Mainborad p01 7040120
NO SIGNAL WHEN I SWITCH MY COMPUTER I CAN NOT SEE ANY MESSAGE ON THE SCREEN
    New Friend:
  • 61 Answers
Remove the RAM and turn on the computer.
Re-insert the RAM in another slot and turn On the computer.
Posted on Mar 30, 2014
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
COMPUTER IS FROZEN..ERROR MESSAGE SAYS CHECK SIGNAL
So the message you get on your screen is telling you that there is no signal coming from the computer, Screen and computer are different parts, the screen is not your computer.
So this means that your computer is either not connected to your screen or not turned on. if it is turned on and properly connected, you have a hardware problem, take or have someone come over to inspect the pc in person.
Feb 03, 2013 | Compaq Presario 7478 PC Desktop
Emachines T6524 will not reboot, get no signal message on monitor
shut down your computer and remove the side cover and remove the memory from the slot and switch on the computer if you hear beeps switch down the computer and insert the memory if you still hear beeps means the tre is an memory failure you need to change the memory while removing memory you didnt hear any beep it means there is problem with your motherboard remove the processor heat sink and the processor clean the surface then insert the processor to the slot apply a thin level of heatsink compound and fix the heat sink then switch on the computer
Dec 29, 2011 | E-Machines eMachines Desktop PC
No signal anolg
good day,
maybe there's a problem with your VGA or the cable wire that connects the monitor and VGA....try to approach technician near to you.....
best regards,
kaybicks
Feb 22, 2010 | ViewSonic VA721 17" LCD Monitor
Screen flashing, message NO SIGNAL
This means it is not getting any signal from you computer. Check all connection on both the monitor and the computer to insure they are tight. Some monitors have both a analog and digital input, if this is the case on your monitor there is usually a button on the monitor that will allow you to switch between the two, usually has an arrow pointing to a box.
Jan 22, 2010 | Computers & Internet
Screen is white when on.....
Try disconnecting your connection to your computer.
If you see a no signal message with a dark background, you have problems with your video card.
If you continue to recv. the white screen, you have input signal problems with the LCD monitor itself.
If you do recv. a no signal message witha dark background, try removing and reseating the video card.
Oct 24, 2009 | ViewSonic VX2235wm LCD Monitor
Boot up computer. Nothing comes up on screen. Get a message:"information. No input signal." Everything is plugged in correctly.
  • check the cable on the monitor screen
  • if after removing the data cable from the computer and it has no vertical color screen then
  • try other data cable
  • try other monitor screen
May 02, 2009 | Computers & Internet
No Signal message
This is a message the monitor displays when the video cable is disconnected or the computer has no video output. Could be the computer is simply entering power save mode. Does the screen come on when you move the mouse or press a key on the keyboard?
Dec 28, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Monitor stuck in sleep mode
It will do this when it's not getting a video signal from the computer. Make sure that the signal cable is firmly plugged in at both ends. Also verify that the computer is actually starting up. The monitor may not be getting a signal because the computer isn't sending any.
Sep 25, 2008 | Compaq TFT5015 15" LCD Monitor
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
