Washing Machine will not start
Washing machine Tricity Bendix AW 1260 W, about 10 years old. No problems till yesterday, when a few seconds after starting a program, a sharp crack was heard - possibly a bit like the noise of a fuse blowing. The program did NOT appear to stop at that point, but my wife switched the machine off anyway, fearing possible safety issues. Subsequent attempts to start the machine have been unsuccessful. What happens now is:- Switch power on at mains. Set program, all the relevant indicator lights function normally. Start/pause light flashes, to show machine is waiting for Start button to be pressed. Press Start, and instead of the wash program beginning, the door light gives a repeating four flashes. According to the manual, this can mean that the door is open, or (presumably in this case) that there's a fault with the machine.
  • James Woodfield
    James Woodfield Dec 02, 2013
    Hey Don, I haven't been able to find anything at all obviously wrong with the machine, and no valid excuse for it having made the loud cracking sound my wife heard. So there really isn't any valid excuse for me dismissing your door switch diagnosis so hastily either; and I'm sorry to have done so. I've ordered another one as you suggested, so that I can try it. I'll report back. Thanks again, James
  • 3 Answers
Either your door actuator is broken or the door switch itself. look at the door and see if the latch(actuator) is broken or loose. If not order a door switch. It can be changed easy if you remove the retainer from the bellows and loosen it from the front of machine.
Hope that helps
Posted on Nov 26, 2013
  • James Woodfield
    James Woodfield Nov 26, 2013
    Thank you, Don, but the door isn't the problem here. On this machine, if the door's not shut properly, the door warning light flashes when you're trying to set the program. What's happening here, ever since that loud crack I mentioned, is that the program setting stage progresses normally. Once you press the start button, THEN the door light flashes, because it has a secondary role as a malfunction indicator. Perhaps there's some kind of fuse inside the machine which could have blown for some reason? Or maybe a coil in the pump or drum motor?
4 Suggested Answers
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
smitty5609
  • 243 Answers
SOURCE: Power light is on but nothing happens - indesit iwme12
Even if the door does lock it may not be sensing it, hense the flashing lid lock light.
Posted on Sep 25, 2011
Drum won't spin on Tricity Bendix AW 1260W washing machine. What do I replace? Is it worth it? Machine is 7 years old.
Hi just food for thought,I normaly fix my things that are brocken,but I was told by a washing machine teck that the life span is usuely 5years,some times you get lucky and other times it gose wrong and you keep throughing money down the drain,I wish you the best and hope it works out for you if you deside to try and fix it.
Nov 21, 2016 | Tricity Bendix Washing Machines
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
How to take back off tricity bendix aw 1000 w
Tip the machine on it's side and fit it from underneath. It's a bit fiddley.
Dec 13, 2012 | Tricity Bendix AW1000W Front Load Washer
Bendix BIW 105w You put on to setting, start light comes on then end light comes on few seconds later.
think you need a service engineer with their laptop to plug into it on this machine as its all electronic
Oct 10, 2011 | Tricity Bendix AW1000W Front Load Washer
Trying to organise changing brushes in Tricity Bendix AW 1400. I'm in Scotland, daughter and machine in England! Does top or back come off machine to allow access and is motor fairly accessible for...
Washing machine motors are usually induction motors and do not have brushes? Anyway, the back comes off and that normally gives access to the screws that hold the top on, but the motor is normally located at the bottom of the machine.
Feb 14, 2011 | Tricity Bendix AW1400W Front Load Washer
Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Apr 20, 2010 | Tricity Bendix AW1000W Front Load Washer
Bendix 1500 series Washer is leaking from bottom
It is now Tricity Bendix, and comes under the ZANNUSI name.
Try looking under Zannusi in your directory
Nov 25, 2008 | Tricity Bendix AW1054 Front Load Washer
Tricity Bendix washing machine AW 1000 W
remove the rear panel 4 screws and you will see it on the lower of the drum.
Feb 09, 2008 | Tricity Bendix AW1000W Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
