Window unit will not turn on/work. Restart button keeps popping out when plugged back into wall. No lights will function.. the usually thermostate lights etc. when plugging into wall sounds like it wants to start but just for like one second then nothing. What could this be? (Whirlpool ac unit ACQ189XS0) ANY HELP APPRECIATED! THANKS AHEAD OF TIME.
  • 158 Answers
Something is shorted or earthed, must call techncian
Posted on May 08, 2009
The reset button keeps popping when I plug in the unit? It won't turn on
when the reset button pops it indicates an over load situation and it works to prevent further damage to the unit
could be a start run capacitor failed or the compressor seized
call an ac technician for a check and a quote
May 28, 2016 | ACE Artic King Window Mount Air...
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
My airconditioner has been on energy saver for almost 2 days and will not come on what should be do
If this is a window or wall unit. Turn the Master ON/OFF Switch to OFF. Unplug the unit and wait 12-15 minutes. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls on anything except energy saver. If the unit then operates as it should, let it run for at least an hour before switching it to Energy Saver Mode. If that's the way you want to operate it. If it doesn't restart and run like it should or it shuts OFF on Energy Saver Mode, there is a problem with one of the setting sensors and needs to be replaced.
Also, while you have the unit unplugged, check the outlet to make sure it's still active. You can do this by plugging in a lamp. If the lamp doesn't work, the circuit breaker for that outlet has been tripped in your home's circuit breaker panel and needs to be reset. When you plug the AC unit back in and it trips the breaker again, there is an electrical short or overload in the AC Unit.
Please keep in mind everything I suggested is based on your AC being a 120 volt window or wall unit.
Hope this helps you solve the problem.
Apr 13, 2011 | GE Heating & Cooling
No power. will not come on at all. already checked the breaker box. all is good. whirlpool ler4634jqI
on the back of this unit the panel can be removed...it requires unplugging unit and taken plate off of cord area and several screws from back panel.remove it and down low usually there is some limits that go bad...if you are not getting anything to happen most likely it is the high heat thermal cutoff which looks white in color and plastic usually it will either be near exhaust outlet in back or you may have to remove from panel and it will be on exhaust in front...while your in back though go ahead and check your heater and thermost on the heater should give you a reading and have continuity if good. and will be open if bad... most likely the thermal fuse though..good luck to you
Jan 08, 2011 | Whirlpool LER4634J Electric Dryer
Genie excelerator light won't turn off...
First unwire the wall button. If the light will go off now replace the wall button. If not then you will need to replace the logic board on this unit(genie.com for replacement). Protect this with a surge protector as well 900 joules or higher. Thanks BB
Jan 21, 2010 | Genie Company Genie PowerLift Excelerator...
Restart button kenmore he 3
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 14, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My little son been touching all buttons... now when i switch on all light are lighting. how can i reset???
May 02, 2009 | Washing Machines
Lights on Washer Machine flash but Washer doesn't work
Mar 31, 2009 | Kenmore Washing Machines
Help
go to sharpusa.com and click on support, they have all the model airconditioners and all the help. its in pdf format and i dont know how to paste the info. really easy problem to fix.
Basically, tells you to make sure air filter is clean.Unplug from wall, then hold Power/on/off button down and plug unit in wall. press Power/on/off button until you hear a beeping sound(approx 5 sec) then disconnect powerplug from wall. plug back in and start your ac again. it should work!
If this dont work try the same thing but by pressing the Mode button and same kind of operation as above, but the unit will start to operate after you press mode and herar the beeps. turn off by pressing On/off button. then start as normal. if you cant get it go visit the website.
Jul 16, 2008 | Sharp ENERGY STAR AF-S60FX...
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
