Question about Echo Garden
Bogs down after warming up
Runs good for a few min then bogs down for a little bit then runs good for a few seconds then bogs down again
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Check exhaust port first. then carb adjustments, then either crankshaft seals or carb needs replaced... You cannot adjust carb, it has to go to a certified center for this procedure... Thank the EPA for this B.S. and no you cannot by the adjustment tools on Ebay.
Posted on Dec 28, 2013
2 Suggested Answers
Healeyman
  • 1198 Answers
SOURCE: echo hedger bogs down after running for a few minutes
Keep a can of WD 40 handy, spray the workings regularly. Shrubbery is sticky.
Posted on Nov 27, 2013
Echo hedger bogs down after running for a few minutes
Nov 26, 2013 | ECHO, Inc. 20 In. Double Sided Hedge...
Low fuel pressure 99 cherokee classic
either fuel pump but change fuel filter first and see if it helps
May 13, 2012 | Cars & Trucks
My leaf blower starts great but takes a while to warm up thats ok too. but when i run it full throttle after warm up its runs for a few seconds and bogs down and runs very slow then after about 5 min. of...
sounds like a plug problem, pull the plug and check the quality of it, also check the gap. also are you useing the correct gas oil mixture , with fresh gas.
Mar 12, 2011 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Engine runs great but as soon as I attempt to move snow it's throws a very little bit, bogs down and "pulls" the engine down to off.
Sounds like an engine that either isn't fully warmed up or the choke improperly set.
Jan 22, 2011 | Garden
Engine bogs down when speed is increased.
Ok I have r Royobi Tiller (30CC Gas) And last year it ran fine after rebuilding the Carb. This year it was "hard starts" Idles fine, (Tiny whisps of blue smoke in exhaust with correct ratio) Even seems to run better with the choke "on" but still...at idle only. as soon as I touch the throttle...its bogs down in tune with how much gas I give it. Little throttle? Little bog down, Little more throttle? Almost stalls, a normal throttle rev? it stalls dead! Then starts right back up again in 1 pull and idles fine again!? WTF? So after cleaning a clean carb again, (twice) and seeing no change I thought I'd go look at the original diaphragm and compare it with the rebuild kit diaphragm (which is the one in the carb.) And guess what? The replacement has a larger rivet by a factor of "2". So basically it was flooding the carb, I bent the needle tang down, better but no cigar. But I could rev it half way now. A second disassemble to bend it yet a bit further and Vrooom vroom vrooom ****! So check your needle valve even though you think its 100%. (Especially if you rebuilt the carb with a kit!)
Mar 27, 2010 | Honda 25cc 4-cycle Mini Tiller
1987 Bayliner capri 85hp force starts and idles fine,after it
if u have a seperate onboard tank i bet its the vent valve is closed
Feb 21, 2010 | Raymarine Linear Feedback Unit For...
Starts then bogs down and quits running
Check and change the fuel pump relay...the one in the black box inside the engine compartment....hope this will help
Jul 07, 2009 | 1998 Isuzu Rodeo
Doesn't want to run after outside temp reaches about 60 degrees
i think something is chokeing it either the air filter or the catalytic converter or it could be 1 of the intake sensors
Nov 17, 2008 | 1991 Mercury Topaz 4 Door
1986 hyundai excel gl
Try changing the fuel filter. You may want to consider a Weber carburetor conversion. That Asian carb is old
May 24, 2017 | 1986 Hyundai Excel
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
Garden Logo
361 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
