Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Removing the water pan underneath the fridge.
How do I remove the water pan underneath the fridge to clean it. It stinks!. I have cleaned the fridge, but still smells bad. I think if I clean the water pan, it may solve the problem.
    Genius:
  • 1,198 Answers
You would hope it was accessible from the front, but no. You probably have to roll the fridge out, not breaking the water line, and get to the pan. You may have to remove the paperboard rear cover, usually takes a 1/4": nut driver. Vacuum out all the dust while you're back there.
Posted on Nov 27, 2013
  • 1073 Answers
SOURCE: Whirlpool Top Mount Refridgerator is Leaking
the problem lies behind the freezer back wall panel, remove the panel, the ground (green) wire on the top left corner and the icemaker
all the ice build up under the evaperator will have to be removed, a good hair drier works well, direct the air at the center hole in the bottom of the metal panel all the ice out of the center hole will need to be melted out to be a success it will take a little time. you can pour some water down the hole and if you hear it going into the bottom drain pan then the tube is clear of ice.
Posted on Apr 10, 2008
22yooper
  • 828 Answers
SOURCE: BAD SMELL COMING FROM THE
There is a drain collection pan under the left side behind the toe plate. Remove the drain tray and clean it.
Posted on May 31, 2008
skeetermcgee
  • 5 Answers
SOURCE: i need help!
I had a problem similar to this as well, ungodly stench coming from under the fridge. I figured "must be the drip pan, easy to fix" totally wrong. I spend the better part of about 10 minutes trying to decide weather or not applying force to remove the from grill would break the damn thing or if it would actually come loose. After tugging like a maniac it did finally come loose. then i looked at the drip pan. It was taped down to the metal under cage. Cut the tape and Viola, came right now....NOT... I spend almost a full hour toying with this pan and the water filter and everything else and here is what i found.
To remove the pan you first need to unbolt the water filter holder and move the metal wire connecting it to the frame off to the side. (be very careful you do not pull the hoses out of the filter or apply too much pressure pulling and pull the hoses loose elsewhere) you then must unbolt the wheel that is in that same area as drip pan and water filter. Remove the wheel completely, (i stuck some magazines under the corner where the wheel was to come out of and it rested right on them.) now push the metal bracket holding the pan in place down until it no longer creates an obstacle and then bend the pan slightly as you pull it out. Don't bend the pan too much or it may crack but it actually slides out when pulled if "creased" in the center. It is a real ***** and there may be an easier way to handle this but this is my solution and the nasty pan in now nice and clean.
As far as spraying bleach in there goes i advise against it, the first thing i noticed when i got the pan out was that is said in big letters "CLEAN WITH WARM WATER ONLY." I though this may be more appropriate as a sticker in a place you can read it rather than on the pan you may not be able to get out :)
Posted on Oct 01, 2008
jumptrout51
  • 3361 Answers
SOURCE: Can't get to drain pan for cleaning, whirlpool fridge
You can not acces the drain pan. Por 1/4 cup bleach in the defrost drain hole.
Two days later pour 1/4 cup vinegar in the defrost drain hole.
Posted on Mar 19, 2009
Maytag317
  • 1136 Answers
SOURCE: Underneath the crispers is full
Hi, I can help you through this. Please get me a model # so I can look this up and advise you further. The problem sounds like a plugged drain. We just need to locate it.
Thanks
Vic
Posted on May 30, 2009
How do I clean the drain pan? Why in the world would anyone make a fridge that has a non-removable - and even a non-accessible drain pan? It stinks after awhile and it does need cleaned - even if jus
The "cover" is removable. Once the cover is removed, you can gain access to the pan and remove it for cleaning. The removal process can be a little tricky, but it can be done.
