Question about Lenovo 17" Thinkvision L171 9227-Ac1 Lcd - 17"
Lenovo 17" L171 9227 AC1 Monitor no display
Screen blank
Half Screen Black half screen working
Display panel fault. Contact the authorized service center.
Jul 30, 2015 | Lenovo 17" Thinkvision L171 9227-Ac1 Lcd -...
Lenovo 9227ac1 comes on then goes black light on front stays green
When it have this kind of error is a problem of the power-board.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Mar 22, 2014 | Lenovo 17" Thinkvision L171 9227-Ac1 Lcd -...
Screen is blank how do I get it to work again
Do you need the external monitor to switch it back to internal monitor or both on?
Feb 07, 2012 | Lenovo 3000 G530 PC Notebook
I have a type 6734-LB1 17" Lenovo ThinkVision
where will i get to install the software/drivers of IBM 6734-L-B-1 for listening Music
Sep 30, 2011 | IBM L170M (Black) 17 in. Flat Panel LCD...
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
SCREEN BLANKS WITH POWER LIT GREEN
Look for bulged or leaking capacitors on the power supply board. If you can solder, you should be able to replace them with the same type and rating and that may just solve the problem. I've had luck with a couple of dozen monitors so far.
Mar 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell F1703 17 in. Flat Panel... Problem
There may be problem of heating the inside components. see him to expert.
Mar 03, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Lenovo 17" Thinkvision L171 9227-Ac1 Lcd - 17" Logo
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
