Question about Woodland Direct CD Vent Free Gas Log Set 360 Series w/Thermostat Remote
Pilot light wont stay lit on gas logs
Pilot light will not stay lit. Was working until we took it out to replace battery for remote control. Replaced the thermocouple but still will not stay lit. Pilot light is good blue flame but immediately goes out when you let go.
  • 38 Answers
One, ensure that the flame is entirely one color blue, no light blue in the center, no orange or yellow. If you replaced the thermocouple yourself, ensure you connected it to the gas valve and/or ensure that the connection to the gas valve is tight. If it is a new thermocouple you may have a gas valve issue, this is uncommon and rare. However, the valve may not be receiving the signal from the thermocouple. If the color of the flame is incorrect, turn fireplace off, and clean out the pilot tube and then relight. If none of this works, call your local trained professional. Remember you are dealing with gas, being cheap can put you in danger.
Posted on Mar 01, 2016
    Genius:
  • 1,198 Answers
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Posted on Nov 27, 2013
My gas log will light on pilot but will not light fully.
Typically, if the pilot stays on and the logs won't light, the thermopile or entire pilot assembly could be bad. If you have an IPI system [automatic lighting system from remote or wall switch] there may be an issue with the control module.
Dec 29, 2013 | Home
More than likely the thermal couple is defective. The thermal couple is a safety device that shuts the gas off if the pilot goes out. If it is defective the pilot light will not stay lit. The thermal couple is the device that the small copper line goes to. It is mounted beside the pilot flame and the flame much touch the TC for it to work. If the flame is not touching the TC bend it until it is in the flame. If it is touching the TC then replace it.
Jul 28, 2011 | Whirlpool Water Heaters
I have a spark and gas coming through on my heater but it will not stay lit...I can light it with a lighter but again it will not stay lit...please help
The pilot assembly may be dirty (dust, lint, pet hair) or the Thermocouple has failed. The thermocouple is a safety feature that stops gas from coning out of the pilot, if the pilot suddenly goes out.
If you can disassemble the heater cabinet, you can access all of the inner workings. To clean the pilot assembly use canned compressed air with a straw nozzle (like you clean your computer with). Blow out the pilot tip and all down the pilot assembly. If you see a lot of dust inside the heater cabinet vacuum it out with a vacuum that has a hose and brush attachment. A crevice tool works well too.
After doing all of the above, reassemble the heater cabinet, and try lighting the pilot. Be sure the control knob is right in the pilot position, when you depress it to light the pilot. If it doesn't go all the way in and your don't feel strong pressure pushing back on it, it's not right in the pilot position. Turn it a hair one way and then the other, until you locate it exactly. Light the pilot as you normally would, hold the control knob in for one minute after it lights, then ease off of it slowly. In the Pilot stays lit, let it burn for a minute before turning it to the ON position. After that, you should be back in business.
If the pilot lights and fails to hold, the Thermocouple will need to be replaced.
Feb 18, 2011 | DeLonghi Heating & Cooling
Pilot light will not stay lit; replaced the thermocouple, still no work. Replaced the W/R gas valve 36C04-222 on my Trane furnace. Still not working. any ideas? Could I have gotten a bad replacement valve?...
Trane unit ,same White -Rogers gas valve. I have replaced both the gas valve and the thermocouple . Have agreat robust blue pilot while the button is pushed in , let go and the flame does not stay lit . I checked the milly D C volts and have better than 20 . Is there a problem with the new gas valve or the couple not generating enough volts or is there a safty I do not know about that could be open ?
Dec 15, 2010 | Heating & Cooling
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
I have a set of propane gas logs. The pilot light
Check the connection of the thermocouple or replace it if connections are tight.Pilot safety valve may be badreplace gas control valve.
Oct 24, 2009 | Desa International CCL3924PTA 24" LP Gas...
Pilot on logs won't stay lit
Hold pilot button longer. if this doesn't work your Thermopile has gone bad and will not generate enough Millivolts to keep gas valve pilot open. A new thermopile will generate 750 millivolts. It cost less than $20 dollars but is difficult to replace. You should call a certified technician. They will charge you about $100.00
Oct 19, 2009 | Desa International Wall/Window Air...
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Woodland Direct CD Vent Free Gas Log Set 360 Series w/Thermostat Remote Logo
300 people viewed this question
Top Woodland Direct Home Experts
Donni Steen
Tom Chichester
Are you a Woodland Direct Home Expert? Answer questions, earn points and help others
