Question about Primos TRUTH Cam Ultra 35 Game Camera 63011
I cant get camera to take pictures, when its set it starts counting down then there are no pictures when i look at cassette
My Panasonic pv-gs180 doesn't record.
If you have Head Cleaning Cassette play it at 10 seconds or use new Cassette for 10 minutes play or record. Otherwise Video Head damage
Mar 10, 2010 | Panasonic PV-GS180 Mini DV Digital...
A delayed pic
Hi dear, you can download the manual from (http://www.retrevo.com/support/Kodak-C330-Digital-Cameras-manual/id/200bh336/t/2/) this site.
All you need is inside. Have FUN !
Jan 27, 2010 | Kodak EasyShare C330 Digital Camera
How do you set the timer on a Finepix F50D, I don't have the manual with me
Press the bottom part of the ring around the menu/ok button to activate the timer. Press once for 10 second count down and twice for 2 second count down. Then press the picture button as normal and the count down will start.
Nov 26, 2009 | Fuji Finepix F50FD Digital Camera
DEW message keeps coming up on camera
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 22, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
F--
Unlike other cameras that start at frame #1 after loading and count up as the film is used, the N55 advance the film to the last frame during the loading process. When loading is complete, the frame counter stops at the number of available frames on the roll (usually 24 or 36) and counts down as photos are taken. I know it sounds backwards but it actually makes a lot of sense to engineer it this way. After the last photo is taken (displays 1 on the counter), the camera automatically winds the end of the film into the cassette and the counter shows a blinking E. I am assuming that that is what is being displayed and not a blinking F. it it is an F, perhaps there is a problem with the LCD display? If so, it probably isn't worth having it repaired.
Jun 26, 2007 | Nikon N55 35mm Film Camera
Can't find pictures I took, but camera counts down the number of pictures left
first try to set playback folder to all: Platback menu - Playback fldr - all I am sure it will fix it, if not try diff memory card. good luck.
Nov 09, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Primos TRUTH Cam Ultra 35 Game Camera 63011 Logo
41 people viewed this question
Top Primos Video Cameras Experts
Are you a Primos Video Camera Expert? Answer questions, earn points and help others