Dec 19, 2014 | Refrigerators
The drain pan under my refrigerator stinks really bad how can i remove it to clean it
The drain pan can be removed by lifting up the refrigerator and removing the four torex screws on the bottom of each side of the refrigerator. Use 2 pieces of 2x4 to hold up each side of the fridge while removing these screws. After removing the screws the bottom panel will separate from the refrigerator and you can remove the drip pan from the panel as it isn't attached by screws. The pan is VERY fragile and removing the drip pan is a two person job. I recommend just pouring bleach into the drip pan to kill any bacteria causing the smell by removing the back panel which will be held on by several quarter inch screws. You'll see the white drip pan on the right hand side of the fridge looking from the back.
Aug 06, 2011 | Refrigerators
I have a Kitchen Aid side by side refrigerator. Under the refrigerator there is a plastic water overflow tray. It collects water and the water becomes foul smelling. I have tried removing the tray to...
You should be able to remove the base grill by opening both doors to 90 degrees and pushing down while pulling outwards on the base grill to unlock the top clips, once the top is away roll the base grill toward you and up. From there you should be able to see the pan underneath which should slide out.
Clean it thoroughly and use a mixture of baking soda and water for final cleaning rinse and replace, I also mix some baking soda and water and pour in the bottom of the fridge to allow the mixture to cleanse the drip tube leading to the pan.
Installation is in reverse of removal
Mar 12, 2011 | KitchenAid KSCS25FKSS Side by Side...
Depression in bottom of refrigerator section beneath vegetble drwers fillwith water and runs ontofloor
The depression is a drain. This leads to a hose that goes to a pan located underneath the fridge. Usually accessed by removing the front panel at the bottom front of fridge. You should be able to see the hose from the top or bottom and use something to clean it.
Mar 12, 2011 | Refrigerators
My Samsung refer RS2630AWW stinks. Can't find source of smell. No drain pan under unit. Any ideas?
In any refrigerator there may be stinks due to lack of cleaning drops of ice cream,buttermilk and milk or any cool drinks which by mistake rest in cooling compartments.
Solution: Remove power. And also empty your fridge. Now with little soap watered cloth(wet) clean indoor compartments all. And Within 5 minutes clean with dry cloth. Keep open the door on sun shine. or in heat room. After 4 to 6 hrs, reuse it. No smell will be there. It's advisable to do this type of cleaning once in 3 months at least. Helpful?
Jan 22, 2011 | Samsung Refrigerators
Bad smell in Refrigerator and cleaned it throughly and it still stinks. Strange since it will get worse then better for no reason. I cannot find a drain in this side by side. If anyone has any ideas please...
The drain is at the bottom inside the freezer section. It is possible a piece of something got behind a panel, or otherwise in a "hidden" spot. Or something is in the defrost water tray underneath and every time it defrosts, it gets wet and releases the odor again. Look in the drain pan by removing the kick plate (bottom grate under the doors) and look in the drain pan to see if anything is there. Use a few open boxes of baking soda in the fridge (to absorb odors), and wipe the inside with some vanilla extract. that combination will help with the odor. But the source of the odor needs to be removed first.
Jan 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
WHIRLPOOL MODELED5VHGXML10 HAS WATER RUNNING FROM UNDERNEATH
is it over flowing on floor ? the pan is the one under fridge on the out side ? it should be full but not over flowing.
find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
Sep 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dripping into fridge from freezer.
Hi. thanks for the question. You have a problem with the drain tube, from the freezer ,to the tray underneath the fridge .Best way to clean. Turn power off to fridge. Let defrost for 24. HRS . pull fridge from wall remove back panel clean all coils locate the drain hose at the drain pan clean . Thanks the appliance doc
Sep 30, 2008 | GE Refrigerators
Water leaking from bottom of refriderator
dear ricurtsmith..
your fridge has a water trap pan underneath it to catch the water from the drain line when your fridge automatic defrost.
either the pan is not in place proper or the pan may not be underneath, period. or pan could be stopped up/need cleaning. or if pan is made of plastic, it could be cracked.
it is located at the bottom of fridge where you see something loos like a grilled vent. remove that bottom piece to get to the drain pan.(it just slides out!!) good luck & hope i was helpful.
brbharo....
Dec 05, 2007 | Kenmore 52642 / 52644 / 52649 Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
100 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
