Question about Intermatic Hardware & Accessories
INTERMATIC MODEL EB11R-70
Clock function doesnt work. the dial doesnt rotate with the time
4 Suggested Answers
  • 112 Answers
SOURCE: Intermatic T104R clock not working.
here is a link to the wiring diagram, u may not have the clock motor hooked to the right terminals. http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Posted on Aug 21, 2009
gotgeek2
  • 565 Answers
SOURCE: intermatic model T1O4R stopped working. time dial
Can you turn the load ON and OFF with the manual switch? If not, the circuit breaker supplying the timer has probably tripped. Turn the breaker OFF, then back ON. Sometimes a breaker will trip, but it looks like it's still ON.
If you are getting 240 volts at the timer from the breaker, and if you can also manually turn the clock dial, then the timer motor is bad.
Posted on Dec 27, 2009
SOURCE: The dial on the intermatic water heater timer is
You can replace clock motor on many Intermatic timers:
Snap mechanism loose using metal spring top inside box.
Tip mechanism out and get clock motor number off motor.
Google search specific clock motor number.
Aplus sells many clock motor:
http://www.aplussupply.com/intermatic/timermotors.htm
Electric supply online sells clock motors
http://www.electricsupplyonline.com/prod/intermatic-motors.php
Grainger carries inexpensive clock motors for T101, T103, T104 timers.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
T101 and T103 use 125v motor
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
T104 uses 240v motor
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK2?Pid=search
Posted on Dec 01, 2010
Pool timer clicking but doesnt keep time
If timer dial does not rotate and keep good time, then replace clock motor.
Clock motor is getting weak, and maybe trippers are sticking on on-off lever.
Add a bit of white grease to on-off lever, and turn power off then spray metal gears with bit of WD40. WD40 is highly flammable so power should be turned off.
Copy following links for troubleshoot resources, and clock motor replacement.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 19, 2012 | Intermatic T104 24h 208-277v Mechanical...
Hi, I have few quick questions regarding the Intermatic HB114C 240 Volt, I would appreciate if you can answer my questions 1. Does this unit have Internal Built in Clock to set up the Clock or does...
HB114C timer likely will not work in India.
Contact Intermatic: http://www.intermatic.com/customer%20service.aspx
Plug type is different than found in India.
India power generation is 50 Hz, so timer might not keep time even with plug adapter.
US power grid is 60Hz, so US-sold products are 60Hz.
Some timers are both 50Hz and 60Hz, but spec sheet usually shows that information.
HB114C spec sheet does not show Hz.
http://www.intermatic.com/~/media/files/intermatic/products/fact%20sheets/timers/hb114c.ashx
http://users.telenet.be/worldstandards/electricity.htm
HB114C is analog appliance timer with clock motor that rotates dial once every 24 hours.
The timer does not have a countdown feature.
Trippers are placed on dial.
As dial rotates, trippers move small switch that opens and closes circuit to load.
Current time is set by manually rotating clock dial until current time lines up with arrow located on inner dial.
After power failure, current time must be reset.
There is no way to install a battery back-up inside the timer.
To see images
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
Aug 15, 2011 | Intermatic HB114C Heavy-Duty Timer
I have an intermatic model t106m pool timer switch that has stopped keeping the time. I have checked the breakers and find nothing tripped. The swith can still be manually turned on and off. Please...
Open following link for T106 240volt troubleshoot and repair steps.
Timer is probably repairable if manual override clicks crisp and clean and load turns on-off.
If the timer dial is not rotating or not on time, then replace clock motor. WG number is printed on clock motor.
If dial is rotating on time, then replace 156T1978A trippers.
Jul 03, 2011 | Solar Intermatic Single Pole Model Ej341c...
I installed a new Intermatic 200w powerpack with 15 malibu lights using 131 watts. The lights turn on manually, but the timer doesn't work. How is this possible.
More information is needed.
Open following link for Intermatic-Malibu resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
You say clock doesn't work.
Add a comment with following information:
Do you have timer with analog dial?
Does dial rotate as time passes?
Does dial keep good time?
Have you put the black and red trippers in place?
Are trippers push all the way down?
Have you set current time by rotating clock dial 2 full turns before rotating dial to current time?
Intermatic/Malibu ML series timers come with 5-year warranty.
Product is covered by warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 01, 2011 | Malibu ML200RT - Low Voltage Power Pack...
My timer stopped working.
You posted under Intermatic box-type timer.
You can add a comment with brand and model number that shows inside timer door for best possible answer. Please add what symptoms you observe.
If you have brand different than Intermatic, then add specific brand like Tork or Paragon or GE.
1) For example is clock dial rotating? If not, then tip mechanism out of box and look for clock motor number printed on clock motor.
2) If dial is rotating as time passes, and keeping correct time, then you might need new trippers.
3) Does manual override lever click crisp and clean, or is it stiff and stuck from rust? If override doesn't work, then replace timer.
4) Does manual override lever turn load on-off? If not, then check circuit breaker, and check that load (light bulb or motor) is functioning.
