Question about Philips CD535 Cordless Phone
Volume increase how do I increase the earpiece volume
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
How to increase the ear piece volume in Nokia 5800 express music and what is the default pin code to reset
You have to be on a call to adjust the earpiece volume. Just call your voice mail and turn the volume up. It's the same button you use to turn the phone ring volume up and down. When you're not on a call the volume is for how loud your phone rings. When your on a call the volume buttons adjust the earpiece volume
Sep 03, 2010 | Nokia 5800 XpressMusic Smartphone
When i make a call i can not hear the caller,but the cller can hear me motorala w510
is this the first time this has happened?
have you dropped your phone?
try a reset of your phone by taking out the battery and the SIM card2_bing.gif. Wait
15 seconds and put it back together and power it on.
I have had this problem and have helped fix others phones this way.
sometimes your phone just needs a hard reset. especially if you leave your phone on all the time.
now,if you have dropped your phone a lot or it had a real bad fall you mayhave damaged something. In this case it is time for a new phone.
Hope the rest helps!
Mar 26, 2010 | Motorola Mobility W510 Mobile Phone
HOW DO I INCREASE THE VOLUME ON NOKIA E63
Answer the call then scroll to the right to increase the volume of the earpiece. Scroll to the left to decrease the volume. You will see the volume bar increases or decreases as you adjust it. The scroll keys are also called the navigation keys. They are the ones used when you navigate the menu up, down, left, or right.
Jan 23, 2010 | Nokia E63 Cell Phone
I have very low volume in the earpiece for calls but great volume for recorded voice or sound. What gives?
while making or receiving calls, try to increase by pressing the upward arrow at the side or on the keypad, earpiece volume will be increased
Dec 13, 2009 | LG VX5300 Cellular Phone
How to increase speaker volume during phone on nokia E63
To adjust the earpiece volume during a phone call,
scroll left or right. To adjust the volume of the media
applications, press and hold the function key, and scroll
up or down.
Dec 05, 2009 | Nokia E63 Cell Phone
W do I turn the earpiece volume up
there will be two buttons + and - for increasing and decreasing your ear piece volume. press + and increase the volume up.
Sep 08, 2009 | Lands Phones
Need to adjust earpiece volume
You can increase the earpiece volume by pressing the UP volume key (located on the side of the phone) *during* a phone call. I simply called my voicemail and once it connected, I hit the UP volume key and the volume meter displayed. Then I pressed it til it was the max and pressed SET. That worked for me, hope it works for you.
--Edriss
edriss@yahoo.com
Aug 17, 2008 | Cell Phones
Earpiece volume
Your earpiece might have a problem. Normally the volume on the phone works with the earpiece
Jan 11, 2008 | Nokia 6600
Philips CD535 Cordless Phone Logo
20 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
