Question about Frigidaire GLHS66EJ (26.0 cu. ft.) Side by Side Refrigerator
Freezer reads 0 and fridge reads 40
When you try to adjust temp. it will reset and power on again
    Top Expert:
  • Frigidaire Master
  • 12,957 Answers
Those readings especially for the freezer are normal. why you are getting a reset is strange. Use another digital thermometer and take readings in both locations. I suspect that there will be a different story and then you can go from there to find the cause of the anomaly.
Posted on Nov 27, 2013
SOURCE: Freezer Working, but Fridge side is not cold.
Excuse me, will not cool lower that 45.
Posted on Jan 27, 2008
  • 125 Answers
SOURCE: Side by side frigidaire
check the evaporator fan motor, behind the back wall of the freezer. If that is turning check if the damper is opening, top lt of the refrigerator compartment. I hope this helps you.
Posted on Jul 19, 2008
  • 942 Answers
SOURCE: Will not make ice, freezer temp is high, can not control the temp
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Posted on Apr 01, 2010
  • 910 Answers
SOURCE: i have a frigidaire fridge,
The E-F Error is a comon fault with all Frigidaire units and is related to the Evaporator Fan but the fault is more often than not associated with the Control Board.
Removing the power from the unit (for upto 8 hours depending on the Control Board) could reset the Control Board and clear your problem.
If this doesn't work then you'll need to replace the Evaporator Fan and/or Control Board.
Can you hear the Evaporator Fan running behind the back panel in the Freezer?
Posted on Jul 02, 2011
  • 11 Answers
SOURCE: Frigidaire Fridge: Temp display blinking, Hi temp alert, and sounds from the freezer
Make sure the internal vent is not blocked with ice.
Posted on Aug 25, 2012
New Westinghouse fridge cannot seem to adjust freezer lower than 0' except if power freeze on getting colder ?
read the user manual or get a technician out under warranty
from 10 down to 0 on a fridge is getting colder with the smaller numbers
with a freezer 0 to 10 gets colder as the numbers get bigger
Jun 05, 2016 | Westinghouse Refrigerators
How do I get my fridge to cool in cold weather with buying grill covers?
That is correct, you have reached the thermostat set point. Does not matter C or F. Read the manual it will give you the limits:
The ideal refrigerator temperature is 35°F (1.6°C). You're not hugging the danger zone like you would be at 40°F (4.4°C), and you're distancing yourself sufficiently from 32°F (0°C) that you don't freeze half the stuff in your refrigerator.
Try these links:
At What Temperature Should My Refrigerator Be Set Tips from The Kitchn
What Are Normal Refrigerator and Freezer Temps eHow
What temperatures should keep my refrigerator and freezer set at
Mar 02, 2015 | Thetford Refrigerators
Refigerator is freezing food
Hi, this problem is going to be with the running thermostat. It has gone bad and stays open which in turn will keep the compressor running continually. It can normally be located in the control panel inside the fridge. Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 18, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerator is not working, freezer is working
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
My freezer on my GE GSH25jfta BB will not get above 0 degrees even on the lowest setting. I have tried adjusting the temp from 1 to 9 with the same 0 degree reading. Could it be the thermostat?
your refrig's frzr temp is designed to be around 0 degrs. in order to give you a 35-40 degrs. temp in the freshfood side. you might not have a problem at all. check temp sensors and main brd in the rear.
Jul 14, 2009 | GE GSH25JFT
Refrigerator cools, but not cool enough, even with temp adjustment turned to coldest setting. Freezer only gets down to 0. Fridge at 44 degrees
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 06, 2009 | Refrigerators
Cannot get the fridge to start cooling
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Did you think this was helpful? Yes No
Feb 08, 2009 | General Electric GFSS6KKXSS Stainless...
Fridge freezer samsung model no sr-s2028cvw
fridge side should only be around 36 to 40 degrees freezer side around 0 to10 below
Apr 13, 2008 | Refrigerators
Kenmore side-by-side with thermo switch problem?
Acting like a bad thermostat, One thing to check is make sure compressor isnt overheating. If really hot you could have a relay problem on compressor.
Jan 05, 2008 | Refrigerators
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire GLHS66EJ (26.0 cu. ft.) Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
