Question about Dell Ethernet Card Network Adapter
686 amibios 1999
Internet takes foever to download. Other computers work fine. Ethernet conection built in on motherboard. D I need to replace the motherboard. ?
  • 107 Answers
You could add a new NIC to the computer which is cheaper ($10), as long as you have the ability to add. You could also get a USB ethernet adapter. Have you tried to update the drivers and firmware of the NIC?
Posted on Dec 06, 2013
Need wiring diagram for Amibios 686 ZL15 1317 Motherboard.
The manufacturer will have this information in PDF form most the time and keep this information for a number of years. Assuming you're looking for the pin outs for the motherboards power button, HDD light, and other indicator lights and functions. Also - If you look real close to the sides of the pins, you'll see indicators to show where everything goes. Hope this helps.
Nov 11, 2016 | Computers & Internet
Soyo Tech aid response 2A: "different BUSes" on 1999 AMI Bios on ECS P4800 Pro-M VI.0A pc motherboard.Won't boot but stops. How to fix?
Visit http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=574&LanID=9
and compare that is your BIOS updated ? If not, I suggest first update your BIOS to the latest version and see if error is removed ? Try Load Optimal Settings of BIOS. If fail, then try resetting the BIOS. If you have install anything new, try to boot by removing the new device. I suggest from the above URL, you can download the manual of the mother board. I hope trying these steps will remove your problem.
Feb 11, 2016 | Intel PENTIUM-4 FSB800 Mother Board with...
Dx4640
Take the power supply and use it with another known working computer. If it works, then the problemo lies with your mo bo. Replace it with the gateway part number for the mo bo and ignore the other stuff. If you can do a "repair" operation with your OS you might be able to avoid reloading the OS and all of your programs all over again and save lots of time and aggravation. Can do with XP, maybe with Win 7.
Mar 30, 2014 | Computers & Internet
Mobo 001d9298691c welke drivers
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Feb 22, 2013 | Packard Bell Computers & Internet
I think my network card is bad. My internet / email isn't working on my desktop (although it works fine on my laptop). And the computer is not recognizing anything when I type ipconfig. So, i think i need...
since the network card is built onto the motherboard reinstalling the driver would be the best first option.
HERE is the link to the driver.
Broadcom827.exe - Broadcom NetXtreme Gigabit Ethernet driver Version: 8.27.1.0
Supports: Windows XP
Note: This is the Broadcom NetXtreme Gigabit Ethernet driver for use with the Big Lake, Cortez, and Putton Bay motherboards in Windows XP.
I would try that first.
Apr 14, 2010 | Gateway GX7022E (RBGX7022E) PC Desktop
PC says no ethernet card (NIC) after reinstalled
First make sure the card (if a stand alone card ) is properly set in place (you'll have to open the computer and manually test it . Do this with the computer off!). If this is not the case or, you have the card built into the motherboard, you should re-install the drivers from your original installation CD. Otherwise you may need a friend or, atrip to a library/colleg etc, to download the proper drivers.
Nov 24, 2009 | Dell Ethernet Card Network Adapter
Bios update
go online and type in
bois download drivers
enter
manifacture name bois model # [date if u have one] download drivers
rod
Dec 16, 2008 | ASUS P4S800-MX Motherboard
Computer will not boot
The code A6 indicates bad memory. If it is new take it back or replaced under warranty.Most memory manufacturers have a lifetime warranty.
If it came with the new computer, take the whole computer back and get it replaced under warranty.
Please let me know how you make out.
thanks
Jan 26, 2008 | Intel Motherboard
Motherboard manual ?
is jumpers on 1 and 2 good power test ram front conecter on pw
Jan 23, 2008 | Computers & Internet
P4mmv2 motherboard
If its a P4mmv2 motherboard with AMIBIOS 686 and a VIA VT8233 chipset then the jumper setting are printed on the motherboard, but they have labeled the power switch wrong, I believe th reset switch is the power switch. This is the type of mother board that I have and I have learned this from experience. Also I read in somewhere on the internet about the problems with these types of motherboards.
Jun 04, 2007 | EliteGroup P4VMM2 Motherboard
Dell Ethernet Card Network Adapter Logo
189 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