5) You can buy extra trippers and motors by searching for specific number that appears on clock. For example WG1570 or WG1573
For example Grainger sells these parts for T101, T103, T104, T106 timers:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 15, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic T101 timer
T101 timer is strictly 120Volt timer
Wiring and manual show on following link
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
See another image of wiring:
http://waterheatertimer.org/images/T-101-control-120V-Load-450.jpg
Amazon sells T101:
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
If timer is not functioning, add a comment.
Grainger sells 125V clock motor and tripper for T100 series timers.
If manual override does not turn Load ON, and the lever snaps crisp and clean, then check electric circuit. Check if load is operable.
If override does not snap crisp and clean, then timer may be worn out.
If dial does not rotate, replace clock motor.
If dial rotates but does not click override back and forth, then replace trippers.
How T101 works:
Lift and rotate dial until current time lines up with silver pointer
Clock motor rotates dial.
ON-OFF trippers attached outer edge of dial contact a lever.
ON tripper pushes lever one direction.
Off tripper pushes lever opposite direction.
Lever opens and closes electrical contacts.
Lever also pushes manual override lever back and forth with audible click.
Dec 28, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Need manual to set timer
You posted under T-100 series outdoor timer
If you have different timer, add a comment with timer model number located inside cover.
T-104, T-103, T-101 timer manuals show on following page:
If your timer has R suffix, like T-101R, that means box is Raintight for outdoor use.
T-101R and T-101 mechanisms are identical except for box. T-101 box is indoor use.
Click model number and drop-down menu reveals link to manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
If you need simple wiring diagrams, and explanation for each T-104, T-103, T-101 timer:
Here's how to set Intermatic T100 series timers:
Lift and rotate yellow dial until current time lines up with silver pointer.
Silver pointer is stationary at 6 o'clock position.
Put ON-OFF trippers on dial at times you want ON OFF functions.
Minimum on-off is 1 hour because of tripper width.
If timer is not working, add a comment and we'll troubleshoot.
These timers have replacement trippers and clock motors at Grainger
How timer works:
Clock motor, located on back of mechanism, rotates yellow dial.
Trippers on dial push lever that turns power ON and OFF.
Off tripper pushes lever one direction.
ON tripper pushes lever opposite direction.
When lever is pushed, manual override lever clicks back and forth with audible click sound.
Nov 29, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I having troble with my t103 timer to turn the lights on manualy i try to set the timer but for some reason doesn't work what can i do ???
T103 Intermatic timer has 120Volt clock motor and can control 120V or 240V Loads.
Wiring for timer is shown on following link:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Troubleshoot T103:
1) Manual override is working correctly, and it snaps crisp and clean, and Load turns on-and-off.
That means timer is basically good.
2) Next look to see if yellow dial is rotating.
If dial is not rotating, then 120Volt clock motor needs to be replaced.
Take photo of wiring and mark wires before starting.
Remove two white wires connected to screw terminals 1 and A.
Snap timer mechanism out of box, clock motor is on back of timer.
Use small star screwdriver to remove old clock motor.
Reattach white wires on terminals 1 and A, tighten screws very tight.
Reset current time: lift and rotate dial until current time lines up with silver pointer.
Grainger sells 125V clock motor:
3) If dial is rotating, but gets stuck at certain times, or runs slow, then replace clock motor.
4) If dial is rotating, and trippers are attached to dial, but timer does not turn ON, then trippers are worn down and need to be replaced.
Grainger sells the T103 trippers
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
5) How Intermatic mechanical timers work:
Dial with ON-OFF trippers is rotated by clock motor.
Trippers on dial contact ON-OFF lever.
OFF tripper pushes lever opposite direction.
Lever moves electrical contacts on back of timer that turn Load ON-OFF.
Manual override lever clicks back and forth with each ON-OFF action.
Nov 20, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
I've set the time on/off and ive tried turning on manually but the lights wont turn on on exact time set. y? when i manually turn on the lights come on 2 hrs later or so, y doesnt it turn on right away?
If I understand correctly, you have an Intermatic timer.
The timer has a yellow dial that rotates around like a clock.
Does the manual override work?
If yes.
a) then the circuit has electricity
b) the lights are in working order
Does the clock rotate?
If yes
a) then the timer is probably good
b) the clock motor could be bad
c) the gears could be rusty and dirty
Do you have the current time set correctly?
Lift and rotate dial until current time lines up with silver pointer.
Do you have the trippers set on the correct time?
There are ON trippers and OFF trippers
Attach trippers to correct time
Tripper pins wear out
Suggestion: You sit in front of the timer and watch the trippers as they rotate to the bottom of the dial
When the trippers get to the bottom, they push a lever that turns lights on and off.
Look at the photo:
Here's a website that sells tripper pins and clock motors for Intermatic timers.
You can buy new trippers or clock motor
Answer this post if you still can't figure out the problem, or need more help.
Oct 23, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
177 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
