Question about Motorola Mobility Dect 6.0 Digital Cordless Phones Model L603 M
Which converter/adapter to use for cordless phone bought in US
I bought Motorola L 603 M cordless phone in USA and want to use it in India. The phone requires 117V 60Hz 35 ma input whereas in India we have standard 220V 50 Hz output. Hence just want to know which adapter or converter I need to use to make this phone work in India.
Why am i unable to connect to my motorola L603m and theres no power supply
Contact The point of purchase. The phone should come with a charger. Or you can contact Looking For Help to find a replacement.
Mark
Motorola Support
May 12, 2014 | Motorola Mobility L603m Digital Cordless...
My uniden phone bought in USA does not display called ID thouhgh BSNL has enabled it. My cheap chinese phone was displaying it. Any help?
Caller ID standards are different in India and the USA, so Caller ID function will not work. You need to purchase a converter which converts from DTMF to Bell FSK standard.
Source
Good Luck!!!!!!!!!!
Oct 18, 2009 | Uniden DECT 6.0 Cordless Telephone...
I too have the same problem
Well like you said, USA and India.
Did you check the power voltage from usa compaired to India? You might have just blown your system if you didn't pay attention to that.
It's not recommended to take outside of usa, but if you do, you should have bought a power converter/adapter.
Sep 07, 2009 | Nintendo Wii Console
Model purchased in USA and installed in India. Caller id is subscribed and other phones shows the calling number but this phone KX-TG6431 does not
Only stupids buy cordless phone from USA. India uses ETSI DTMF standard for Caller ID which is not supported by any cordless phone sold in USA. It is about time you trash your worthless instrument in the dumpster.
Jun 06, 2009 | Motorola Mobility 5.8 GHz Digital Cordless...
Configuring caller IDfor India
Were those other instruments purchased in India? The problem is that the U.S .uses a different"signal" to send caller ID than India.
May 28, 2009 | Panasonic KX-TG9331T Cordless Phone
The id caller is not working in that cordless phone
Any Caller Id phone bought in USA will not show the id as the Caller id format in USA is FSK and in India it is DTMF. You need a caller id converter from DTMF to FSK. It is available online on www.ebay.in Just type DTMF to FSK converter and the item will be displayed. Right now it is avilable only with a seller in Bangalore and the price is Rs.589/- per piece. I bought it and it is working fine.
Aug 24, 2008 | Panasonic KX-TG1100 Cordless Phone
Caller id not working
US phones use Bellcore FSK caller id. India uses DTMF caller id. Buy a DTMF- FSK converter at a telecom shop.
Jan 05, 2008 | Motorola Mobility 5.8 GHz Digital Cordless...
AREA CODE
Just purchased the GE 25922 today. Looks like you can skip (ignore) the option to enter an area code.
United States' Area Codes are three-digit numbers. If the phone 'requires' entering a number you can use any three digit number. The purpose of this option is to display a local telephone number with only the 7 digits.
Example:
603 - 123 - 4567
'603' is the area code
123-4567 is the 7-digit local number.
If the area code option is programmed to '603', then if that number called '123-4567' would display on the Caller ID display.
Which now reminds me: you would need to also subscribe to Caller ID with the Telephone Company for the numberic display to occur.
Oct 27, 2007 | GE 25922 Cordless Phone
Caller ID not working in India
I too purchased an Uniden phone for India. Everything except the caller ID works fine. The caller ID wont work as the technology used in India is different. Try purchasing a FSK to DTMF converter or a separate caller ID box.
Oct 27, 2007 | Uniden TRU9480 Cordless Phone
Motorola Mobility Dect 6.0 Digital Cordless Phones Model L603 M Logo
52 people viewed this question
Top Motorola Mobility Lands Phones Experts
Motorola Mobility
Motorola Mobility
Eric Sutherland
Level 1 Expert
Ngoro
Ngoro
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
