in Ohio may be a second source
Jul 02, 2014 | Toys
Lionel # 3830 submarine instructions for assembly
You can download instructions and product manuals at Lionel.com in their customer service section. If you don't find what you need, use the Contact Us link to ask for help. Lionel offers great customer support.
Mar 03, 2014 | Lionel New York Central Flyer
Need manual or instructions or lionel wabash cannonball 70-1962-202
You should be able to get a manual from the Lionel Service Department on 586 949 4100 or use their website contact service. Contact Lionel Trains
Dec 02, 2013 | Lionel Crafts & Hobbies
Looking for instructions for lionel fast track automatic switch
Try contacting the Lionel Service Department on
Oct 12, 2013 | Crafts & Hobbies
Lionel cw-80 transformer blown voltage regulator i cant read the size can you help?
The voltage regulator is part LM78L05. You might want to check the two diodes are ok as well 'D1' & 'D2', sadly I can't see markings on them.
Dec 19, 2012 | Lionel Cw 80 Transformer
Crafts & Hobbies Logo
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
