Question about Building Materials
Have thin white burn marks in corelle countertop.
Put a very hot pot on corelle countertop. It left a thin round line of white damage.
larryyb
  • 291 Answers
SOURCE: Kenmore dryer leaving brown burned lines on clothing
the rear drum seal was bad and as things rub against it they will get black marks on them.
Larry
Posted on Nov 25, 2008
MGCO420
  • 11 Answers
SOURCE: White thin line verticaly middle of lap top screen
Sounds like the monitor. Do you have another monitor to hook up to the laptop? If so, that will tell you precisely if it's the monitor or video card.
Posted on Jan 14, 2009
lafalot
  • 152 Answers
SOURCE: Westbend 6 qt crock white round pot
Try the Westbend website or replacements.com. If those two fail, try eBay.
Please remember to rate my solutions! Thanks
Posted on Feb 05, 2009
SOURCE: water damage on left corner black orbs on right
My daugther sprayed cleaner on our vizio tv screen, and now there streaks and a ***** of black pixels at the bottom. Is the tv junk now? Can it be fixed? Will it get worst? Thanks!
Posted on Aug 24, 2009
FixinFax
  • 3085 Answers
SOURCE: The inside bowl broke to my corelle by corningware
The crock will cost as much as a whole new crock-pot
Posted on May 14, 2010
Which one has more heat resistant: Granite or Silestone? Explain?
Planning to refurbish your kitchen, Now-a-days, a wide range of choices for kitchen countertops are available in the market, which make you to choose the perfect one. In case if you are looking to select granite or Silestone for your kitchen worktops. Then, as per my knowledge both are popular choices, but he Granite is a very durable natural stone with a high aesthetic value. It is heat and scratch resistant but also porous and therefore possible to stain; it needs periodic maintenance. Where as the quartz used in countertops and flooring is a man-made combination of resins and crushed quartz. The resulting surface is non-porous, meaning it is more stain resistant than granite and requires less maintenance overall. For further detail explore at: Black White Granite Kitchen Worktops in Surrey Essex MKW Surfaces
Feb 29, 2016 | Green Bean Cleaning Products Commercial...
My Corelle plate (round) is wedged in my round Rival stoneware crockpot - have tried everything I can think of to unstick it - soap, oil, hot water, cold water -- only the tip of a thin knife fits between...
suggestion to try, depending on how far the plate is down in the stoneware, try filling the Crockpot with warm water. Then plug in the Crockpot and turn it on to a medium heat. Then keep close watch on it, as the stoneware warms up it may expand enough to release the plate.
May 24, 2011 | Microwave Ovens
Outside of crockpot gets very hot and countertop is extremely hot after cooking for a couple of hours
This sounds normal. put the unit on something to protect counter. It is very difficult to heat long term, without the unit becoming quite hot.
May 19, 2011 | Rival 3040-VG 4-Quart
I have an older model Hitachi 32" ultravision CRT tv. the video just collapsed into a thin horizontal line (about 1/4"). Video is fine. Any help would be greatly appreciated. Thanks.
TURN IT OFF AND DO NOT TRY TO USE---if a thin line left to right in middle of screen it is vertical problem---the set should shut down but even seconds count here--this can burn a mark on all three picture tubes instantly and it is permanent.
Problem if small line left to right in vertical circuit.
Let me know what you know and I will try to help--I know these sets very well.
SD TECH
Sep 22, 2010 | Hitachi 61SWX10B 61" Rear Projection...
We just had it installed, Kitchen counter top, moss Green in color -Corian moving coffee pots with rubber feet leaves scuff marks , plates ceramic or china leaves scuff marks also , and they can not be...
Countertops
Cleaning All Finishes
Most dirt & residue
Use soapy water, ammonia based cleaner (not window cleaner), rinse and wipe completely dry. Commercially available solid surface cleaners, such as Clean EnCounters® will also work well.
Preventing hard water marks
Rinse and wipe completely dry after cleaning; clean up spills before they dry.
Removing hard water marks
Use a cleaner formulated for removing hard water marks such as CLR or Lime-A-Way.
Difficult residue
Spray residue with Deep Cleaner for DuPont Corian® from Stone Care International. Follow instructions on the bottle. Wash area with soapy water, rinse and wipe completely dry. If residue persists, follow steps below for removing dulling film.
Disinfecting
Occasionally, wipe surface with diluted household bleach (1 part water/1 part bleach). Rinse top thoroughly with water and wipe completely dry.
Preventing Heat Damage
While Corian® is heat resistant, as with all countertop materials, it is important to minimize direct heat exposure to protect your surface and investment.
DO NOT PLACE HOT POTS, PANS, ETC. DIRECTLY ON THE COUNTERTOP SURFACE.
Always use heat trivets or hot pads when placing hot objects on any surface. Always use a trivet under portable heat generating appliances such as a toaster oven. Allow cookware to cool before placing it into a Corian® sink. Preventing Other Damage
In most cases Corian® can be repaired if damaged. Be sure to follow these guidelines to help you prevent any permanent damage to your Corian®.
  • Avoid getting strong chemicals, such as paint removers, oven cleaners, etc., on your Corian® countertop. If a spill does occur, promptly flush the surface with water to fully rinse off the chemical.
  • Do not cut directly on Corian® countertops. Use a cutting board.
  • Boiling water alone will not damage your Corian® sink, however it is a recommended practice to run cold water from the faucet while pouring boiling water into the sink.
Removing fine scratches or a blotchy appearance
You may notice that the surface of your countertop begins to look blotchy. Typically, this is caused by leaving hard water to dry on the surface which will leave a film of minerals. To remove this film:
  • Pour some mild abrasive liquid cleanser, such as Soft Scrub®, on a damp sponge or cloth and rub over area using small circular motions, from the front to the back, then side to side, overlapping the circles until the entire area has been cleaned.
  • Thoroughly rinse the top with clean water and WIPE SURFACE COMPLETELY DRY.
  • Check to see if blotchiness is gone. If not, repeat procedure applying more pressure on the sponge or rag.
  • Continue over all affected areas until all film is removed.
Your new Corian® installation entitles you to certain quality assurance standards as provided in this Residential Limited Warranty. To obtain information and service under this warranty, contact the source from whom you purchased your DuPont™ Corian® installation or DuPont at www.Corian.com or call 1-800-426-7426.ifrcor_corianwarranty_10
Dec 21, 2009 | American Standard 7236.LBW.950 Glacier...
Dec 21, 2008 | LG Flatron L1750S 17" LCD Monitor
Larry
Aug 02, 2008 | Whirlpool GEW9250P Electric Dryer
Building Materials Logo
195 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
