Question about Vacuums
Replacement belt sliding over and smelling v. hot
The belt that drives the brushes had broken,we have bought a replacement but as soon as we turn the cleaner on the belt veres to the side and catches on a piece of metal,which looks as if something has snapped off. Any ideas please?
  • 98 Answers
Try taking a small locking washer and push it on the shaft with a pair of needle plyier
Posted on May 09, 2009
I replaced the belt but as soon as I start the vacuum I smell burning and the belt is broken?
The brush roller is clogged with debris and unable to rotate. Because of this, the new belt was unable to move and the motor shaft spun in one place until it burned through. The brush roller has to be removed and disassembled to allow the end caps to be cleaned inside.
Dec 26, 2016 | Vacuums
Why are the belts burning and the brush not turning?
Check the ends of your brush roll. Most have bearings on the end and if one of those is locked up and will not turn it will burn the belt. Sometimes hair will get in the bearing area and will contribute to the bearing locking up.
May 14, 2014 | Hoover U5780-900 Windtunnel Cyclonic...
Brushes will not rotate
I can't tell for sure from the pictures, but there are two possibilities - the drive belt to the brushes broke, or the brush can't turn due to excessive hair wrapped around the shaft. If the belt is OK but the brush does not turn, you should smell burning rubber.
If the belt is broken, you have to remove the bottom plate to expose the brush, remove the brush and the broken belt, and replace the belt, and put it back to gether. While you have the brush out, now would be a good time to clean it - remove the hair, etc from the brush and around the shaft. Good Luck!
Dec 19, 2012 | Hoover F7210-900 SteamVac V2 Upright...
Motor runs, but noisey, smells hot, brushes don't turn
First you need to check why the brushes are not turning, this could be due to a lack of suction, which means the smell of heat and excess noise is due to a faulty motor, this can also be tested simply by testing the units suction power.
A faulty motor is the most comon problem when it comes to smells of heat or 'ozone' as well as excessive noise. Good Luck.
Apr 12, 2010 | Hoover H3030 FloorMate SpinScrub 500...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
Brush is not rotating and I get a smell from the
It might be the drive belt. If it is stretched, worn or broken it will not turn the brush roll. You can get replacement belts here:
Replacement Vacuum Belts
Nov 24, 2009 | Vacuums
The brush isn't turning. Have cleaned around ends of brush. Looks like the motor isn't turning the belt.
Belt could be broken or has come off. It needs to be taken apart to find out. Not a hard fix usually. Since you didn't mention that it didn't squeal, got hot and smelled of burnt rubber or the roller didn't spin this is my guess.
May 09, 2009 | Vacuums
Brush froze up and keeps breaking belts
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
Feb 25, 2009 | Bissell Upright Vacuum - The Pet Hair...
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Vacume brush won't turn but belt is not broken
The belt is probably stretched and won't drive the brush roll. Also check the brush roll, the ends should turn freely, if no, then replace it also.
Mar 20, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
