BD-9388 mouse not working
Light flashes but won't appear on screen
I have a lawn mower engine model 98963 type 9388 code 97698891 is there a filter inside the petrol tank ore where fitted motor starts then after short period cuts out appears not getting petrol
I have a 5hp B&S and was experiencing fuel leakage problems
when I pulled the hose of the tank fitting to fit a tap, I found a small filter up the tube and held in place by the rubber hose
IT is extremely fine and about 3 mm in dia so it is possible that you could have one and it is blocked
Jun 04, 2016 | Garden
Mouse won't function at all
Buy a new one and see if that cures the problem.
Jun 05, 2017 | Dynex Computers & Internet
Instructions for sony bd remote control
You can also plug in your Keyboard/mouse (any usb type keyboard and/or mouse will work with a PlayStation 3). That will allow you to navigate the PS3 XMB Menu, as follows:
1) Prepare the BD Controller.
2) Go to: (Settings) > (Accessory Settings)...
3) Select [Register BD Remote Control].
4) Follow the on-screen instructions to register the BD remote control.
When the registration, or pairing, is complete, your system will assign a controller number to the remote.
Hints
  • You can register only one BD remote control at a time. If you register another BD remote control, you will overwrite information on the currently registered device.
  • After you reach the maximum of seven active wireless controllers, you cannot register or use a BD remote control.
  • Registering the BD remote control with another PS3 system will clear the device registration from the first PS3 system.
  • For details on the BD remote control, refer to the instructions supplied with the remote.
Jul 24, 2012 | Sony BD Remote Control for Playstation 3
Screen won't work
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 26, 2012 | OQO Computers & Internet
The power went out here at work and my acer desktop wouldn't log into anything (ie email, internet) when the power came back on. So I clicked shut down and it turned off but now it won't turn back...
try taking out all peripherals like mouse printer keyboard leave screen pluggged n then press and hold the power button for 2 minutes then plug in your mouse and keyboard and see if it boots hope this helps
Sep 14, 2011 | Acer Aspireā„¢ T180 PC Desktop
I want to change region code from 3 to 5vikrammehmi
Turn your BD on without cd in it, wait until appear no disk on screen.
Use this combination : Repeat-5-6-7-3-2 ,
on screen will appear 3, than press 5.
Or if it not working, Repeat-5-6-7-3-2-Repeat-5.
Good luck.
Apr 02, 2011 | Samsung BD-P1600 Blu-ray Disc Player
My HP mouse is plugged in and the red light is on but I do not see the arrow on the screen. What is wrong?
Hmmm... if you are using a different mouse on the same pc and it works odds are your HP mouse is fried. Just out of curiousity and to confirm that the USB port that the HP mouse was connected to is not damaged, insert the Logitech wireless USB receiver into the HP's port and see if it still works.
If it does I suggest replacing the HP mouse. There are a number of factors that could've killed the mouse from USB power surge to rough handling, etc.
BD
Sep 02, 2010 | HP (A2839B) Mouse
MODEL 96150 , PROBLEM":LIGHT FLASHES ON MOUSE ONLY. tHE SMALL DEVICE INSTERTED DOES NOT FLASH. AND THE MOUSE ARROW DOES NOT MOVE AROUND SCREEN
ODEL 96147 , PROBLEM":LIGHT FLASHES ON MOUSE ONLY. tHE SMALL DEVICE INSTERTED DOES NOT FLASH. AND THE MOUSE ARROW DOES NOT MOVE AROUND SCREE
Aug 06, 2009 | Verbatim 95208 Mouse
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
