Question about Honeywell Thermostat Ct31a Heat & Cool Non Programmable
Home furnace erratic
Replaced old with this thermostat and was working at first but then the heater would turn on and off, work for a while then quit. Noticed a small resistor was broken and wondering if this could cause the problem I am having.
    Genius:
  • 1,198 Answers
Did you keep the old thermostat? I prefer them. New ones want batteries, and can get complicated.
Posted on Nov 26, 2013
3 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: digital thermostat not working
Can you saY, Batteries!
Posted on Sep 15, 2008
  • 1033 Answers
SOURCE: I replace limit switch on my furnace heater with a wrong one and my thermostat sparked. My heater won't turn on now. What can I do?
Csn you check the 5 amp fuse on the Furnace control board to see if its blown?
Posted on Dec 11, 2012
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
6 year old colman furnace codes 1 blink ignition failure. Turn heater off at thermostat it cycles and heatsd house restarts a few times. alot of clicking noises and codes again a few cycles later. works...
I had the exact same issue and replaced the control circuit board, igniter, flame sensor, and thermostat just to discover the real problem was a rusted out Roof Jack. (The exhaust pipe that goes through the roof. The inner fresh air pipe was rotted out so the furnace was sucking exhaust gases in which would not support combustion. Have your's checked.
Oct 24, 2013 | Coleman Propane Forced Air Heater...
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Jan 04, 2013 | Coleman Mobile Modular Home Electric...
I replaced my old mercury thermostat with a ct87k and it will not turn on. I have tried several so they surely are not defective. Hooked my old one back up and the furnace works. only 2 wire supply on a...
the two wires are hooked to the baseplate at the R terminal and the W terminal. there may be a switch somewhere on thermostat for electric or gas heat. make sure its in gas mode. make sure batteries are fresh and put in correctly in regards to polarity. make sure furnace is on when doing any settings with the thermostat. make sure themostat is set to "heat". make sure themostat is calling for heat (turn way up to be sure its doing that) . check the troubleshooting guide that came with the new thermostat.
Oct 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
I have a Honeywell CT3200A1001 in my home, I need help! It kicks on but won't heat the house passed 71 degrees. The furnace seems fine but the thermostat just keeps turning it on and off with no results...
try replacing the battery in the thermostat i am not familiar with this particular model but had a similar problem in my home replaced battery and now works good
Oct 10, 2009 | Honeywell Electronic Programmable...
Furnace blower not working how it should
first off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Jan 19, 2009 | Coleman Propane Forced Air Heater...
Furnace blower motor turns on and off all the time...
blower will not shut off. will only shut off by turning off circuit breaker. changed thermostat. no help. what should i check?
Dec 20, 2008 | Coleman Propane Forced Air Heater...
Need to know which terminals run what
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Nov 07, 2008 | Honeywell Focus 6300B 5-2 Days...
Honeywell Thermostat Ct31a Heat & Cool Non Programmable Logo
35 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
