Question about ECHO, Inc. 20 In. Double Sided Hedge Clipper
Echo hedger bogs down after running for a few minutes
Runs good for a few minutes then bogs down for a minute then runs good for a couple of minutes then bogs down again
    Genius:
  • 1,198 Answers
Keep a can of WD 40 handy, spray the workings regularly. Shrubbery is sticky.
Posted on Nov 27, 2013
Bogs down after warming up
check exhaust port first. then carb adjustments, then either crankshaft seals or carb needs replaced... You cannot adjust carb, it has to go to a certified center for this procedure... Thank the EPA for this B.S. and no you cannot by the adjustment tools on Ebay.
Nov 26, 2013 | Echo Garden
Engine runs for a few minutes then stalls...
It sounds like vapor lock or other lack of fuel. Premium gas will cause detonation and "may" have something to do with it. Drain the fuel the best you can and add regular fuel, after a couple minutes the engine should be burning mixed fuel and if the problem goes away you have fixed it, if not you obviously have other issues.
Jun 19, 2010 | Craftsman 2500 PSI Briggs Stratton...
89 jetta boggin down when runs for a minute or two
Check the fuel pressure with a gauge and see if the pressure is dropping during this bog. This would be the first place to start a diagnosis.
Apr 14, 2010 | 1989 Volkswagen Jetta 2 Door
Echo CS-440 Chainsaw. Was cutting firewood, saw running fine until I refilled the gas tank. The gas was a few months old but looked clean and smelled OK. But after I filled the tank could not get the...
unleaded fuel is notorious for going stale,and it can leave a resinous coating in the carb-try running the saw on half choke with new gas and less oil eg 50 to 1 for say ten minutes,this should clear the gunk out-if this does not work,you have two choices-strip and clean the carb,or adjust the H (high) scew on the carb anti-clockwise by a quarter turn a time till it revs out full bore-good idea to remove the chain and wear ear defenders when adjusting-and always use a chainsaw at its max rpm,or you run the risk of "kickback"
Feb 25, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
2006 Arctic Cat ATV dies after about 15 minutes of riding
Sounds as if the gas tank is not breathing properly. The next time you run it, when it's about to die, loosen the gas cap. It should begin to run again. This is a sure sign that your gas cap is clogged. Clear gas cap of debris, or buy a new one.
Jim
May 30, 2009 | Swisher Atv Tru Plow
It Sounds like your Stator is going bad.
I would have it checked/Diagnosed by a Local Shop.
May 12, 2009 | Sport & Outdoor - Others
ECHO, Inc. 20 In. Double Sided Hedge Clipper Logo
293 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
