Question about Microsoft Excel for PC
Excel 2007: Conditional formatting
I've created a worksheet using conditional formating to display Bold or Italics font depending on the cell values. Works fine until I incorporate that worksheet in a multi-sheet workbook where references are made to cells in other sheets. The conditional formats no longer operate after saving the workbook. Microsoft office displays a message "cannot apply conditional formats in linked worksheets". Is there a way around this problem?
  • grenfletch May 11, 2009
    Yes - gave names to cells in sheet1. Certain cells in sheet2 were set equal to these named cells and conditional formats applied using "cell value is..." Appeared to work OK but after saving and reopening formats didn't appear to act. Problem seems to be related to having linked sheets because works OK with only one sheet in the workbook.
  • 152 Answers
Did you put the sheet name in your reference? ex =Sheet2!A1 or you can name the cell ranges on the other sheets and use the cell names in your conditional formatting formla.
Posted on May 10, 2009
  • Dave Herard
    Dave Herard May 11, 2009
    can you send the formula your using or a copy of the spreadsheet?
IS THERE A FORMULA IN EXCEL THAT WILL HIGHLIGHT CELLS THAT MATCH A NUMERICAL INVENTORY LIST?
One way would be to create a colunn C and use the formula: =COUNTIF(B$2:B$200,A2) in cell C2. Then copy the formula down to C200. (assuming you have 200 entries in B...). This will put a "1" next to every number in Column A that has a match in column B. Then you could put a conditional formula in column A that will highlight the cell if the value in column C is equal to 1. Alternatively you could also simply filter for 1's in column C and then manually highlight the cells that show up in A!
Sep 16, 2014 | Microsoft Excel for PC
Dear specialists, I've faced with error with BO Report: The excel file is updating every 15 minutes, but since yesterday BO creates corrupted excel file. Status of appropriate schedule:...
Excel unable to read file is able to resolve Excel repair worksheets, fonts, formulas, cells, columns, rows and etc. Software gives back excel data crashed by any reasons: viruses, incorrect actions anti-virus software, hard drive failures. Tool has the compatibility with Windows 98 and higher. Its interface doesn't require special skills and is simple for novices.
Jun 03, 2011 | Business Objects BusinessObjects...
Conditional formating to highlight problems.
in Excel 2007 and if you have a cell (say C2) with the value of elapsed time (for example set = A2 which contains start time plus B2 which contains end time - or current time) - click in the cell (C2) then on the Home tab click on Styles >> Conditional formatting choose Highlight Cells Rules>>Greater Than... set your value in the dialog to your respective value and choose your highlight. This is a start - you can then add new rules.
to then apply this same conditional formatting to every cell in that column Ctrl-C to copy the cell you just formatted - then click on the column header to highlght the entire column - Right-click and choose Paste Special - then choose Formatting for what to paste.
It's slightly different in Excel 2003 so let us know what version you are using.
Cheers.
Feb 27, 2009 | Microsoft Office Standard for PC
I have a new PC using Works 8.5 I have a problem with loss of formatting when I do a dabase report output, and paste it to a works spreadsheet ( or to an Excel 2007 spreadsheet) All larger fonts and bold...
You may be able to set the cell styles for every workbook/worksheet. Take and re-format your exported spreadsheet the way you would like it to look, then highlight those cells and poke through the menus until you find the cell formatting options (I don't use Works that much, so I'm not sure of the actual menu path) and see if there is an option for formatting those cells in that manner as a general default cell format.
Feb 09, 2009 | Computers & Internet
Need Formula
TEXT CASE
Convert to UPPER, Proper or lower
Auto Convert to UPPER, Proper or lower
Stop VBA Being Case Sensitive
SELECT CASE VBA
Select Case Statement. Great alternative to Else If Statements
CONVERSION
VBA: CBool(),CByt(),CCur(),CDate(),CDbl()Double,CDec(),CInt(),CLng(),CSng(),CStr(),CVar().
Example
dDate=cDate("25-Jan-07")
Convert Numbers to Words
Convert Numbers to Dollar Amount in Words
Spreadsheet Converter. Versions: HTML/JavaScript,Excel ASP.Net and Excel Java/JSP. $
SQL Database Migration $
Converters. Database Converters, Spreadsheet Converters, Text Converters, E-mail Conversion, Document Conversion, PDF Conversion and more! $
CSV Converter $
IMPORTING
Import SQL Into Excel-SQL Tester $
Import Excel Into Access $
CONDITIONAL FORMATTING
Conditional Formatting
More Than 3 Conditional Formats
Conditional Format Fonts for greater than 3
CUSTOM FORMATS
Custom Formats
Excel see a cells format as having four Sections. These are, from left to right: Positives;Negatives;Zeros;Text.
To hide zeros cell-by-cell use a Custom Number Format like 0.00;-0.00; where 0.00 is desired format for non zeros. Note the use of -0.00 for negatives.
To hide zeros on the Workbook level go to Tools>Options>View - Zero Values.
Dec 15, 2008 | Microsoft Windows XP Home Edition
http://chandoo.org/wp/2008/03/13/want-to-be-an-excel-conditional-formatting-rock-star-read-this/
Go down to the section about highlighting where there's an error. That's the basics of what you want to do. Now you need the code:
This will set a value of "True" if the string is -not- found inside. So if you want to flag it for finding the word NOT, you want the conditional formatting to kick in if the value of this is FALSE.
=iserr(find("NOT",A1))
Dec 06, 2008 | Computers & Internet
Need a formula for excel
select CONDITIONAL FORMATING in Format
select FORMULA IS , CELL VALUE = > < (condition)
after this select Format
font style , COLOR
SEE IT WILL WORK CHANGE OF COLOURS ........
Oct 10, 2008 | Microsoft Excel for PC
Forgot password to open Excel sheet
If you mean that you can open the Workbook and read the Worksheet - then all you have to do is select all and paste it to another Worksheet. This will allow for changes of formulas etc.
If you mean the whole Workbook - then I dunno.
In future, either use the same password for everything (easy to remember) or Protect the work with nothing entered into the password field (leave this blank). This last will protect the work from people who try to guess your password, but will be easy for you to remember - eg every password is left blank.
If you must use unique passwords, then keep a record of them somewhere other than on your computer.
Sorry I can't help with the "Workbook" solution - but somebody else out ther may be able to do so.
Apr 25, 2008 | Microsoft Office Professional 2007 Full...
EXCEL
It is very useful to learn excel shortcut realy i thank you
Sep 26, 2007 | Microsoft Office Standard for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
264 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
