Question about Xerox Phaser 7400/DXF Laser Printer
Hi, I am trying to get my Ipad to print from a xerox phaser 7400. The problem I'm having it keeps trying to print from the manual feed tray 1. This isn't possible as the printer is in a cupboard and there is no access to that side of the printer. Is there any way I can force it to print from tray 3 by changing settings? Or even bypass tray 1 completely as it is never used. I have already tried changing the paper type of tray 1 to something unsuitable. Thanks for any help you can give me with this.
  • 3 Answers
Try going in settings and fiddeling aroung :)
Posted on Nov 26, 2013
4 Suggested Answers
  • 2072 Answers
SOURCE: xerox phaser 7400
Remove the tray, first look for a piece of paper that has come out of the tray inside the tray area.
Make sure the rolllers are snapped into place. The easiest way to verify that is to remove another tray and compare them.
Look to see if all the switches and actuators are in place.
Make sure you hear the tray up motor running when you close the tray.
Also inspect the paper tray itself for broken items. Compare it to another tray.
Posted on Feb 04, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 7400
That is caused 99 percent of the time by the fuser.
There is a solid aluminum roll and a silicon rubber ( pressure) roller in the fuser. The pressure roller either developes some flat spots from park ( non running) time and over time heat and use cause it to deform and become out of round. What then happens is when the paper enters the fuser it does so with a slight twist, and the pressure of the fuser, for lack of a better term, Irons in that crease during the fusing process.
Gave the explaination so you would understand what is happening.
Posted on Mar 07, 2008
wrinaldo
  • 185 Answers
SOURCE: Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Posted on Aug 10, 2010
Can I print to the edge with Phaser 7400
No this is phisically impossible, try a larger sheet of paper and cut it
Mar 17, 2013 | Xerox Phaser 7400DN Laser Printer
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
We have a Xerox Phaser 7400. The output is dirty along the bottom 1/2 inch of the page.
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. If the issue is there at that point then it would point to loose toner residue underneath the cartridge. if not then the fuser area has to be cleaned. Wipe the area clean with a lint free cloth, do not use compressed air.....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 04, 2011 | Xerox Phaser 7400/DXF Laser Printer
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 7750 - Tray 1 streaks on prints
If you put Tray 2 in Tray 1's spot with the heavy stock in Tray 1 (now in tray 2's spot) and print from it, does the problem persist?
This may help...
http://www.support.xerox.com/support/phaser-7500/support/enus.html?objGUID=4538
May 16, 2017 | Xerox Phaser 7750DN Laser Printer
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
Envelope printing
The manual bypass tray on the Phaser 8400 can be set only when you have paper in the tray.
The envelope will read in the set up when you have it in the tray.
Nov 12, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Phaser 7400
The closest I can find to your description is a U6-0 and the suggestion is to replace the transfer belt assembly,
Feb 11, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox phaser 7400
Feb 03, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400/DXF Laser Printer Logo
61 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
