Question about Brother FAX-575 Plain Paper Thermal
Panasonic kx-ft981 contact number save - Brother FAX-575 Plain Paper Thermal
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
Panasonic kx-ft981 ,no print out and copy.
Panasonic kx-ft981 ,dark print out and copy.
Jun 23, 2012 | Office Equipment & Supplies
Problems with panasonic kx-ft981 fax machine
my panasonic kx-ft981 get trouble with paper jam, i change with different paper fax it still paper jam... plz help
Mar 17, 2012 | Office Equipment & Supplies
Panasonic KX-FT981 our Fax phone has no ink any more. where do we get ink and hoe to put it in the fax phone?
Maybe I'm missing something here, but your machine appears to have a thermal printer. If this is so, there is no ink to replace. One simply buys a roll of thermal printer paper from your office supply store, or order it online. A search for 8.5 inch thermal paper turns up several listings for the paper. If this is another type machine, sorry.
Oct 21, 2010 | Panasonic Lands Phones
Panasonic fax model KX-FT981
the machine showing memory full . how clean memory
Jul 15, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Using the fax machine of Panasonic KX FT981, how can i add a contact (including its number) into the phonebook ?
Panasonic KX FT981
I am unable to rcv fax message because memory full messsage is diplaying.
How to delete memory
Pls help
Feb 24, 2010 | Office Equipment & Supplies
Programming kx-tga230pw
1: Press Mute/Function
2: Press the right arrow key at Save Directory
3: enter up at a 15 char name with the number keys, press the down arrow and enter the phone number.
4: Press down arrow again, and then the right arrow to save.
A beep should be heard to confirm it was saved. Repeat from step 2 for more numbers.
Jan 02, 2009 | Panasonic KX-T7630 Corded Phone
Panasonic KX-TG2357
To open phone remove the 2 crews at the bottom, then pry open using a screw driver to unlock the internal fasteners. then remove 3 internal screws. Clean-up the PCB key and the back of the keypad with Acetone. This works perfectly. Saved me $150 on a new set.
Oct 06, 2008 | Panasonic KX-TG2357 Cordless Phone
Panasonic phone KX - T7630 - memory
Of course it's possible. Maybe the PROG softkey is a start. That an a manual.....
Carl
Aug 11, 2008 | Panasonic KX-T7630 Corded Phone
Brother FAX-575 Plain Paper Thermal Logo
24 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
