Question about Car Audio & Video
Speaker diagram from the disc player to the subwoofer av cables cant get to get it work... need a diagram.. I plug one av cable and 2 or 3speakers work and another to the SR or SL but just one work? thank you
  • 65 Answers
Some Subwoofer accept stereo line in, and hi end may need 4 channel line in direct from your head unit, its depend on which type you AMP is?
Posted on Nov 28, 2013
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
I need help hooking up my system from cable box to old toshiba 52 inch tv does not have hdmi on tv red, green , blue wires i also bought today a sony blue ray player speakers are not working ...
Please indicate the brand and model of your receiver, BD player and your speakers. Basically, you just need to connect the cable box and blue ray player to the receiver. The 5.1 speakers should be connected to the blue ray player, then another set of cables from your BD player to your TV. When you want to use the speakers while watching TV, you need to turn on the blue ray player too.
Sep 15, 2011 | Audio Players & Recorders
Alright well I have a Numark rack mount dj set with two CDN95 2 disc players. Well I bought it used with speakers and everything and do not know how to plug everything, I really need some help please...
As shown in the Quick Start Guide (link below) this unit should be connected to a Mixer Unit.
http://www.numark.com/stuff/contentmgr/files/0/662529d8e9e5b8ebe1747274e5bad9d6/file/cdn95_quickstartguide.pdf
Looking at the Diagram they appear to be standard AV Cables so you should just be able to plug the CD Outputs into the Amp AV Inputs (as long as it's a Dual Amp) and then connect your speakers to the Amp (make sure the speakers impedance matches the Amp.
Further details available at http://www.numark.com/cdn95?tt=5
Please leave feedback
Cheers
Andy
Apr 25, 2011 | Numark CDN95 2-Disc CD Player
Need wiring diagram for bass w x 10
You have not mentioned what equipment you would like to connect to this active subwoofer.
Assuming you have an AV Receiver, you will require a single long RCA to RCA subwoofer cable. Connect the left input (white socket ) of the subwoofer to the AV Receiver subwoofer pre output.
Leave the front crossover knob at 100Hz , Phase at 0. While playing an audio track slowly increase the subwoofer front volume to suit your taste. If you are using big floor standing speakers along with the subwoofer reduce the crossover frequency to 70Hz. Phase should be adjusted to blend the front speakers with the sub.bobhifi_6.jpg
Mar 09, 2011 | SpeakerCraft BassX-10 Subwoofer
I have no idea how to connect these speakers all I have is the wires for the 5 speakers and a power cord for the sub any help please?
You have not mentioned -- connect it to what ???. Assuming that its an AV receiver. Start by connecting the front three speakers to the the amplifiers speaker sockets labeled Left front / Center / Right Front. These are connected using three short wires. Then connect the two surround speakers using the pair of long speaker cables. You will need a RCA to RCA cable to connect the subwoofer to the Receivers subwoofer preamp out.The subwoofer also requires an A/C wall socket to power it.
Mar 08, 2011 | Cerwin Vega AVS-5.1 System
How to hookup
It depends on the TV connectors. The most common is to use either the AV or S-video. In both cases you carry the video signal on one cable (either an RCA plug (yellow) or a S-video). Plug this into the appropriate video in on the TV. Then you can connect the audio. If you use the TVs speakers or a stereo receiver or amplifier, use a 2-plug (or a 3-plug including the RCA video) on each end wire (red and white for the audio) with the white wire carrying the left audio. Connect this cable to the audio outputs labeled Front on the left of the DVD player. If your TV uses PAL signal you will need to set the audio to 2-channel and the Down-Mix to Lo/Ro. Both are accessed from the On-screen menu or the buttons on the remote when a disc is in the player. The Down-mix is in Preferences 2 (Zoom + on the remote) and the Audio Channels is in Speaker Settings (Zoom - on the remote).
If you are using a multichannel (5.1) speaker system, use a couple of extra audio cables and match them to the speakers input ports (center, subwoofer, rear left and right). Set the Speaker settings appropriately. If your receiver can handle digital audio output, you can use that (get a cable) and modify the Preferences 2 section for digital audio.
If your TV doesn't have A/V inputs, you will need a converter. (If you only have RF (coax) in, get a RF modulator.) These are available at many stores.
I hope this helps.
Aug 14, 2010 | JVC XV-D723 DVD Player
Subwoofer wont work
Receivers often have the ability to switch off the subwoofer channel. Especial if it wasn't connected before. If it has the ability to do a speaker test or set up try that. If it bypasses the subwoofer that will confirm the channel is not on.
May 22, 2017 | Aiwa AV-D58 Receiver
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
How to hook up a subwoofer to my computer?
i to have that sub and i hook it up to my dell 1501 i use a mini steroe plug it has two input so you can hook up two device get two y cables on one end it will have a plug like your headphone plug on the other end has two male the ones you hook up at the back of your steroe the other cable is a y cable as well this one has two female end and steroe end to hook up to the sub connect both wires to become one male to female one end goes to the computer the other end the sub you cant do it wrong there is only one plug that will fit hope this helps .
Jan 12, 2009 | Jensen JW250 Main / Stereo Speaker
Speakers
Test the speakers by changing source to the disc mode, and inserting a dvd into the HTS. If you get sound on all 5 speakers in DVD mode, then your speakers are still good. If you don't get sound on all 5 speakers, then press the "SURR" button to try the sound in stero, dolby, or other modes - one of these should give you sound on all 5 speakers. If you still don't get sound on all 5 speakers in dvd mode, then there is a problem with the speakers or speaker wires.
If you do get sound on all 5 speakers in disc (dvd) mode, but not when in TV mode, then take out the red and white AV cable, go buy a digital audio or SPDIF cable, and plug in the digital audio or SPDIF cable from the digital audio OUT of your TV or cable/satellite box to the "DIGITAL IN" of the HTS.
-Tha Mp3 Doctor
Feb 17, 2008 | Philips HTS3440/37 System
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
