Question about Measuring Tools & Sensors
Ac light is always on - Measuring Tools & Sensors
How can i tell if its running on 12v or 240v
Running on AC always cools down faster. If you plug it in to AC and the fridge cools quickly then the switch position is AC. Turn on a 12 volt light. Watch the lite while you operate the switch. When the light dims a little the switch position is in the DC mode.
Feb 20, 2016 | Refrigerators
Have 2006 rav 4. Abs, brake, vsc and tr ac lights all come on at once. They always go off after a bit of driving... All fluid levels are good.... Very wet and snowy here
I know this problem from the many posts about it on this site, as to the cause it is never always the same, it will require a trip to the Toyota dealer for testing and diagnosis with special diagnostic tools.
Jan 09, 2016 | AC Cars & Trucks
AC compressor always engaged.
disconnect the wire at the compressor to check that the clutch is releasing,then with a test light check to see if power is present when it is switched on and no power when off.
Aug 09, 2014 | 2004 Pontiac Grand Am GT
Lights come on but no AC output
Yes,internally there is two fuses. always arround 30 Amps. change it. there are like automotive fuses, plug in type.
Apr 19, 2013 | Belkin AC Anywhere (F5C412UK140W) Battery
My 2002 Jeep Grand Cherokee Laredo with manual climate control AC light goes off and AC stops working whenever it wants. I can force the AC to work by holding the AC button in real tight.The AC l
Have a good mechanic to check to see if the door of the a/c and heater and defroster is working properly. I had the same problem and one mechanic said he could fix it for $750. I got it fixed by an honest mechanic for less than $100. Good Luck!!
Jul 18, 2012 | Jeep Grand Cherokee Cars & Trucks
AC switch always on for mitsubishi galant
It can be "on" in defrost mode without touching it.
Otherwise, the switch is probably stuck.
Jun 27, 2012 | 2005 Mitsubishi Galant
Hitachi ACE follow me red filter light is always on
the red light turns on automatically after 120 hrs of running to remind us for cleaning the filters. once you cleaned the filters and inserted back , then just keep ac in stand by mode, open the remote panel and press the button on extreme right bottom of the remote ( see carefully in the remote, there is very light image of the filter is made along with the button). red light will go off. no need to press the reset button.... enjoy
Apr 03, 2012 | Hitachi Heating & Cooling
I have a Lynx system with a 5828 wireless keypad that I have connected a 5v transformer to it to keep the keypad lit always. The keypad does not stay lit always and it keeps going to sleep after 10...
It sounds like your 5V transformer isn't working. It could be the outlet it is plugged into isn't working, or the outlet is on a light switch that is turned off, or there is a problem with the keypad itself. The user manual says:
"AC-Powered Operation: When powered by the
optional AC adapter, the keypad remains active at all
times. If AC power is lost, the keypad reverts to
battery-powered operation until AC power is restored
On AC powered units you can get the status by viewing
the display."
The only way I know of to keep it active is by using the transformer.
Hope this helps.
Mar 22, 2011 | Ademco 5828 Wireless Keypad Lynx / Vista...
Radio and gear lights don't always turn on
probably a fuse,thats where to start
Jul 26, 2009 | 2004 Kia Sorento
Measuring Tools & Sensors Logo
66 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
