Question about Dell 3110cn Laser Printer
Dell 2155cn Error message 016-370 - Dell 3110cn Laser Printer
What can I do .....I am not receiving confirmation pages after I fax.
Anonymous,
Click the link below to download the online manual for the printer. The manual provides information on faxing as well as other helpful topics that you may need to resolve issues.
Dell 2155cn Printer Manual
http://dell.to/1PrwXMm
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 07, 2016 | Dell 2155CN Color Laser Fax, Copier,...
I have a paper jam error message that will not go away. Paper path is clear and will feed paper in Customer Mode. Tries new paper tray and fuser - still have error.
Hi Bruce Lisanti,
My name is Rohan and I work for Dell.
Since you have already replaced the paper tray and fuser, going by the symptoms that you have mentioned, seems to be like an issue with the Feeder assembly. If the printer is in warranty, please call the dell tech support in your country to receive support. If it is not under warranty, we request you to take it to a local technician.
-Rohan
Social Media and Community Professional
Order Status: http://dell.to/1fgKSTr
Download Drivers : http://dell.to/1hcxG98
Jun 16, 2015 | Dell 2150cn / 2150cdn / 2155cn / 2155cdn...
2155cn printer giving error #006-370 what should I do
Power off the printer and turn it on again with the big button held down (the one with the tick on it).
This seems to clear the error and allow printing but won't fix the fault itself.
Feb 17, 2014 | Dell 2150cn / 2150cdn / 2155cn / 2155cdn...
MCU Firmware Error: Error 006-370: Code 00000001h on 2155cn dell printer
  • Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
  • for more help visit CBR Tech Solutions
Dell 2155cn will not print
Hi Joyce,
Use this link for help:
Troubleshooting Printhead Problems on the Dell AIO V313 V313w V515w...
  1. Turn off the printer, and remove the Printhead out of the printer,
  2. Connect the printer and the computer with a USB cable and turn on the printer.
  3. Open this link in the computer:
Drivers Downloads Dell US
4.Select the operating system of the computer from the list of options.
5. Under the Firmware, select the right Firmware according to the printer model depending on Wifi mode.
6. Click "Get driver" and follow the onscreen instructions and update the Firmware software.
7. Reinsert the printhead and try printing and check.
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Dell Printer Support
Feb 05, 2014 | Dell 2155cn and 2155cdn Color Laser...
Dell 2155cn
If you are looking for a printer driver for your Dell printer then -
You can download the Dell printer drivers from their supportWEB site. Please click on this link and select your model printer to download:-http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=3A943AE039242E89E040A68F5B2854C9&journalid=803559AE24446852E040AC0A66E95D38&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=&toggle=&dl=#Issue0_3
Mar 18, 2012 | Dell 2155cn AllInOne Laser Printer
Dell 2155cn Installs without error, but won't print
Most router (DHCP servicer) issue an IP to any device on the network, is your PC on the the same subset of the network? Can you ping the printer? Check your printer and device property, make sure you have the same IP address and you're on the same subset.
Feb 02, 2012 | Dell 2155cn and 2155cdn Color Laser...
Need a printer driver for Dell 2155cn for Mac Os X Lion
Google Cloud Print works with all printers I've tried. Good solution for those printers with no Mac drivers
Jan 25, 2012 | Dell 2155cn AllInOne Laser Printer
Is there a Driver for this printer for Linux (Ubuntu)?
Yes there is. You can find it on:
http://support.dell.com/support/index.aspx?c=us&l=en&s=dhs
Go to Drivers & Downloads, select your 2155cn from the device list and select your operaring system. It should direct you to a driver download for your printer.
Sep 12, 2011 | Dell 2155cn AllInOne Laser Printer
Dell 3110cn Laser Printer Logo
54 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
