Av cables speaker diagram - Audio Players & Recorders
Jukebox speaker jupiter diagram c96
Posted on Dec 28, 2013
How to wire up speakers
TVs have a low level output and cannot generally drive speakers directly. You need some kind of speaker kit with an AV amplifier or surround sound system. You would get an optical or electrical cable and diagrams of how to wire them up.
Sep 04, 2014 | Televison & Video
Audio not ok pic ok
Hi ,
Check problem is in AV mode only or both AV and RF
If both mode problem is there follow the bellow
Other wise problem May RCA cable (AV cable)
I f you are able to open TV check speaker using a Multimeter (Tv should be OFF) continuity mode,is it shows 2 ohms or below speaker is ok, problem may be audio section of your TV.
Thank you
Apr 22, 2014 | JVC AV-21meu 21" TV
JVC AV21AT NO SOUND PIC OK
Hi ,
Thank you
Apr 22, 2014 | JVC Televison & Video
Speaker diagram
Some Subwoofer accept stereo line in, and hi end may need 4 channel line in direct from your head unit, its depend on which type you AMP is?
Nov 26, 2013 | Car Audio & Video
Black diagram of av-502a
front: 500 watts/channel
surround: 30 watts/channel
center: 30 watts
Jun 22, 2013 | Audio Players & Recorders
Alright well I have a Numark rack mount dj set with two CDN95 2 disc players. Well I bought it used with speakers and everything and do not know how to plug everything, I really need some help please...
As shown in the Quick Start Guide (link below) this unit should be connected to a Mixer Unit.
http://www.numark.com/stuff/contentmgr/files/0/662529d8e9e5b8ebe1747274e5bad9d6/file/cdn95_quickstartguide.pdf
Looking at the Diagram they appear to be standard AV Cables so you should just be able to plug the CD Outputs into the Amp AV Inputs (as long as it's a Dual Amp) and then connect your speakers to the Amp (make sure the speakers impedance matches the Amp.
Further details available at http://www.numark.com/cdn95?tt=5
Please leave feedback
Cheers
Andy
Apr 25, 2011 | Numark CDN95 2-Disc CD Player
Need wiring diagram for bass w x 10
You have not mentioned what equipment you would like to connect to this active subwoofer.
Assuming you have an AV Receiver, you will require a single long RCA to RCA subwoofer cable. Connect the left input (white socket ) of the subwoofer to the AV Receiver subwoofer pre output.
Leave the front crossover knob at 100Hz , Phase at 0. While playing an audio track slowly increase the subwoofer front volume to suit your taste. If you are using big floor standing speakers along with the subwoofer reduce the crossover frequency to 70Hz. Phase should be adjusted to blend the front speakers with the sub.bobhifi_6.jpg
Mar 09, 2011 | SpeakerCraft BassX-10 Subwoofer
Hey, my old tv blew out so i plugged in my tv in the kitchen to my bedroom. It is an older jvc television. It worked fine for a few days then the sound just quit working one night. I have messed with it...
Recheck all AV cables connections?Common problems,take all the AV cables connections aparts and clean it replug it in or AV cables are damage and shorted,change the AV cables.
Oct 11, 2010 | Televison & Video
Reciever turns off
Powering off usually points to issues with speaker setup. You should read pages 42 and 96 of the 606 manual.
Page 42 covers impedence settings. Check your impedence settings for your speakers. The 606 handles speakers from 4 to 16 ohms. There are two impedence settings on the 606 - 4 ohms and 6 ohms. Set to 4 ohms if your speakers are 4 ohms or more but less than 6 ohms. Set to 6 ohms if your speakers sit between 6 and 16 ohms. Incorrect settings can result in the 606 going into power protection after prolonged use or at higher volume.
Page 96 covers testing for unexpected power protection. You should switch off your AV at source and leave for an hour. Disconnect all cables to speakers and other peripherals (TV, DVD et al). After an hour turn on AV and turn volume to MAX, If the AV remains on, turn down volume to min, switch off AV and reconnect all devices. Make sure the speaker cables are properly connected and that no bare wiring is exposed.
Once you have done this switch on the AV and turn to volume to MAX. If the AV stays on then problem solved. If the AV switches off then you should contact your supplier.
Nov 24, 2008 | Onkyo TX-SR606 Receiver
 Grubhead
Grubhead
