Question about Vivitar VC-7340 Digital Camera
Very bright pictures from ouside
When taking pictures outside, they are too light - you can't see anythig - only white. Inside it is ok
    Top Expert:
  • Vivitar Master
  • 6,702 Answers
When you go outside, do you change anything in the settings? I think the camera should be in the auto, sport or something like that. If it is not in auto but in the night Scenery, night Portrait or high Sensitivity, pictures inside, with less light will be ok, but outside they will be over blown.
Posted on Nov 26, 2013
2 Suggested Answers
  • 94 Answers
SOURCE: can't take pictures outside
Syptom suggest shutter has failed - jammed open. Probably marginal repair ?
Posted on Jun 02, 2010
Camera exilim ex-s600 will not take pictures outside,pictures turning out white,yet will take pictures inside ok.is this a worthwhile repair
This seems to be a software problem with your camera. Your camera should, if on AUTO mode, automatically expose your photo accurately. Try half pressing the shutter button (used to take pictures) while outside to adjust focus and exposure, then press the button fully to take picture. If your camera cannot adjust to take a properly exposed picture (not bright white), then it is possible that the shutter speed is stuck on a too high speed, outside daytime shutter speed should be fast (1/1000 sec). Or if your shutter speed adjust accurately, it could be the aperture if the aperture is not small enough for daylight shooting. This is likely a software problem. Try adjusting your settings manually and see if the picture turns out!
Sep 10, 2011 | Casio EXILIM Card EX-S770 Digital Camera
Trying to take a picture outside, when I've taken it, the image is all white. Why is that?
This problem may occur if camera got too much bright inside the lens. Try to turn off the flash light and try to avoid taking picture in front of direct light, sun or lamp.
Please RATE.
Jan 16, 2011 | Samsung Digimax D73 Digital Camera
When pictures are taken outside during the day they are unclear with some white horizontal lines and when taken indoors its ok.tried everything the manual said but still no changes
White shadow or white lines may occur if the light was too bright when you take the picture, especially in strong sun light. Have you turn off the flash light when you taking those picture ? If you haven't, then you should try to turn off your camera flash light manually. And I must remind you not to take a picture with your lens faced the sun light or other light (lamp etc) directly. Even if you take a picture outdoors, try to make your lens shaded by something, you can even use your own shadow to shade them.
Hope this help and be kind to rate please.
(^_^)
Jan 08, 2011 | Cameras
Pictures are over exposed when outside
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside.
Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight
t
Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Samsung Digimax L60 Digital Camera
Why does my camera take white pictures outside,
Do you have the ISO set to a very high number instead of "auto ISO"?
Apr 18, 2010 | Kodak EasyShare C763 Digital Camera
The pictures are too light, when taken outside. Inside they are quite good, but sometimes, if it is too much light inside, I get again too light pictures
you can set the white balance so when your outside you can tone the brightness and visa versa for night. it should be in the setting of camera menu
Nov 12, 2009 | Olympus FE-220 Digital Camera
When taking pictures outside the view screen after picture taken appears as a bright burst of white light. Inside picture appear fine. Any ideas?
let me see if i understand. if you llok at the screen it looks ok, but after you take the picture it will record only a white bright image.....
in some cases you can easily fix this by goining into your camera option and restoring default settings. it is the exposure setting .
if you camera still giving you just black white images the light sensor in the machine ahs gone bad, it needs to be replace.
Oct 04, 2009 | Nikon COOLPIX L4 Digital Camera
When taking pictures outside bright white photos
i am an train picture guy but neverthe less u cant take anything for granted put cam on "P" and see whad happens and check your manual
Aug 24, 2009 | Olympus FE-220 Digital Camera
Outside pictures come out white
if the settings are auto and pics were ok b4 now started this oversxposed white pics
see the link it starts with overexposed pics outside and normal inside but u will see a red or pink or green tinge in pics
http://www.imaging-resource.com/badccds.html
pls contact service centre for free replacement of CCD i am sure they will do it even if u are out of warranty dont worry all are doing it casio will also do it
see link for europe support
http://www.casio-europe.com/euro/support/repair/dc/
US
https://www.casio.com/support/contactus/contact
pls rate me FIXYA for helping u
Mar 21, 2009 | Casio Exilim EX-Z77 Digital Camera
Digital camera . Konica Dimage G530. Problem Outside in bright light the pictures are all white. Pictures ok inside in low light. Video mode works ok inside and outside.
you need to adjust the exposure for that camera. since having too much light makes the photo all white.
Exposure and Focus Just as with film, a digital camera has to control the amount of light that reaches the sensor. The two components it uses to do this, the aperture and shutter speed, are also present on conventional cameras.
  • Aperture: The size of the opening in the camera. The aperture is automatic in most digital cameras, but some allow manual adjustment to give professionals and hobbyists more control over the final image.
  • Shutter speed: The amount of time that light can pass through the aperture. Unlike film, the light sensor in a digital camera can be reset electronically, so digital cameras have a digital shutter rather than a mechanical shutter.
Mar 21, 2008 | Cameras
Vivitar VC-7340 Digital Camera Logo
43 people viewed this question
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
