Question about Panasonic DVD-LA95 Portable DVD Player
DVD player just shuts off when using
When we have been using the DVD player in the car, the batteries fully charged, it will just turn off when in use.  We power the DVD player back up and after a few minutes it will just turn off again.  The problem does not happen all of the time when using.  When this has happen, I have confirmed that the batteries are charged.  It has not happened when it has been plugged into an outlet.  I think that it might have a loose wire or board that when it is been held in the car, the motion causing it to turn off.  Any thoughts?
Thanks...
    Scholar:
  • 132 Answers
As you say - - if it does not happen all the time, you have the worst problem ever.
AN INTERMITTENT FAULT - Horrid
You are likely to be correct, and have a loose connection / poor solder joint / dry joint within the unit.
Time and patience could find this fault - as long as you have a soldering iron, and a good avo..
Posted on Aug 15, 2008
SOURCE:
How long does it take to charge battery. how do I know when we need a new battery
If ur battery is less than a year old,it take about 6 hours to fully charge the battery,after a year the battery weaker,it take like about 8 to 10 hours for a fully charge.The used of the DVD player last only 10 to 20 of used of the DVD player or DVD player the charge light don't lite at all.
Dec 13, 2010 | Durabrand PDV-709
When I plug in the ac adaptor to charge unit,the instructions state the chg light will go off when charged. Is it possible that it is charged and the light stays on. I charged it (in the off position)...
The unit still,work?The battery when it low,the battery light turn yellow or red?Than when it fully charge it turn green?Just unplug the unit and use it dosen't matter,if the light don't turn off the light,that find.Or the battery is old and not taking full charged anymore that another resoan the charging light still on.
Jun 14, 2010 | Mintek MDP-1770 Portable DVD Player
Need help charging my mintek dvd player battery
The way the battery is usually charged is by plugging it into the player and plugging the player into the a/c outlet. Do not use the player, Just allow the player to charge the battery. The way you tell if the charging is working is the light on the front will usually be a red color and it will be steady color or blinking while charging. When the battery is fully charged, the light will turn green or turn off . This lets you know that the battery has fully charged.To test this try using the dvd player on the battery only. Play a dvd or cd and see if the battery is working properly. I hope this information helps you with your problem.
Apr 01, 2009 | Mintek MDP-1770 Portable DVD Player
GPX DVD Player
Most items, first time your have to charge it for continious 8 to 11 hours. On that time it fully charge the battery and internal battery. I would say charge it for 11 hours.(It wont over chage on anything.)
But, if you already charged it for some time, discharge it fully. (Leave it playing till it wont even turn on when you puch the power button) Then charge it backfor11 hours.
Cheers!!
Mar 13, 2009 | GPX Audio Players & Recorders
Charged battery only lasts 30 minutes
Try fully draining the battery and recharging it fully. If that does not work chances are the battery is going bad. How old is the dvd player ? If its still under warranty you might be able to get a replacement.
Jan 05, 2009 | GoVideo DP5040 Portable DVD Player
Power source.
Well I am not a technical person, but i imagine it should be possible to use all such products while they are charging.
Aug 12, 2008 | Philips PET702 Portable DVD Player
Bulge battery!
I have a battery for your dvd player. You can contact me at [email protected]
May 07, 2008 | Durabrand DUR7 Portable DVD Player
How recharge battery of mintek mdp1020
leave battery attached to dvd player and plug dvd player in. leave dvd player off. LED on front of unit should glow orange. When it turns off the battery is fully charged
Feb 08, 2008 | Mintek MDP-1020 Portable DVD Player
How do I charge battery
Simply hook the battery up to the player, plug in the adapter (house AC outlet, car adapter will not recharge batter), and turn the unit off.
The charging light should come on and when it goes out it's fully charged.
Jan 18, 2008 | Durabrand Portable DVD
CHARGING
Lulu1121 and guest, red means no charge and will remain red till its fully charge. Then it will turn to green. In fact, coby battery can be charge directly without the whole unit attached. But if on charge too long and still red, battery is dead, kaput, finish. some even show evidence when the casing is swollen...gel chemicals inside is swollen. The power supply that came with it is the only way you can use it...portability is out of the question.
Good Luck
Siliconchip
Nov 20, 2007 | Coby TF-DVD7107 Portable DVD Player
Panasonic DVD-LA95 Portable DVD Player Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
