DT 16300 Digital TV recorder
It has been suggested that I elaborate on the problem so here goes. The Recorder lost all the recorded programmes and the TV Guide. I posted this on here and it was suggested that I do the following - Menu>Set up> Help> Green>Red. This I did and everything worked again. The only problem is that I cannot now record a series - there used to be a Series Link option which no longer seems to be there. Any ideas
SOURCE: DVR 6200/6400T Upgrade
get version 8 of software
Posted on Nov 25, 2008
futureloginn
  • 734 Answers
SOURCE: Olympus digital voice recorder VN-1000PC malfunction
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 12, 2008
SOURCE: Thomson DTI 6300 Digital TV Recorder freezes
try this forum http://kafkasworld.com/phpBB2/ they have tons of stuff on thomson dtis
Posted on Dec 21, 2008
SOURCE: panasonic viera tv,recorder. since updating the
ran auto set up on hdd recorder
Posted on Nov 19, 2009
  • 212 Answers
SOURCE: My thomson DTI6300 digital TV recorder shows that
If you have no recordings and it's playing up, I'd do a complete reset as follows;
Restore Factory Defaults
This will restore all the factory settings and erase the contents of the box.
Menu>Set-up>Help>Green>Red
Format HDD
This will re-partition and re-format the hard drive.
Menu>Set-up>Help>Green>Blue
This will wipe everything you have recorded. It will also dump your 14 day Electronic Program Guide which will take upto a day to reload. Leave the unit on standby.
You might want to take this opporunity to do a channel scan as well.
Posted on Jan 22, 2010
I can't record digital tv on the dvd recorder coupled with a new philips tv with built in digital
You need a freeview box to connect to the scart INPUT of the DVD recorder. The Freeview box has to have a programmable timer built in. Connect your aerial to the freeview box, the aerial output then goes into the TV. You program the DVD to the times you want to record each program, but always the input is the SCart. You the program the Freeview box to change to the right program at the beginning of the program you want to record.
Jun 27, 2011 | Mico DVDR311
Nd.comI have a set top box awa DT 2030 trying to connect to a standard tv through a video recorder/player what are the instructions as I cannot get it to work
Hi, With new DTV's these days, there will be problem running old players.(VCR) Video cassette recorders will not be able to record Digital signal. You will have to get (PVR) personal video recorder which can record and play Digital programs with great picture.
Jun 11, 2011 | Televison & Video
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
SINCE RETUNING TV IN dECEMBER TO RECEIVE DIGITAL TV THROUGH MY DVD/FREE TO VIEW RECORDER I HAVE NOT BEEN ABLE TO RECORD ANY TV PROGRAMMES. THANKS!!!
The tuner in the DVD recorder also needs to be digital. If you have a converter box that would take care of it, otherwise you'll need a new DVD recorder.
Dec 14, 2009 | Radio Communications
Thomson top up tv recorder Model 16300 wont record
Found this on another site. it worked for me.
Do the following:
Menu > Setup > Help
* Then press the Green Button (Even though it doesn't show as an option)
* Then press the Red button for a full reset
Hope this works for you.
All the best
Pottysam
Jul 20, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Mar 24, 2008 | Televison & Video
Sony RDR-HXD860 DVD Recorder
Have you observed any 5 digit service numbers in the display of your unit?
Jan 22, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
Televison & Video Logo
Top Televison & Video Experts
