Question about Vacuums
Vax bare floor pro
The steam has become very limited when using it. Has a filter become blocked?
    Problem Solver:
  • 12 Answers
Yes you will need a replacement filter,the one you have is probally blocked and can not release the steam because of it..Good luck
Posted on Nov 27, 2013
2 Suggested Answers
  • 3 Answers
SOURCE: Vax steam mop pro
maybe if you set fire to it, you would get more steam.
Posted on May 13, 2013
How do iput water in a vax hard floor advance+steam cleaner s3s+
look for a big knob that you can unscrew. When you locate this knob unscrew fully and add water......then screw tighten and you are ready to turn on appliance.
Dec 06, 2014 | Vax Vacuums
How do I put water in a Vax steam hard floor mop
GO HERE> http://www.vax.co.uk/video-gallery/
Sep 30, 2014 | VAX Appliances Vacuums
Why is the steam is not coming out in 45 mins of use half a tank of water is not being used
poor quality, poor track record of durability, not repairable. Why do people keep buying these things and expect them to actually work ?
Sep 22, 2014 | Euro-Pro Shark Cordless Bare Floor & Low...
Vax floor steamer is not steaming
First check the fuse in the power point plug, and replace if necessary. If ok, then it is either a loose or disconnected electrical wire, defective on/off switch, or a burnt out heating element.
Aug 26, 2014 | Vacuums
Vax steam mop pro
May 13, 2013 | Vacuums
Can I use my steam mop on laminate floors
Yes, it works great on laminate floors...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Sep 12, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Using the Shark steam cleaner on floor with unsealed grout
Yeah it will work fine...
heatman101
Jul 09, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Is it safe to use shark steam Pocket Mop on Armstrong Vinyl no wax floors?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Yes, you can use it it will not hurt that floor...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Jan 11, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Vacuums Logo
178 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
