Question about Sony Cyber-Shot DSC-P32 Digital Camera
Memory Stick Hi, I have had this camera for over a year and all of a sudden it refuses to read a memory stick. I keep trying different memory sticks but the camera will not register the stick.
  • 1 more comment
  • memod Dec 13, 2007
    i got the same problem, something i tried before was taking out the batteries and the memory stick and holding the power button for a while and putt it all back and turn the camera back on, sometimes it worked, sometimes didnt (most of the time) soooo i still got the same problem lol
  • firebuff Jan 23, 2008
    Same thing for me. Used it just the other day and then tried to use it today and it won't read either of my memory sticks.
  • Anonymous Mar 18, 2014
    I don't know how to get the camera to read the memory stick
I got the same problem, if i had a sony office/sales shop around i'll go give them to take a look,
Posted on May 24, 2008
I've been having the same problem.. Try bringing it to your sony service centers so they can see what the problem is.. try resetting the device.. i did that and it worked..
Posted on Jul 08, 2008
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
Sony DSC-P32 Memory Stick Error, "C:13:01"? When I went to review pics on memory card, camera would not scroll through and it would immediately shut off. Assuming it was the batteries, I...
The C:13:01 error code is the self diagnosis display of the camera to identify the cause of the issue with the Camera. This error code indicates the issue with the medium used in the Camera. You can try few steps to check if the issue can be resolved.
Try using different Memory Stick in the Camera.
Make sure that the Memory Stick used is compatible with the Camera. (The maximum capacity that can be used in the Camera is of 2GB Memory Stick PRO Duo.)
Format the Memory Stick in the Camera and check if it works. (Formatting the Memory Stick will delete all the files saved in it).
This may happen if the files in the Memory Stick is damaged or corrupted.
Try turning the camera power off and on.
Remove and re-insert the Memory Stick several times.
Insert another Memory Stick in the Camera to check if the issue is with the particular Memory Stick.
Try resetting the Camera and check if it helps. To reset the Camera, press the RESET button located inside the jack cover using a sharp pointed object.
If the issue happens with different Memory Sticks after performing all the steps, service may be required.
Dec 05, 2010 | Sony Cyber-Shot DSC-P32 Digital Camera
13:01 error
The C:13:01 error code indicates the issue with the Media used in the Camera.
This may be due to the:
Format Error of the Internal Memory.
Un-formatted Memory Stick Duo.
Broken Memory Stick Duo.
Memory Stick Duo type error.
When the Camera cannot Read or Write the data in the Memory Stick Duo.
This can be resolved by Formatting the Internal Memory and Memory Stick Duo.
If not resolved, try inserting a new Memory Stick Duo which is supported.
Try power resetting, remove and reinsert the Memory Stick etc.
This will resolve the issue, if not the Camera may require service.
Aug 06, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
The Error message C:13:XX indicates that the Camera cannot read or write data on the Memory Stick or an unformatted Memory Stick is inserted in the Camera or the inserted Memory Stick cannot be used with your Camera or the data is damaged.
1. Try reinserting the Memory Stick several times.
2. Format the Memory Stick in the Camera.
*Formatting a Memory Stick will delete all the data saved in the Memory Stick.
Insert the Memory Stick in the Camera, Turn ON the Camera. Press MENU -> Memory Stick Tool -> Format -> OK.
Memory Stick compatibility information for you Camera:
3. Try with different Memory Stick.
Good Luck!!!!!!!!!!!!!!!!!!!!
Aug 28, 2009 | Sony Cyber-Shot DSC-P43 Digital Camera
Memory stick error when camera is turned on
How about download the user manual from this link
and then, please read page 106 and follow the sugestions they have relative to your memory error.
Are you using the correct memory type recommended for your camera?
Did you insert the memory stick in correctely?
Is the metal part of the memory stick and the camera clean?
Did you accidently recorded video for a long time on the memory stick. The memory stick may be full.
Did you unlock the memory stick if it has one?
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 27, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Keeps telling me to reinsert my memory stick
I will forward a link to a page where you can get the information about this issue.
Also please check whether you're using a Compatible Memory Stick with the Camera.
It's not recommended to Format the Memory Stick in the Computer.
The Memory Stick should be Formatted in the Camera only, other wise such error messages can occur.
Please try using a different Memory Stick and check whether the issue persists with the other Memory Stick.
This is to check whether the issue is with the Memory Stick.
Apr 14, 2009 | Sony Cyber-shot DSC-W300 Digital Camera
My Sony DSC-R1 refuses to read memory sticks
The first think I would do is connect the memory stick to the computer and reformat it.
Feb 10, 2009 | Sony Cyber-Shot DSC-R1 Digital Camera
Flashing Acces lamp while using camera.
Flashing Access is sign that memory stick has some problem and mostly it can be fixed if you format memory stick through camera Menu Format Option.
Jan 04, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Memory Card Problem
Have you (or can you) formated the memory sticks when they're in the camera?
Sep 13, 2005 | Sony Cyber-Shot DSC-P5 Digital Camera
Sony Cyber-Shot DSC-P32 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
